Old 10-11-2009, 07:45 PM   #15
1980 31' Excella II
Madison , Wisconsin
Aage,
I was able to get the window out. The glass seems to be in good shape, but everything between the two panes is falling apart. I found another thread where someone had a similar issue and they removed the inside pane of glass. Any thoughts on doing that? I just can't put all this work into this trailer and leave windows that look terrible in it.
excella80 is offline   Reply With Quote
Old 10-11-2009, 08:14 PM   #16
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
Originally Posted by excella80 View Post
Brian,
Your cracks sound like they are in about the same place as mine. The cracks allowed the frame rail to twist out and caused all the out riggers to sag a lot. Can you tell me more about the reinforcement plate. I had a friend helping me get the frame straightened out and welded back together. He did not want to add too much more steal to the frame, in fear of adding too much weight or making it too stiff. But you are making me think I should do more be fore reuniting the shell and the frame.
http://service.airstream.com/files/l...14bd730003.pdf
Take a look at the link above. This is right off Airstream's website. I know it's for pre-80's, but it may also work for your frame. I don't see many differences from your pictures, but I would ask the experts for their opinion, also. Send Drag'nwagon a pm. He had some work done on his frame and he gave me a few pointers on repairing/reinforcing mine. I'm sure that he would share with you as well.
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 05-27-2010, 02:25 AM   #17
qc1500's Avatar
rozenburg , netherlands
Amzaing, i will be in this soon. Have to remove the shell of our 74 sovereign. Is it possible to leave the floor in?
qc1500 is offline   Reply With Quote
Old 05-27-2010, 05:56 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
No. The floor is attached to the frame, and not really attached to the trailer, except for some little screws in the floor channel. The full attachment is the outriggers have bolts through the ends, through the floor, and into the bows (upright aluminum frame parts for the shell). There are also many self-tapping screws that hold the floor and frame together. If you really, really wanted to, you could probably support the trailer and floor, and cut out each frame section, pull it out, replace it, and weld it back to everything, then repeat on the other side. That's a lot or work, and magnifies the possibility of a fire when you start welding near that 35 year old plywood in the floor.
1980 Airstream Landyacht! Original Condition! Fun Fun eBay Watch Airstreams on eBay 0 04-13-2009 08:10 PM
Towing an empty 31' shell bugz42 Towing, Tow Vehicles & Hitches 16 04-07-2009 01:42 PM
How can the new 1/2 tons tow 10K?? mandolindave Tow Vehicles 35 10-25-2007 06:49 PM
Soon to be Newbie with Tons of Questions eharv Member Introductions 9 09-26-2006 08:28 PM
