Old 02-19-2018, 08:49 AM   #141
1970 29' Ambassador
Santa Rosa , California
1970 New to Us Ambassador reality check
Hi Kay,
Thanks, but no need to go through that trouble. I grew up in the Green Bay area, so I know what you are talking about! Stay inside with that puppy and the Olympics :-)
My current plan (and maybe the way these were built anyway) is to connect the belly pan in the areas around the tank box and probably have some seams in which both the tank box and belly pan overlap. Our climate is mild enough that even if the normal method is to go over both the bottom of the tank box, there would be no gain by doing that here. What remains to be seen is how I will handle the belly pan at the rear. Colorado David gave a great description of how the belly pan extends to the rear bumper. I still have to decide if I will do the same on this, or treat the back bumper and slinky storage as a separate "unit". For sure, there will be drain holes in either approach.
I will insulate inside of the tank box, and eventually all of the underside of the floor. For now, though, it is probably best if I start focusing on rebuilding. As I have learned from remodeling our houses, demo is fun and feels super productive because so much happens so quickly. It always takes me more than 10 times as long to build it back up...
Feel better, Kay!
David
2002sheds is offline   Reply With Quote
Old 02-22-2018, 03:38 PM   #142
1970 29' Ambassador
Hi All,
It has been a few days. Lots of remodeling at our house, so little time to make progress. I did, however manage to squeeze in a trip to a local metal scrap yard and pick up replacement angle iron for the braces for the tank box (one of the old ones rusted in half and the other was bent so far it twisted the bottom of the frame slightly).
I also grabbed an aluminum "Construction Ahead" sign that will make a great tank box bottom (not to mention a surprise to the next owner that gets that far in dis-assembly
I hope to get back at the AS in earnest soon.
Stay warm out there!
David
Old 02-22-2018, 07:15 PM   #143
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Scrap aluminum road signs do make good heavy aluminum sheeting for this or that on our Airstreams. My Overlander had one used as a platform for a "lock box" under the bed. I was quite surprised to find a road sign painted on the other side. I was even more surprised to find a floor rot hole under the sign. Oh well.
Colorado David
Name:	1710 Floor Patch Sign (Small).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 02-24-2018, 03:48 PM   #144
1970 29' Ambassador
Hi All,
As I get closer to putting the plywood back in and repair the rusted tank box, its supports and the rear body plate, I am considering a non-original solution. Namely, providing a little gap between the rear shell and the slinky storage box.
I need to rebuild everything except for the lid anyway, and it seems like a super obvious solution -- that is, have as little aluminum as possible that is horizontal...
Currently, a piece of aluminum is part of the "sandwich" which includes the plywood, U channel and rear body plate. Rain will run down the back of the AS and hit that seam. Some of it eventually is going to make it inward. Why keep that connection?
My plan is to build the storage box sides and bottom (probably of steel mesh) and hang the box between the bumper supports.
What would be the strengths or drawbacks (besides a slight amount of capacity lost) of this configuration?
David
Old 02-24-2018, 06:39 PM   #145
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I plan on doing the exact same thing. I will have about an inch of gap between the rear bumper storage compartment lid and the body of the trailer. I will run some sheet aluminum about two inches below the subfloor. I want rainwater to drain down into the rear compartment where I will have some drain holes in the belly pan to let it drip out.
I am tentatively planning on reversing the bumper compartment lid so it opens front to rear, instead of from the rear. This will give me more access and visibility to the waste tank drain manifold and dump valves. My old Trade Wind was built this way.
Some folks make flashing vertical with the body and then bend it outward to the bumper compartment. The idea is to never let rainwater ingress to the subfloor rear edge.
Colorado David
WBCCI #8607
VAC Region 11
Old 02-24-2018, 07:16 PM   #146
1970 29' Ambassador
Hi David,
I think I understand. How would water drain into the belly pan if you have a gap between the body and the bumper? The hinge?
So it sounds as if you will eliminate that one piece of aluminum that is sandwiched in with the rest of that stuff but goes straight out to the hinge for the slinky storage... is that correct?
David
Old 02-24-2018, 07:37 PM   #147
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The gap is only on the top of the bumper compartment area. I don't need a gap in the belly pan. Imagine about a 1" gap right below the rear storage compartment where that infamous aluminum sheet used to be.
I'll try to remember to take a picture tomorrow of how it might look on my trailer.
Colorado David
WBCCI #8607
VAC Region 11
Old 02-25-2018, 08:54 AM   #148
1970 29' Ambassador
Hi David,
Thanks. I understand where the gap is/will be, but I should have been more clear in my question: If that piece of aluminum that goes from beneath the rear access compartment door over to the slinky storage door is not part of the structure, how would water get into the belly pan (you had mentioned drilling holes to let the water drain from the belly pan)? Wouldn't the water now run down the back of the Airstream and drip off of the outside ?
I'm sure I am missing something...
David
Old 02-25-2018, 06:16 PM   #149
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm not planning on putting that infamous piece of aluminum back on the trailer. If I leave it off, there will be a gap. Rainwater will run off the rear of the body and fall into the gap instead of hitting that piece of aluminum. The rainwater will splash on to the belly pan aluminum riveted to the bottom frame rails and cross member. I will drill drain holes so most of it will drain out.
A picture is worth a thousand words.
David
Name:	1802 Bumper Gap 2 (Small).JPG
WBCCI #8607
VAC Region 11
Old 02-25-2018, 06:25 PM   #150
1970 29' Ambassador
Hi David,
Great -- thanks! I see that the storage compartment door hinge is reversed. I am assuming that it is not yet attached. How will you do that? i will probably go the same route.
David
Old 02-25-2018, 06:43 PM   #151
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My rear bumper storage compartment lid has a spring loaded hinge to make it easier to open. I don't need this "assist". I'm not that feeble yet.
That hinge is attached to a piece of steel flat stock about 1/4" thick by 1" wide. It is a stout piece, you can see it in the picture. That piece of flat stock is bolted to the frame rails. I will likely purchase a new standard piano hinge for the bumper lid. Easier and adequate.
Colorado David
WBCCI #8607
VAC Region 11
Old 02-25-2018, 11:30 PM   #152
1970 25' Caravanner
Incline Village , Nevada
another solution for bumper box water build up
David. Not what you are thinking but an alternative. Can't take credit for the idea as found it on an older forum thread. I believe it will work out nicely.
http://www.airforums.com/forums/f7/7...ml#post2068447
Jeremy9107 is offline   Reply With Quote
Old 02-26-2018, 02:16 PM   #153
1970 29' Ambassador
Hi Jeremy,
I like it... flashing was the first thing I thought of, but I was pretty unsure of how to do it correctly -- and kind of still am. Since there is no belly pan there currently (it was torn off somewhere along the way), I think I have been thrown off as to how anything but a gap between the body and that storage box will minimize water intrusion...
In your example, where does water flow? How is it ultimately "steered"?
David
Old 02-26-2018, 11:56 PM   #154
1970 25' Caravanner
Took many attempts to get the flashing cut and bent correctly but mostly because had a tough time understanding simple directions from the designer.
The flashing is riveted on the frame horizontally, but we put Protecto flashing tape between the steel frame and it to stop corrosion. It then takes a 90 degree bend vertically and tucks behind the outer skin. This sandwiches it between the rear holding plate and outer skin (the rear holding plate also has the flashing tape on it).
So water will run down the outer skin and hit that flashing. The vertical bend is 1" high, so water level on bumper box would have to get that high to have a chance of entering the trailer, which won't happen cause it will just roll off the sides. That is our vision atleast. No seams in the flashing, so no caulking required.
This design is meant to stop intrusion to the rear of the trailer and subfloor so floor does not rot and sag. It will not be a seal from water intrusion into the bumper box.
Another Reality Check! RLS Hitches, Couplers & Balls 24 09-23-2009 11:38 PM
Bathroom ABS repair-Reality check SilverHoot Upholstery, Blinds, Walls & Interior Finishes 1 07-21-2009 10:02 PM
POR15 reality check truckasaurus Repairing/Replacing Floor &/or Frame 20 06-07-2009 08:19 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
