Old 08-11-2011, 04:34 PM   #15
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Just a thought, but I am replacing some of the flooring in my 73 and came by some fire rated epoxy plywood. When you think of the possibility of the occasional water leak (well we all know old Airstreams never leak ) this stuff may be a good investment. I have had some large scrap pieces I left outside, directly on the ground and often flooded (when it rains in TX) and not so much as a hint of de-lamination or rot. Be nice to just do this task one time.
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 08-13-2011, 02:56 PM   #16
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Man, I'd be all over that one. If you've got it, or can get it affordably. Do it!
Phrunes is offline   Reply With Quote
Old 08-14-2011, 12:59 AM   #17
P&K
P&K's Avatar
1970 29' Ambassador
Images: 37
Ok. I know I'm being a total slacker with the pics, but I promise they are coming. We have the shell off, trailer out, floor off, and belly pan off. I will order replacement outriggers tomorrow. The trailer is sitting in my dads shop waiting to be worked on this week.
Any thoughts on strengthening the frame? The frame appears to be bent (wavy up and down, not side to side), but it's hard to judge since the whole thing is floppy without the plywood or shell attached. The main frame rails are cracked and sagging about where the rear bath starts, so they will for sure be getting the treatment. The welders suggested "boxing in the frame" like they do on old cars, but I realize this is not a car and that different principals apply. It seems to me that if the suspension is doing its job well that a stiff frame would not be a bad thing.
I'm also looking for suggestions on where to get some axles around Austin or Dallas. I would like to pick them up to avoid shipping charges.
I'm feeling stuck on the fresh water tank. The tank that is in there is original. It doesn't smell or look funny. It feels pliable and doesn't appear to be cracked, but how long can that puppy last? It just feels like while I'm in here I should replace it. Again, direct replacement is available, but pricey compared to similar square tanks. I doubt we will be doing much boondocking. I guess building a rectangular tank into a cabinet or piece of furniture might be a good way to go.
I'm liking the sound of this epoxy plywood. I'll check it out.
P&K is offline   Reply With Quote
Old 08-14-2011, 05:34 AM   #18
r carl's Avatar
Lin , Ne
I would build a new frame. Use at minumum 2x6x11ga rectangle tube.
Old 08-14-2011, 07:45 AM   #19
P&K
P&K's Avatar
1970 29' Ambassador
Images: 37
I'm sure a new frame would be superior, but is it really necessary? Material cost is going to be pretty big compared to just patching it. It seems to me that as much as the frame relies on the floor and shell for strength, buiding a new frame might be overkill. The only real frame rot is on the very rear cross member and the outriggers.
Old 08-14-2011, 08:04 AM   #20
Tool Hoarder
West , California
You can "box" in the channel like I have to strenghten weak areas of the frame
ID:	137520   Click image for larger version
marzboy is offline   Reply With Quote
Old 08-14-2011, 08:15 AM   #21
P&K
P&K's Avatar
1970 29' Ambassador
Images: 37
Pretty sure. That sucker has got to be strong now. It seems to me that this is the way to go.
Removing 1" plywood under fresh tank bennyg Belly Pans & Banana Wraps 0 06-12-2011 02:50 PM
Floor channel size when installing 3/4" plywood? surfpod Repairing/Replacing Floor &/or Frame 8 05-03-2011 12:25 PM
Plywood or Advantech? COACHJEFF Repairing/Replacing Floor &/or Frame 27 04-05-2011 08:48 AM
More than u wanted to know about plywood ! BabyBoomers Repairing/Replacing Floor &/or Frame 1 04-02-2011 01:36 PM
Aluminum Trim for Plywood Walls Motochi Upholstery, Blinds, Walls & Interior Finishes 7 02-06-2011 09:33 AM
