Old 02-26-2010, 08:17 AM   #261
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
2air, Thanks these are great thoughts. The shower location is partly because of the placement of the stove and the sink. This is because of the original location for the stove vent in the side of the trailer. There are also some interesting holes that have been cut in the shell by the PO. I'm planning to have the crapper drop directly down into the holding tank. This is how it works on the Bambi. And that seems to be a good feature. Good thought about the metal being cold. It sure could be a wake--up in the morning.
NorCal Bambi is offline   Reply With Quote
Old 02-26-2010, 09:34 AM   #262
_
ok don just to EASE my confusions...
1. is this gonna be a 3 tank trailer?
2. are the tanks sizes determined yet?
3. are the tank locations sorted out?
4. will the tanks be 'custom built' or off the shelf ready mades with predetermined HOLEZ?
5. will THAT pooper location really work out?
6. by that i mean are the frame rails/outriggers spaced such that the straight SHOOT for the crapper fits right there?
i hate to be stuck at the basics or early detail stage but, don't see any mention of these things yet.
perhaps this has all be worked out and just not posted yet?
___________
and going back 1 last time, to an earlier question, is this really a WET BATH or not?
imv ceiling holes are easy to patch or redirect pipes/vents toward...
but floor holes take COMMITMENT and are hard to alter later.
so the interior design and placement of many fixtures seems to flow FROM those foundation decisions...
__________
one last question in this round...
do you have a copy of the ORIGINAL floorplan anywhere?
have u got a sketch up of that original layout?
later gator
2air'
Old 02-26-2010, 04:20 PM   #263
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
If I remember correctly.. and I may not.. , Don was working on building his own tanks... how many, I don't know.
Marc
Old 02-27-2010, 10:23 PM   #264
1963 16' Bambi
Yreka , California
Images: 21
Another question
How is the door in the back of a 55 Flying Cloud mounted. The back of the trailer I am restoring had quite a bit of damage in the back. I have the back "trunk" door but I don't know how it was attached when stock. I know it folded down because there is a key lock in the top of the door. Some pictures would be of great help.
Thanks Don
Old 02-27-2010, 10:27 PM   #265
1963 16' Bambi
Yreka , California
Images: 21
2air, I'm working on measurement and layout ideas for the plumbing now. I plan on building my own tanks. I'm trying to work a plan where I can keep everything within the 4" of the original frame. Not sure I can make that work. Thanks for the list I need to try and keep all things in mind. The Bambi was easy by comparrison because I had everything from the original.
Don
___________
__________
later gator
2air'
Old 02-28-2010, 12:05 PM   #266
1963 16' Bambi
Yreka , California
Images: 21
Here two drawings of the black and gray plumbing drain and storage unit design for our 55 Flying Cloud. The Bath Unit that I showed in an earlier post has room for the gray water pipe form the sink to run to the gray tank. The vent pipes for both the gray and black tanks run inside the walls of this unit also. Please feel free to comment.
Thanks Don
I also need some pictures from someone on how the door in the back of these trailers is attached. I have the door. There is no clear sign of how to attach.
Thanks Don
Name:	55 Flying Cloud Drain Plumbint.jpg
ID:	97153   Click image for larger version
Name:	55 Flying Cloud Drain Plumbing btm.jpg
Name:	55 Flying Cloud Drain bath.jpg
Old 02-28-2010, 08:36 PM   #267
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Thanks Don
Thanks Don
Ya know Don, I don't think they were on a hinge. I think they were like my side door on my Caravel. The top of the door slides into a channel and the you push the bottom in and latch it. I have seen some other older Airstreams and the access door fits the same way as my Caravel. So you would remove the door from the trailer when you open it. On later models that I have looked at the rear access door had a hinge at the top. I don't know if it was there from the factory or a PO made it that way.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 02-28-2010, 09:13 PM   #268
1963 16' Bambi
Yreka , California
Images: 21
Chris, Thanks I bet you are right. I like the idea as well. Removing the door for access makes much better since.
Don
Old 02-28-2010, 09:20 PM   #269
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Don
Yes it does, Someday, no doubt, I will forget and run over my access door. I think I will get a spare. haha. Came home today and was happy to see the AS and know that I will be camping next weekend. Sorry you can't make it. I am determined to make some time and stop by on one of my forays down south.
Project 2k5
Old 02-28-2010, 09:45 PM   #270
Byams55FlyCl's Avatar
Centrally Located , Wish you were here!
Here is a picture of the original Zolatone green. The rest of the trailer was in pink and two tone gray. Boy is that 1955 or what? I was still a freshman in high school then. I don't think I want to go there again.
Don
Hi Don!
Just found your thread - now I will be up all night reading!
I do hope that you've photos of the green, with pink and gray.
My 1955 Flying Cloud # 7787 is green Zolatone also, but I didn't see any pink. If you didn't share the original color photos yet, please will you share some now?
Kathy
Byams55FlyCl is offline   Reply With Quote
Old 03-02-2010, 07:30 AM   #271
1963 16' Bambi
Yreka , California
Images: 21
Byams, could you post a couple of pictures of how the back door in your trailer fit in place and what holds it there. My trailer was gutted when I bought it, so there are no pictures that show any interior. I can tell that the interior was a green Zolatone. The sliding doors on the high storage units were a dark gray with white flecks. the counter tops were the same formica.
Don
Originally Posted by Byams55FlyCl View Post
Hi Don!
Old 03-02-2010, 09:53 AM   #272
1963 16' Bambi
Yreka , California
Images: 21
New Graphic
Howdy all, I may have mentioned in an earlier post that I had some computer problems about two months ago. When that happened I lost my original 55 Flying Cloud SketchUp computer graphic. I've been working on a new one. This graphic has taken a litter longer because I've set out to make it look as much like a 55 Cloud as I could. I'm not finished with the work yet, but I thought I'd share where the work is at the present time.
Don
Name:	55 Flyint Cloud w environment.jpg
Old 03-02-2010, 10:03 AM   #273
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
And looks like a wonderful campground too. TT
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
Old 03-02-2010, 01:44 PM   #274
That's very cool Don.
Rich the Viking
VIKING is offline   Reply With Quote
Old 03-02-2010, 06:16 PM   #275
1963 16' Bambi
Yreka , California
Images: 21
Picase Slide shows of 3d Airstream graphics
Picasa Web Albums - Don - Final Design ...
Picasa Web Albums - Don - Airstream 55 ...
Old 03-03-2010, 06:38 AM   #276
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Wow! Amazing what YOU can do with Sketchup! I tried it for a hour or so one time but could not figure it out. Love your floor plan and am planning a similar dinette area. Thanks for sharing!
SilverHoot is offline   Reply With Quote
Old 03-03-2010, 06:59 AM   #277
1963 16' Bambi
Yreka , California
Images: 21
Thanks for the positive comments, How is your trailer coming?
Don
Old 03-03-2010, 07:17 AM   #278
SilverHoot's Avatar
1967 24' Tradewind
Hi Don,
My trailer is coming along slowly. Installed my 4th piece of subflooring day before yesterday. Been working from back to front and have removing cleaning and painting frame then cutting, sealing edges and installing new. Next to last piece is cut and sealed, now I have to remove the last front piece and make the new. Don't know what it's doing up your way but has been raining pretty hard here. Trailers outside and the ground gets wet under the trailer so I don't work on it when its's raining, not much fun painting upside down anyway and really bad if the grounds wet. Be happy when I get the floor completed and can do some inside work. Probably won't get much done today as it is raining as I type!
Old 03-08-2010, 08:12 AM   #279
1963 16' Bambi
Yreka , California
Images: 21
Missed the NW rally
I've decided that I want as much lighting on the trailer to be LED. So I found some new type tail lights that I have installed as a fit test. I'll include some pictures later. Be prepared, I know some will not like what I have chosen. Doesn't really fit a vintage trailer. But remember this was a shell and frame only to start with. And the purpose was to make it my own.
We missed the NW rally. And it looks like it was another great time. I was cleaning out the shop. So I could actually get some work done. And Claudia was working on taxes so we can keep the hounds away.
I have also been working on dent removal from the siding on the trailer. I got this really great video tape from a guy in England who dose this fantastic body work. It was very informative. So I'm working with some of his techniques to remove some dents. I'll let you know later how that is going. I could have replaced panels but I wanted to work with what I had. There is something special about convincing metal to move and form in the way you wish.
Don
Old 03-08-2010, 09:16 AM   #280
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Don
Could you post info on the tape and where to get it? Thanks in advance ...
Xbob2 is offline   Reply With Quote
Ball Height Issue, 16' International mico75 Hitches, Couplers & Balls 5 01-09-2012 07:25 PM
1964 Bambi II ball height? AWCHIEF Hitches, Couplers & Balls 5 12-29-2011 11:08 AM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
