Old 06-16-2006, 06:44 PM   #15
MarkR's Avatar
Profile:  1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
ouch, you must have been shocked.
I have detailed measurements of my 21' frame (and right now the frame and shell are separated (they remain friends, and I even think they have reconcilable differences (as opposed to irreconcilable) with some work of course) . . . So anyway if you need any measurements or photographs or ?, I'd be glad to help.
Led Balloon in Drag
MarkR is offline   Reply With Quote
Old 06-16-2006, 09:19 PM   #16
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
I'll second the ouch on the frame. I'm afraid to look at mine. I know it will be bad. Thanks for the kudo. Everybody on the forum has kept me going as well. It's nice to think that I might pass a little of that on.
Don
NorCal Bambi is offline   Reply With Quote
Old 06-18-2006, 09:52 PM   #17
Cloud 9's Avatar
Profile:  1954 22' Flying Cloud
Crestline , California
Ouch!
Yeah, I guess I should have known better when I saw the Washington License plate, but hey, blinded by aluminum. Any way here's a little more on what I've done so far.
After I removed the whole interior, I removed the lower interior panels. (I didn't remove all of the interior panels thinking that it wouldn't comprise the structural integrity of the shell as much. I plan on removing them for the rest of the interior refurb after I get the shell back on.) Then I attached cross bracing to the exposed ribs. 2X4's were attached perpendicular to the cross bracing down the length of the trailer. I attached some 2X4 scrap pieces to the bracing and used those as lifting points where I used a couple of bottle jacks to lift the shell up. All of the rivets around the bottom perimeter were drilled out and any remaining bolts goint through the channel were cut off. Once the shell was up I slid in two 4X4's that extended out past the shell 2 feet on each side.
More to come
Steve
Name:	New pictures to be printed 421.jpg
ID:	22485  Click image for larger version
Name:	New pictures to be printed 114.jpg
Name:	New pictures to be printed 120.jpg
ID:	22487  Click image for larger version
Name:	New pictures to be printed 435.jpg
Cloud 9 is offline   Reply With Quote
Old 06-19-2006, 07:14 AM   #18
Yreka , California
Images: 21
Cloud9, thanks for the pictures. I'll be watching every step of the way. My plan is to watch your progress to get me motivated to redo my 55 FC. I don't think I'll do much until next spring. So you should be well along by the time I go to work on mine. After working for 10 months on the restoration of our Bambi, I need to get some work done around the house. I'd like to repaint my truck also.
Don
Old 08-22-2006, 10:38 PM   #19
Cloud 9's Avatar
Back on track
Alright, I knew would be too busy to post during the summer. But now things are winding down at work and I can get back on track.
After the shell was lifted the frame was pulled out and taken in to be welded. I wanted to do the welding myself but my wife wanted to have a "Professional" do it. Sooo... I took it to someone who came highly recommended and had all new crossmembers and outriggers welded on. I won't go in to the hassles of getting small town businesses to work on any type of schedule. Needless to say after 4 weeks of sitting at his shop the welding is completed and I get the frame back to my work area.
I started painting the frame using Eastwood rust encapsulating paint. Got all of the top and sides that I could reach easily painted so I flip the frame over to finish the job. As I'm doing that one of the new welds breaks! Further inspection of the frame shows partial penetration on almost all of the welds! Welder is called back and finally returns to fix the job after two weeks of angry calls and threats of a trip to small claims court!
So now I'm waiting for a little cooler weather to finish painting. I think I'll probably need more paint too. Two quarts just isn't quite enough.
Any way here are the rest of the pictures I have of the removal of the frame from the shell (It's always nice to have some helpful Rangers to do the heavy lifting ).
Name:	New pictures to be printed 440.jpg
ID:	25066  Click image for larger version
Name:	New pictures to be printed 442.jpg
Name:	Amy swimming lessons 062.jpg
Old 08-22-2006, 10:58 PM   #20
Cloud 9's Avatar
Not all the pictures made it. I guess I'll have to sit down and figure the easiest way to upload pictures.
ID:	25069  Click image for larger version
Name:	New pictures to be printed 444.jpg
Old 08-23-2006, 08:34 AM   #21
Yreka , California
Images: 21
Thanks for the new pictures. In your line of work the summer is probably work, work, work. One thing I've found when loading pictures is when all the pictures don't show up. Click on "manage attachments" again and reload more pictures. Sometimes it seems that it only likes to process three pictures at a time.
Don
Old 08-23-2006, 04:00 PM   #22
Cloud 9's Avatar
Thanks Don,
It does seem to be only taking three at a time. Here are the rest that I meant to post
Steve
Name:	Amy swimming lessons 063.jpg
ID:	25098  Click image for larger version
Name:	New pictures to be printed 445.jpg
Name:	New pictures to be printed 447.jpg
ID:	25100  Click image for larger version
Name:	New pictures to be printed 449.jpg
Name:	New pictures to be printed 450.jpg
ID:	25102  Click image for larger version
Name:	New pictures to be printed 451.jpg
Old 08-24-2006, 06:50 AM   #23
Yreka , California
Images: 21
I started tearing some of the very rotten floor out of my trailer. Guess I should start a new thread on the 55. Sure like the shine of your shell. Do you have any more pictures of the original frame in its original condition?
Don
Old 08-29-2006, 03:08 PM   #24
Cloud 9's Avatar
Don
Here are the other photos I have of the frame as we found it.
Name:	New pictures to be printed 039.jpg
ID:	25348  Click image for larger version
Name:	New pictures to be printed 046.jpg
Name:	New pictures to be printed 048.jpg
ID:	25350  Click image for larger version
Name:	New pictures to be printed 052.jpg
Name:	New pictures to be printed 053.jpg
ID:	25352  Click image for larger version
Name:	New pictures to be printed 055.jpg
Name:	New pictures to be printed 059.jpg
ID:	25354  Click image for larger version
Name:	New pictures to be printed 060.jpg
Old 08-29-2006, 03:23 PM   #25
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Someone got quite creative with the 2x4's. Better than crashing through the floor, I guess.
This obviously needs a fair amount of welding repairs. Might be worthwhile to consider a new frame altogether. You can build it right on top of the old one, using the old one for a template. Then, transfer the running gear over tot he new one and off you go.
I am suggesting a new frame because it seems that the main frame rails are severely weakened by rust.
Uwe
Old 08-30-2006, 03:07 PM   #26
Cloud 9's Avatar
I don't know if I made it clear when I started this thread, but I'm farther along in the process than the pictures depict. I already have the frame repairs done (I kept the main frame rails, they weren't as bad as you might think.) and am in the process of painting it.
I have to catch everyone up on what I've done so far. So here it is in a nutshell:
1. Removed rotten floor and gutted interior
2. Removed lower interior panels and braced shell prior to removal
3. Separated shell from frame
4. Removed frame and replaced all crossmembers and outriggers (these members were replaced with 3" C channel about the same guage as the main frame rails)
5. Removed axle and springs from frame
6. Replaced all lug studs
7. Replacing both brake assemblies (currently in process)
8. Painting frame (using Eastwood rust encapsulating paint) and axle (Rustoleum)
9. I also welded in gray tank supports similar to what Uwe did, but I haven't completed the installation yet.
I'll post pictures of each step I've done where I have photos. (Didn't have a camera with me all of the time.)
Steve
Old 08-30-2006, 03:09 PM   #27
Cloud 9's Avatar
Sorry if I've repeated anything from previous posts.
From the Department of Redundancy Department
Old 08-30-2006, 06:39 PM   #28
Yreka , California
Images: 21
Shell lifting
I'd like to see pictures of your shell lifting. A description of your process would also be appreciated. Great to hear how much progress your making.
Don
Pingbacks are On
Tracing a Wally Byam Club member #. Simplyspent WBCCI Forum 32 08-09-2007 09:55 AM
Vin number for 54 Flying Cloud michael Murphy Title, VIN & Registration 2 01-22-2006 10:21 AM
roof vent size USA 53 FLYING CLOUD wilson russe Roof Vents, Skylights & Fans 0 10-08-2005 11:08 AM
1957 Flying Cloud Parts awaymire Parts Archive 1 06-18-2003 11:51 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
