Old 06-30-2011, 10:43 PM   #1
1985 34' Sovereign
1958 22' Flying Cloud
1971 31' Sovereign
Zillah , Washington
34' Full Monty (not the funny kind)
My wife just had to have a dinette!! So we pulled home a 1985 34' - whom we have affectionately named Monty - that needs a lot of work (it had a fine crop of very cool mushrooms under the beds). Soooo....now itís completely gutted, rivets removed, and prepared for liftoff. So now to the floor. I have read every post on floor replacements until my eyes have nearly glossed over, and have yet to find an answer to my question. How do I join the sheets of plywood together since the cross members do not allow for a splice underneath? As you may know, the factory at that time thought that OSB was brilliant and used it throughout our trailer with only one seem in the front section. I have not yet removed the floor from the frame, but would like some idea how my new plywood will go back down (yes it will be sealed). Shouldn't the floor be basically one unified sheet? I was of the impression that all seems would be over a cross member so the e-bolts hold the seams down (I think this method would require more seems because of short sheets in order to hit the spacing of the crossmebers just perfect). Can my seams "float" in between the members using a lap joint and a splice strip underneath? That just does not seem strong enough.
ANY help would be GREATLY appreciated.
Landscraper is offline   Reply With Quote
Old 07-01-2011, 05:39 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The spar cross members between the ladder frame are not held at the same heights on my trailers, some are 3/4-inch lower than others to accommodate a backing doubler plate...
Old 07-01-2011, 06:20 AM   #3
Central , Mississippi
You COULD make one big sheet by splicing them like this...
http://www.airforums.com/forums/f36/...tml#post737994
We have about 10,000 miles on this repair with no issues so far...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-01-2011, 08:16 AM   #4
1985 34' Sovereign
1971 31' Sovereign
Zillah , Washington
You are right on the cross members being lower on the 70's trailers, but on the 80's there were no seems. Granted I have not removed the floor, but since they used a "mega" sheet, wouldn't all the cross members be the sameheight?
As far as using a tapered splice joint, I saw your project, and it looked great! However, I have about 8 sheets of plywood (more if there are more seams) to be putting down so a lapjoint may be more practical, and easier to mass produce. But again, can my seem - the one between the sheets - "float", or does it have to land on a crossmember?
Any further thoughts? As this progresses, I will post pics on how we will be succedding or failing with the restoration.
Old 07-01-2011, 08:23 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have only done replacement of small areas. I floated my seams on purpose so I could put a lap piece under the seam. I glued the lap and used screws. It seems pretty darn solid to me. There are places, like under the sofa and in the compartments, where you can use a 3 layer joint, with a lap under and a lap over, so the seam is in a sandwich.
Old 07-01-2011, 10:48 PM   #6
1985 34' Sovereign
1971 31' Sovereign
Zillah , Washington
Does anyone know of complete shell off project on a mid 80's 34' that might be referenced? I have only heard of partial floor replacements, not doing the whole thing at the same time (probably due to the fear of the lift logistics).
Old 07-02-2011, 06:21 PM   #7
I've seen a couple of 31' full monty's here on the 'forum...it's lookin like you may be the first to document a 34'
It's only an extra 10%...
Old 07-03-2011, 12:21 PM   #8
1985 34' Sovereign
1971 31' Sovereign
Zillah , Washington
First one? That is what I was afraid of. We just got back from the Baker City rally for Wally's B-day, and I heard the same sentimate. Still looking for advice on the OSB to plywood conversion from someone who has been there, done that. The wind is calm so my father and I will try to lift off today. Here are two pics of what I call my "daily does of depresion" (the trailer not the toddler). The second pic is of the braces not yet installed. We have bracing front to back, side to side, and crossed. Hope it works.
ID:	133836   Click image for larger version
Old 07-03-2011, 12:43 PM   #9
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Cool! Good luck!
I did my 31' today if you need ideas look at my photos
Darkspeed is offline   Reply With Quote
Old 07-03-2011, 01:03 PM   #10
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
What you have is 1 1/2" of space to break the floor on. This is not a problem in house floors because everything breaks 16" on center and you can nail the floor down at the break with a lot of nails.
The plywood should break fine, giving you 3/4" on each side to attach the plywood. The 24" between the cross-members will put more stress on the joint. This makes it more difficult to attach the plywood at the break. I'd think along the lines of a lot of smaller screws or (flat headed) bolts along the seams.
I'd be cautious and not assume that the cross members are exactly 24" on center.. after all, it is an Airstream. One cross-member off can throw the whole thing out of whack.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 07-03-2011, 01:12 PM   #11
1985 34' Sovereign
1971 31' Sovereign
Zillah , Washington
Thanks DanielB,
I agree that the 1.5" is not much to attach to. Also, if one was to incorperate a lapjoint, that would ineffect shorten the usable width to less than 48". Once the floor is off I will probably throw the dimentions into CAD for the most effecient use of the wood. Is it possible to add a wider plate on top of the cross member to aid in the fastening? I supoose one could always add a member or two as well.
Old 07-03-2011, 03:30 PM   #12
JimGolden's Avatar
1977 31' Excella 500
Build a new frame. Then you can put the cross members where you like. Use L extrusions atop the cross embers on both sides and you're good to go. I'd change out the rubber axles too and go to swingarm type suspension.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 07-05-2011, 09:42 PM   #13
1985 34' Sovereign
1971 31' Sovereign
Zillah , Washington
Thumbs up
THIS MAY BE A FIRST (at least I have yet to hear of another 34' shell off)!!!!!
As you can see the shell is off and on the ground and most of the c-channel is loose and comming off.
Some things other people may be intereed in knowing. The C-channel does indeed fully wrap the front and back of the trailer. Not just the sides like in the earlier models. The floor is 5/8 OSB (my 3/4" will be returned tomorrow).
So far - with only looking in the front portion - I have found only one mouse carcus and one bee's nest. The count will surely increase when we get the rest removed.
My plan is:
1) get the correct plywood
2) coat all sides with penetraiting sealer (similar to rot doc)
3) Flip the frame
4) Prep and POR 15 the frame (possibly add additional cross members)
5) check tanks and running gear
6) start worrying about how to insulate reasemble the $*!@!!
More to follow. But please jump in and give your $.02 worth. Any sugestions or comments are appreciated.
By the way, if any of you has a spare front battery box that is in your way, I will be glad to take it off your hands. I am adding an extra battery.
ID:	134074   Click image for larger version
ID:	134076   Click image for larger version
Old 07-05-2011, 10:18 PM   #14
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Was good seeing you Saturday, sorry things were so crazy. Cool to see lift off. Make sure to get that shell tied down good to the ground, just in case we get some of those winds coming through again. Awesome start!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
What kind of wood was used in 1967 Safari bamurphree Upholstery, Blinds, Walls & Interior Finishes 15 10-17-2013 02:10 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 06:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 10:59 AM
Dinnerware for full timing Khulse On The Road... 45 03-29-2011 07:52 PM
Full timing and your primary residence Khulse Full-Timing, Winter Living & Workamping 6 02-01-2011 07:38 PM
