Old 07-29-2012, 11:23 AM   #449
Tool Hoarder
West , California
@ Tim the only trick I have for you is build a jig to match the curve of the trailers inner door frame. I wll take a couple pics of it when I get home and post them. Also find a really good welder that can tig weld aluminum.
Don't feel too bad, not very many can follow kip. When I read his threads I feel like a cave man working with sticks and stones.
marzboy is offline   Reply With Quote
Old 07-29-2012, 11:32 AM   #450
Tool Hoarder
West , California
Originally Posted by SeasideSteph
Funny how the cracks are right where the rivets mount, and why was it riveted in such a weak spot?? Removed inside sheets and insulation, dreading removing the door off the hinge but the hinge needs work anyway. My welder told me I'd need to remove the outer skin too, if I didn't want it marred in the process. Not looking forward to investing in the Olympic rivet shaver, but I suppose I'll need it in the inventory anyway.
My cracks are in the same spots the design is crap. You will need to have your trailer with your welder as they are working on the frame to get the curve of the door right. Your frame is cast aluminum which is very difficult to weld. It absorbs lots of moisture and can produce crappy weak welds. If you can't move the trailer you can make a jig out of scrap 2x4 like I have. I will post some detailed pics of the jig when I get home tomorrow. Also I have been told that more curve in the frame is better than not enough (this will make more sense when you start welding)
You are going to have to reskin the door with new aluminum because the rivet holes won't match up. Its not too expensive like around $250. Check out kips thread on door repair (arrowood)
Old 07-29-2012, 03:31 PM   #451
1963 30' Sovereign
Vancouver , British Columbia
marzboy - if we ever get to an Airstream gathering at the same time and place as you, boy do we owe you a few nice beverages! We are definitely following in your footsteps:
Ronco tanks - check
Sky Geeks for chemicals - check
Spare Tire Holder - check
Levelling Jacks - check
Question on installing the spare tire holder - Did you install your spare tire holder as I have roughed out in the attached photo? (Realize that some of the extra battery supports will have to go).
Name:	29-07-2012 2-28-31 PM_0002.JPG
lunadog is offline   Reply With Quote
Old 07-30-2012, 05:34 PM   #452
Tool Hoarder
West , California
Ronco tanks - check
Lunadog
That is exactly where I placed mine. It is pretty nice I must say. I actually borrowed the idea from Aarowood. It helps that you dont have the subfloor in yet. I would make a template of the inner area that will be above (under the subfloor) the tire between the frame rails. I glued 1/4 " foam insulation board and then covered it with aluminum. Then I seales on all sides with Trempro.
Would love to see it in person someday!
Old 07-30-2012, 10:12 PM   #453
1963 30' Sovereign
Thanks for this. What Tempro product did you use to seal the wheel well cavity; those guys make a raft of sealants and barrier coats? Maybe we'll see you out-and-about next year; we're hoping to be on-the-road to celebrate the 50th anniversary of out trailer.
Old 07-31-2012, 10:17 AM   #454
Tool Hoarder
West , California
I used this to seal. If you get to Southern California I will buy you a drink! Good luck on your goal!
Old 07-31-2012, 02:48 PM   #455
1963 30' Sovereign
Thanks for the details. Everyone gets to Southern California; suggest you keep ice and margarita mix on hand. Thanks and warm regards.
Old 08-01-2012, 10:49 AM   #456
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Originally Posted by SeasideSteph View Post
Attachment 164013
The shaver and the cyclo were definitely two purchases in this project where I had the rare experience of not being excited to buy a tool. It was frustrating to spend that much, but the shaver has been invaluable. It is simple, well-constructed, and long lasting. Plus, you always end up replacing 10x as many rivets as you expect.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 08-01-2012, 10:51 AM   #457
1959 17' Pacer
Party at Javier's?
I'm down. Just tell me when. I'll load up the fridge with drinks and bring the trailer.
And you think I'm joking.
- Peter (and Marie)
TAC CA-15
Old 08-02-2012, 05:44 AM   #458
Aluminum Addict
SeasideSteph's Avatar
1970 31' Sovereign
Rockport , Texas
Well at least I know I'm not alone on that. Thanks for assuring me of the value, it does seem rather expensive for that lil thing. But I'd rather have a pretty door, and I do think I have more rivets to do than I want to admit. (plus I just keep telling myself most gals my age spend way more that that on shoes and purses; )
SeasideSteph is offline   Reply With Quote
Old 08-03-2012, 09:35 AM   #459
Tool Hoarder
West , California
@Lunadog Absolutly! Would love to have a cocktail with all yall!
@Peter Sounds like someone needs to get a SoCal rally going....
@Seasidesteph The shaver is a great tool, so is s the cyclo, I love them. The cyclo also does a great job taking the swirl marks out of the paint an my tow vehicle.
I suffered a minor set back on my door frame. While cleaning and removeing some tuff rivets I broke the frame again. Oh well back to the welder....
Old 08-03-2012, 10:04 AM   #460
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
To frame it mildly, he was framed, again!
That sure looks like a good item to etch, passivate and Allodine.
Old 08-03-2012, 06:59 PM   #461
Tool Hoarder
West , California
I dont think Alumiprep 33 can be used on my sand cast aluminum frame, but I could be wrong. It does work on aluminum sheet quite nicely though.
Old 08-20-2012, 10:13 PM   #462
Tool Hoarder
West , California
Finally got the door frame back from my welder. Thankfully it wasent 107 in my driveway so I was able to rebuild my outer door.
ID:	166318   Click image for larger version
ID:	166320   Click image for larger version
1965, 1965 sovereign, buck rivet, frame repair, olympic rivet, shell off
'63 Overlander Rehab.... tgregory13 1960 - 1964 Overlander 43 12-09-2010 09:40 AM
Need Rehab Buddy for Hubby/Anywhere in US! goobygirl General Repair Forum 6 09-17-2009 12:47 AM
Getting Assistance in Rehab? goobygirl General Interior Topics 9 09-15-2009 11:22 PM
First Use Rehab Merry Stahel General Interior Topics 16 11-18-2006 07:41 PM
6 metre interior rehab? Janet H All Argosy Trailers 2 09-24-2003 04:17 PM
