08-04-2011, 10:24 AM
#121
1967 24' Tradewind
Greenville
, South Carolina
Originally Posted by Top
You know, the biscuit joiner is something I didn't use in the rear half of Abby but I definitely will for the front half. I would have done it if I had the tool. I looked at it and chose not to buy it at the time. It is even a better idea to use it in 50s and 60s trailers because where the sheets butt up to each other isn't supported with a piece of plywood glued to the joining sheets from underneath like the 69 and up trailers. Now with a 62GT in my back yard, I'm kinda kicking myself for not buying it.
My 67 had the sheets joined by a sheet that was glued and screwed from below. The frame was designed to accommodate the extra thickness at those joints.
08-04-2011, 11:48 AM
#122
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Well I stand corrected! Thanks Hoot. Guess I need to tear apart more trailers. In due time.
Lance
08-05-2011, 08:17 AM
#123
Tool Hoarder
West
Mine is too, I just used the biscuits for extra stability.
08-05-2011, 10:22 AM
#124
1975 Argosy 26
1963 24' Tradewind
Seattle
What do you mean by "pitching?". Is it being tilted over to one side? Are the bolts tighter on one side vs the other due to the pitch defect?
08-05-2011, 09:25 PM
#125
1958 22' Flying Cloud
Folsom
marzboy,
I recieved my bal jacks, which came with no instructions, I'm not that smart, so did you just drill holes and mash the bolts in, or weld them to the frame? Seems like bolting them thru the belly pan would be the better way to go. Any advice would be appreciated.
Matt
08-05-2011, 09:29 PM
#126
Folsom
Nevermind, I can see in your latest pictures you just drilled a hole and ratcheted the bolts in. They looked like they could thread themselves in there.
08-06-2011, 10:29 AM
#127
Tool Hoarder
West
It is actually about 1/2" to the street side off center behind the rear tire. I think I know what it is though. Just means more work!!
08-06-2011, 10:31 AM
#128
Tool Hoarder
West
Its pretty straight forward. Just make sure not to drill the holes too big or the threads wont tap snug. I actually snapped a couple bolts because they were too tight. You will love them!!
08-06-2011, 10:55 AM
#129
Folsom
I got one on last night. They are amazing! 3 more to go today. I think I will back the bolts out today that I put on last night and use some locktight just as a little extra grab.
08-06-2011, 11:16 AM
#130
Tool Hoarder
West
Glad to hear! I have to remove them to re skin my belly pan so I just have them on dry fit.
08-07-2011, 08:39 AM
#131
1967 24' Tradewind
Greenville
, South Carolina
Matt,
Did you buy yours at Inland also? I'm considering getting some too.
08-08-2011, 12:04 AM
#132
Folsom
I did get them there. I think it's the best price. Shipping was 50.00ish.
I'm really impressed with them. One of the best things I've gotten so far.
08-11-2011, 10:06 AM
#133
Tool Hoarder
West
Here are a couple more shots of my subfloor with the elevator bolts covered and subfloor insulation.
08-11-2011, 12:39 PM
#134
Always learning
1972 29' Ambassador
Central
Ahhh! The floor laid is a floor played! Nice. Keep it up! You'll be done in no time!
Lance
08-12-2011, 09:51 AM
#135
Tool Hoarder
West
Thanks Top! I am anxious to get to the rest of it this weekend!
08-16-2011, 09:02 AM
#136
Tool Hoarder
West
Got a bit more insulation done yesterday, mind numbing tedious labor. Hope to have the rest of it done today along with bolting down the U channel. Oh and I got my new tires in anticipation of getting my axles in a week!! Here are a couple pics complete with obligatory beer shot.
08-24-2011, 08:53 AM
#137
Tool Hoarder
West
Got my axles today, finally! Took over two month but I finally got em. Removed the old axles, pretty hard core. I must have used every cutting tool I own. The bolts were pretty much frozen so I just cut em! I also cleaned up corrosion coated primed and painted the "c" channel. Lots of busy work my garage is filling up with parts just need a little more time to put the beast together!
08-25-2011, 05:27 AM
#138
Always learning
1972 29' Ambassador
Central
Nice axles. You went with the super HD discs I see. Nice paint work on the C/U/J channel. It'll last about another 50 years or so.
Lance
08-25-2011, 07:29 AM
#139
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
what did you use to prime/paint the u-channels?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
08-25-2011, 07:43 AM
#140
Always learning
1972 29' Ambassador
Central
I believe he is using this stuff from SkyGeek.com
Lance
