Old 07-12-2018, 09:06 PM   #1
1965 22' Safari
1952 21' Flying Cloud
Olympia , Washington
52 floor replace
Hi I was given a 52 Flying cloud with a repaired frame and the body sitting next to it.
I want to deck it and replace the body. There are sheets of plywood here for it but something seems a miss.
Is the plywood just as wide as the outriggers? Does it hang over like 1/2 inch? ( The plywood I was left does)
I added some pics.
So how wide should the plywood be?
ID:	316732   Click image for larger version
rlaxton is offline   Reply With Quote
Old 07-12-2018, 11:25 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
There should be a U shaped channel between the top of the plywood and the shell. Is it still attached to the shell? Assuming the channel is there, that would be the 'pattern' for your plywood.
The plywood will go the the ends of the outriggers for the most part. It may vary a little. Where it extends beyond the outriggers is usually on the rounded corners.
If the channel is on the shell don't assume it has retain the original shape after it was removed from the frame. If the person put bracing at the bottom of the shell from side to side in several places, it may measure out correctly.I would consider setting the shell back on the frame with plywood sheets setting on the frame. Then you can check how the channel lines up with the outriggers and scribe the corners.
If that's not feasible take some careful measurements of the shell width and length at the channel and compare to mounting points on the outriggers/frame.
There should be a reinforcing panel at the front and rear (some older models just have it in front). It should be a heavy gauge L shaped steel panel that goes up the skin about 12". It sits in the channel and goes up the inside of the outer skin. It's bolted through the channel to the plywood and frame and riveted to the outside panel. You'll see see a couple horizontal rows of rivets a few inches above the bottom of the shell.
A few photos of what can be seen from the inside and bottom of the shell would help us give you better guidance.
Nice to see another Overlander saved.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-13-2018, 07:20 AM   #3
1966 22' Safari
Fredericksburg , Texas
Looks like a fun project. Harold made some good points. Make sure you have all the frame and outriggers complete. The hold down plate is important. I installed plates on the front and rear since mine was a double and not a twin. Doubles had the side cargo door and not the rear. The plywood on my 55 did have the plywood overhanging the end of the outriggers by 1/2”. Don’t have any idea why unless they wanted a wood cushion at the banana wrap to prevent outrigger punch thru. So, once the frame is complete, plywood first with elevator bolts. Then the 1 1/2” “C”-channel on top of the edge of the plywood held down with elevator bolts near the end of the outriggers thru the C-channel and outrigger. Secure the channel where needed with SS wood screws into the plywood. The belly pan comes up the bottom edge and forms the banana wrap that gets about 1/2” crimped over into the C-channel and pop riveted to the channel. I just split a 4’ wide sheet of 5052 .032 and formed the banana wrap. This way if I have to remove the belly pan in the future I don’t have to disrupt the banana. Good luck, Bubba
Bubba L is online now   Reply With Quote
Old 07-14-2018, 04:21 PM   #4
1965 22' Safari
Thanks for the replies.
Does anyone of pictures of the step area?
Old 07-18-2018, 09:17 AM   #5
toastie's Avatar
1955 22' Safari
Great Lake State , .
Was the shell braced before lift-off.
toastie
toastie is offline   Reply With Quote
To Replace or Not Replace ( dome and fan ) estock Roof Vents, Skylights & Fans 2 05-20-2018 02:42 AM
To Replace or Not to Replace that is the Question Redleger Water Heaters, Filters & Pumps 3 10-15-2016 07:38 PM
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
