Old 08-20-2012, 11:25 PM   #463
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Shut the front door! It's back together! Lookin good.
ddstech is offline   Reply With Quote
Old 08-21-2012, 12:16 AM   #464
Ottawa , ON
Originally Posted by marzboy View Post
Lunadog
I actually borrowed the idea from Aarowood.
I think you'll find that kip is Aerowood. But I could be wrong...
Old 08-21-2012, 05:54 AM   #465
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Very nice!
desertair27 is offline   Reply With Quote
Old 08-21-2012, 08:13 AM   #466
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Kip / Aerowood, same same
Old 08-21-2012, 10:36 AM   #467
Tool Hoarder
West , California
Thanks guys, it was more time consuming than hard. Off to Homo Depo for a few parts. I need to clean up my dead bolt and front door lock. BTW does anyone know how to remove the lock cylinders? I need to replace and re key.
ps sorry about the typo Kip aka Aerowood. Thanks for the great step by step on the door. I tried to take out the door pin but its was a bit too out of my ability.
marzboy is offline   Reply With Quote
Old 08-21-2012, 10:46 AM   #468
salzburg , salzburg
great job on the door, this is the next part of my project, i'm going to follow Kips lead fairly closely although my door pins are o'k with very little play (one thing on this trailer that's not broke!!) but i will be putting a new K.TZ lock in and reinforcing with a couple of stringers, did you re sheet the whole door just with one piece of Ally?
mrgreen is offline   Reply With Quote
Old 08-21-2012, 01:39 PM   #469
Tool Hoarder
West , California
Thank you, it was a lot of work but it came out nice. If I were you I wouldnt remove the main door pin if you dont have to. It is a pretty big PITA. I did replace the front with a new sheet of 2024 t3 I plan to replace the rear with a whole piece of 5052. Post some pics of your door!
Old 08-21-2012, 10:16 PM   #470
Tool Hoarder
West , California
Got the other side done. I insulated with two layers of Prodex and skinned the inside with 5052 .032. Now I hope to hang the door this weekend. I ordered new door hardwear should be here later this week.
ID:	166406   Click image for larger version
ID:	166408   Click image for larger version
Old 08-29-2012, 10:52 AM   #471
salzburg , salzburg
wow looking good, i will post pics of mine but not really much to see outside of the frame!!, i'm replacing my skin due to corrossion in the bottonm half and a new trimark door latch going in, so far i've cleaned up the frame, removed enough material from the door frame to mount the new lockset in their and have it reach through and lock!!, the question i have is when i look at Kips he seems to have two stringers, one is definately riveted in and the other is either floating or welded,, what have you done? i'm thinking of welding in two stringers above and below the lockset to give it strength in that area, tomorrow i'm pickiing up my aluminium for the door which is M3? as far as i can make out it's pretty firm stuff so will probably need to roll it a bit for it to hold a nice shape and it's meant to polish well?? no idea i will find out tomorrowClick image for larger version
Old 08-29-2012, 08:49 PM   #472
Tool Hoarder
West , California
I like the idea of welding to pieces of metal to the door frame. I didn't do it because I just wanted my door frame back from the welder. I didn't have the bargman l100 latch like a lot of the mid 60s trailers. I have a Westlock dead bolt and a Weisner door knob. I had to go to an old school locksmith to find the guts for my hardware. Your outer skin for the door is 2024 t3 aluminum. I went with the .032 thickness. It is tempered an should pleanty ridged. I didn't have to roll it to get a good shape. I just clamped drilled clecoed and buck riveted. I will probably hang the door in a couple weeks. Any one with any pointers on how to properly hang a door please chime in!
Old 08-30-2012, 02:50 PM   #473
colberjs's Avatar
1964 30' Sovereign
Porum , Oklahoma
34 pages and half a day later I finally read the whole thread. Excellent work and it makes me feel like I am really cutting corners by attempting a shell-on restoration on mine. Unfortunately I don't have the space, time, or other resources to go to the great lengths that you have. I wish I could. That AS will probably last you the rest of your life and probably your kids lives.
Great work!!!
colberjs is offline   Reply With Quote
Old 08-31-2012, 08:24 AM   #474
Tool Hoarder
West , California
Great work!!!
Thank you! I just went over your thread and you are doing good. Just dont get too hung up on the whole project. I sat down and made a list of micro projects. Then I seperated the tasks by inportance and little projects that I could do when funds were low. Once I had a decent plan of attack I dug in. I think the big relief was when I got the shell back down on the frame. Its an Elephant sandwich take small bites.
Old 09-12-2012, 12:09 AM   #475
Tool Hoarder
West , California
Finally got the door back on today. It was a little tough but I got thru it. Big thanks to Kenny P for bucking those rivets with me.
Name:	2012-09-11 12.44.16.jpg
ID:	168084   Click image for larger version
Name:	2012-09-11 15.30.09.jpg
Name:	2012-09-11 17.22.41.jpg
Old 10-08-2012, 09:32 PM   #476
Tool Hoarder
West , California
Minor set back # 1007 door frame broke again! Arrrrgggggg!! So I tore the door down to the frame again, had my welder repair the crack again. There must have been some stress on the frame that cracked it. So this time after I got the frame back I set it in the door way braced it with clamps and heated it with my blow torch. Then very carefully tighten the clamps til the door frame mached the curve of the trailer. I finished Bucking the outer skin to the frame today. While I was waiting for the frame to be welded I started on the inner skins so that I can figure out the outlets and switches.
ID:	169854   Click image for larger version
ID:	169856   Click image for larger version
1965, 1965 sovereign, buck rivet, frame repair, olympic rivet, shell off
'63 Overlander Rehab.... tgregory13 1960 - 1964 Overlander 43 12-09-2010 09:40 AM
Need Rehab Buddy for Hubby/Anywhere in US! goobygirl General Repair Forum 6 09-17-2009 12:47 AM
Getting Assistance in Rehab? goobygirl General Interior Topics 9 09-15-2009 11:22 PM
First Use Rehab Merry Stahel General Interior Topics 16 11-18-2006 07:41 PM
6 metre interior rehab? Janet H All Argosy Trailers 2 09-24-2003 04:17 PM
