Old 09-27-2003, 06:07 AM   #1
michael foster
Profile:
Post 1973 airstream tradewind questions
Hello we are interested in purchasing a 1973 25 foot airstream tradewind could anyone help us by telling us exactly how the floor to this model is constructed? also would a british 2.5 litre tdi diesel landrover discovery tow it if we fitted uprated suspension?
michael foster is offline   Reply With Quote
Old 09-27-2003, 08:26 AM   #2
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Tradewind Floor
Michael,
The floor is plywood. There is a quite lengthy thread here of some members in the process of replacing their floors. Check their running "Docupost":
http://www.airforums.com/forum...&threadid=6554
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 09-27-2003, 09:20 AM   #3
drboyd
drboyd's Avatar
Profile:
I have a 1978 Trade Wind that I tow with a 2001 Chevrolet Tahoe. Your trailer will weigh roughly 4500 pounds and have a tongue weight of about 600 pounds,
My vehicle has a 5.3 L gas engine with no turbo, and it's adequate, but certainly not overpowered. I would think you would be in a very high turbo boost pressure situation for long periods of time, putting serious stress on the engine.
Perhaps there's more information on line or at a dealer about your vehicle....
Don
Old 09-27-2003, 10:35 AM   #4
1stimer
Profile:
Smile Questions about 1969 Ambassador 29ft
I wish I would have found this forum before we bought. We have always wanted an Airstream and we are handy at fixing things, don't have alot of money (3 college age kids) so we found what we thought was a bargain 1969 Ambassador 29ft. for $3500. Its a little longer than what we need. My husband wanted to take on jobs around the country instead of motels and go on vacations. We have so many questions about fixing it up we don't know where to start.
We are looking for a vehicle to pull it .... Checked out the poll on vehicles I got the impression Chev Suburban, Chev 3/4 ton, or Ford 350 are the most popular choices?
Can someone tell me how much this thing weighs?
We think the axles are bad and maybe rear separation? Got this bit of info from the Polishing Guru in CA. What kind of expense and trouble are these going to be to fix????
The underneath is completely enclosed do we take it off?There is some rust on the exposed frame.
Did we make a huge financial mistake (we can't count that will enjoy fixing it)???
Appreciate any input you may have would be great. I really want to fix it up and use it for years to come we think it is the coolest.
Southeast Kansas 1stimers for a trailer let alone a big silver Twinkie
1stimer is offline   Reply With Quote
Old 09-27-2003, 12:27 PM   #5
Leipper
Profile:
I think a '69 Ambassador for $3500 is probably an OK deal if it can be hooked up and run down the road safely.
69 is a bit early for some of the frame problems common in the mid 70's models, I think
For rear end sag, sit on the rear bumper and see if the shell goes down with the bumper or is loose.
For frame problems, look for creases and such in the skin near the axles.
Complete axle replacements can run about $2000 at Andy's (inland RV is the dealer for Airstream axles in the US) or you can get Dexter equivalent axles for maybe half that if you know a good axle place.
There is a tech note for reinforcements to handle the rear end sag, if any - I don't know the cost but I don't think it is too bad.
If frame problems are not too bad, there is a reinforcing plate available to handle that.
The biggest problem is likely to be floor rot or severe frame problems, But this should have been detected before purchase.
That trailer in good shape could be worth $5k to $10k so a bit of repair, if necessary, could be worthwhile.
Bryan
Leipper is offline   Reply With Quote
Old 09-27-2003, 03:37 PM   #6
drboyd
drboyd's Avatar
Profile:
1sttimer, here's your weight.
...and you did good on it - not to worry! Don't go nuts fixing things that aren't broke (like I am!) and just enjoy it!
Don
Old 09-28-2003, 06:19 AM   #7
1stimer
Profile:
Where can I find tech note on reinforcements
Thanks for the quick responses.
Where can I find the tech note for rear end reinforcements?
and a reinforcing plate?
1stimer
Old 10-13-2003, 12:01 PM   #8
vegas73globetrotter
vegas73globetrotter's Avatar
Profile:
Hello Michael,
I have a 21 foot Airstream that was about 4500lbs that we towed with an '89 Range Rover, we towed it 1200 miles from Washington State to Las Vegas, it towed it just fine. The Rover also has bad suspension. If the vehicle is newer the suspension may be fine just stock.
Best 4x4xFar.
Jesse
vegas73globetrotter is offline   Reply With Quote
Old 10-13-2003, 09:21 PM   #9
gerbermania
gerbermania's Avatar
Profile:
Hello 1stimer,
Here is a link to a thread discussing reinforcing plates to support a sagging rear end: http://www.airforums.com/forum...eferrerid=1032
Here is a link to a website containing Airstream Service Bulletin #146 which describes a method to bolt the frame back up to the shell: http://www.tompatterson.com/VAC/Bull...Separation.pdf
I myself have had Inland RV replace my axles/brakes/suspension to ensure that my running gear is balanced in good shape. Andy of InlandRV is extremely knowledgeable.
I have also had my frame re-welded in key support areas at the rear, where my frame was so corroded that I could see pinholes through it.
In addition to remedying a shell separation, many of us have replaced and/or reinforced sections of the plywood subflooring.
Hope it helps,
Christopher
gerbermania is offline   Reply With Quote
Old 10-14-2003, 08:44 AM   #10
duckrunner
duckrunner's Avatar
Profile:
First post to this forum--I too can't believe I hadn't seen this before I bought. I am remodeling a 1967 31' Sovereign, and I towed the thing back to Colorado from Alexandria, Lousiana with a Nissan XE 4x4 pickup. I stayed in 4th the whole trip, but made it at 10 mpg, traveling 60-65 mph the whole way (except up a few hills ). If you buy a smaller tow vehicle, just make sure not to use your overdrive, or you'll leave it behind you...
JP
Jimmy D. Pippin
1967 Sovereign 31'
"Do or do not; there is no try."
--Yoda
duckrunner is offline   Reply With Quote
'78 Tradewind labeled fuse box pics & questions BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 20 06-15-2005 06:33 PM
1973 27 ft airstream rear bath LA008 Plumbing - Systems & Fixtures 8 10-05-2003 08:18 PM
New Owner! 71 Airstream TradeWind Davydd 1970-76 Tradewind 11 08-10-2003 10:03 PM
Help - new Airstream questions Elaine and Bohdan General Repair Forum 4 04-23-2003 09:36 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
