Old 02-23-2010, 08:16 AM   #225
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
SilverHoot, Let me know how your realignment works. We are almost neighbors. We are in Yreka. I'll PM you with info. There is more details on what I had to do to make things fit.
Don
NorCal Bambi is offline   Reply With Quote
Old 02-23-2010, 08:37 AM   #226
1963 16' Bambi
Yreka , California
Images: 21
Mice and Rats and Bees, OH MY!
I've removed the back inside end cap on the Cloud. And once again, "Mice and Rats and Bees, OH MY". Airstreams seem to be home on the range for all types of gritters.
Including Humans
Name:	End Cap back re 002.jpg
ID:	96820   Click image for larger version
Name:	End Cap removal 011.jpg
Name:	End Cap removal 016.jpg
ID:	96822   Click image for larger version
Name:	End Cap removal 010.jpg
Old 02-23-2010, 11:35 AM   #227
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
blech! I WILL take the whole ceiling off my TW when I get the floor in... yuck!
Marc
Old 02-23-2010, 12:54 PM   #228
1963 16' Bambi
Yreka , California
Images: 21
Marc, I'm going to start a new thread by the same title. I think it could help others rebuilding to solve some critter problems.
Don
Marc
Old 02-23-2010, 09:27 PM   #229
1963 16' Bambi
Yreka , California
Images: 21
Side Bath Design
I've just finished the design for the side bath in The 55 Flying Cloud. It's not too different form some of the stock designs. But I have made some changes to fit our needs. I am includes 2 sets of pictures of the plan. As always, I'm open for comments. The different colors represent the sections. I'm planning on making molds and producing this unit out of fiberglass. The sections are so the pieces will fit through the door.
Don
Name:	Bathroom Unit 3 View.jpg
ID:	96870   Click image for larger version
Name:	Bathroom Unit 3 View 2.jpg
Old 02-24-2010, 06:52 AM   #230
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That sure is excellent work Don. Both on the thought process and the rendering. A couple questions come to mind. How about slopping the horizontal surface under the sink for run off? I realize not much water would probably get under there but having standing water is not good. If you don't already have the sink, how about running the base all the way up to counter height and putting in a drop in sink to avoid that unusable dead space? Might even put in an access door for personal care items storage.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 02-24-2010, 06:57 AM   #231
1963 16' Bambi
Yreka , California
Images: 21
Brad, great suggestions. I will probably work on those today. Once again the forum is so great. It's so easy to miss a good idea when one gets so involved in a project. A fresh look from someone on the outside can have such value.
Thanks Don
FF
Old 02-24-2010, 07:00 AM   #232
1963 16' Bambi
Yreka , California
Images: 21
I haven't decided where to put the shower head yet. Anyone have ideas. Or comments on where their shower head is located. And what the good and bad reasons for the location.
Don
Old 02-24-2010, 07:12 AM   #233
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Don
Unless you want exposed plumbing, the curved exterior wall is out so that leaves the two end walls. Putting the hot and cold water lines on the other side of the wall you chose may be decided by what's on the other side of that wall. Another item to consider is from which direction would the two water supplies be coming from.
Alot to ponder.
FF
Old 02-24-2010, 07:46 AM   #234
1963 16' Bambi
Yreka , California
Images: 21
Bath upgrade as per suggestions.
The plumbing for the shower is a good thought. I'm also wandering about the direction of shower spray.
Don
Name:	Bathroom Unit upgrade.jpg
Old 02-24-2010, 08:17 AM   #235
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
1960's hand-held shower head
Bath upgrade as per suggestions. The plumbing for the shower is a good thought. I'm also wandering about the direction of shower spray. Don
Hi Don:
You might consider having exposed plumbing inside the bathroom from the faucet "upwards", and use a hand-held shower head like those found in 1960's Airstreams. The head can be "hooked" to the wall for an overhead shower, or taken off to more directly reach those "underneath" body parts we used to be able to see when we were younger. :<> VanDyke's Restorers has the hand-held shower head and flexible hose:
Handheld Shower and Hose Chrome, Shower Heads and Accessories, Bath at Van Dykes Restorers
During a quick look in VanDyke's web site I could not find the other hardware, a wall-mounted "hook" and the attachment to the hand held shower head that provides the "hole" for going over the hook's vertical "post". But perhaps others can help you locate those parts.
I'd put the shower faucets on the left hand wall as one enters the bathroom, and put a mount for the hand-held shower head higher on that wall. This location is closest to the shower pan. It also places the faucet knobs close to you for water temperature adjustment while maximizing the water's impact. Nice drawings!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 02-24-2010, 09:46 AM   #236
1963 16' Bambi
Yreka , California
Images: 21
Fred, thanks a lot for the suggestion. I like this unit a lot. I sure my wife will like it even more.
Don
Originally Posted by 47WeeWind View Post
Hi Don:
Old 02-24-2010, 11:47 AM   #237
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Don
Do a quick Google search on shower head slide bar . This will give you many options.
My thought is to have one nozzle. Mounted low on the bar for the sink. Slide it up to the desired hieght for a shower.
FC7039 is offline   Reply With Quote
Old 02-24-2010, 12:36 PM   #238
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Don, your drawings/renderings are very impressive. Am I correct that they are in SketchUp?
I have a 56 FC (that I acquired last summer), but I still am in the demolition stage. I hope to build a wet bath similar to your plans, and (to simplify the plumbing) I have been thinking about a single fixture for the sink and the shower similar to what FC7039 suggested.
Excellent work! Hank
RankAm is offline   Reply With Quote
Ball Height Issue, 16' International mico75 Hitches, Couplers & Balls 5 01-09-2012 07:25 PM
1964 Bambi II ball height? AWCHIEF Hitches, Couplers & Balls 5 12-29-2011 11:08 AM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
