03-18-2013, 11:38 AM
#541
Tool Hoarder
West
Thanks guys! You know its been an ocd day when you go to clean up and every tool you own in on the driveway. Now to talk my wife into bucking some rivets.
03-18-2013, 11:52 AM
#542
1959 17' Pacer
Long Beach
I like the progress so much I would tweet it if I had an account.
08-19-2013, 05:57 AM
#543
salzburg
, salzburg
Originally Posted by marzboy
I should have done alot of panel replacement on mine but i am not patient enough and i would have had to replace just about the whole front end!, good Joob Javier
08-28-2013, 09:44 AM
#544
Tool Hoarder
West
Thanks, I think we could all say we should have replaced more panels etc. I have definitely done my share of patches.
08-14-2014, 09:32 AM
#545
Tool Hoarder
West
Hello all been a little while since my last post. I have been absorbed in other stuff, not a lot of time to spare on the trailer. But I have managed to squeeze a couple days in here and there. I have been stuck on the 12v wiring. I have been searching the forums for re wiring pictures, led sources, and stories. Any one??
08-15-2014, 01:13 AM
#546
salzburg
, salzburg
leds
Hey Marzboy good to see you're still chomping away at it, i used 24 volt led strip lighting which are like daylight when you turn them on!! if you're interested i could find out the name for you but i gotta say they were not cheap the whole van ran me at over €1200!
08-15-2014, 09:09 AM
#547
1967 30' Sovereign
Chiefland
Hi-I'm still grinding away on the 1967 Sovereign 30, am doing wiring now, using all led's-if you have any questions feel free to ask, (christiansnaples@aol.com) I'm fairly familiar with the systems, this is the third (and last) Airstream rebuild I'm doing. Good luck, Rolland
08-16-2014, 08:30 AM
#548
Tool Hoarder
West
Thanks Mr Green ,I'm still in the fight. I would love to see any and all of the info and or pictures that you have. I am going with puck lights in the interior. I am not 100% solid on the layout so placing switches lights and wires is a little hard. Then there are the questions "Do I want this light to turn on and off at the switch panel or independently?" "How many lights on this circuit?" "12v cigarette plugs?"... etc. 1200 Euro? Is that close to $2000 US?
Thanks Rolland I will email you tomorrow. Any help will be most appreciated! Love to see pic of your rig!
08-16-2014, 02:52 PM
#549
Nowhere
Get on it Javier! Every year in the driveway is a year of missed camping. Seriously though - life can get in the way of this hobby pretty fast. Good luck with the finish work.
Norm
08-16-2014, 07:45 PM
#550
Tool Hoarder
West
Norm
Dude I know, I know. Tent camping is getting a bit old....
08-24-2014, 07:48 PM
#551
1967 30' Sovereign
Chiefland
Am finishing the 12v wiring this week-All led light bulbs in the old style fixtures. I used a circuit breaker strip with a bunch of 12v automotive style self resettable breakers as my main 12v positive buss bar, and a old ground buss bar out of a home breaker box for the 12v negative side. Mounted these on a board inside the side compartment where the 12v wiring terminates. Each 12v circuit has its own breaker. Also mounted the battery charger and solar regulator in there, and hooked everything, including the wiring from the battery to the two buss bars. The extension cord I fabricated for the solar panel also lives in this side compartment. There are 12v lighter type power outlets in the bathroom, kitchen, and above the front window in the stereo compartment. Have not decided if I really want to permanently mount an inverter, but if I do it will probably reside in this compartment also. In the mean time can plug it or the phone chargers into the power ports. The positive 12v dc line from the tow vehicle goes through the pigtail directly to the battery, and there is a breaker for this under the hood. The positive line for the electric jack comes directly from the battery(it has it's own breaker) and a ground wire from the battery is connected to the frame at the jack as well as to the buss bar in the side compartment. The 12v negative (ground) from the tow vehicle pigtail is connected to the frame, and to both antennas, as well as a variety of lights mounted on the aluminum skin, (all led) so I will not have grounding problems with the running lights. For the AC 110v I mounted a house type square D breaker box in the rear compartment, because that is where all the 110v AC terminates. I added more lines and receptacles from this breaker box for all the high draw outlets that I installed (Air conditioning/electric heat, convection oven, battery charger) so I would not overtax the original aluminum wiring. The original wiring was good but most of the receptacles were bad so I replaced them. Also installed extra double breakers so can add extra circuits if needed. 110 Vac only, no main breaker, so don't need 220 V or 50 amp hookup. Trying to keep everything as inexpensive and simple as possible. Hope this helps someone, feel free to ask any questions, am happy to help. Haven't posted any pictures lately because am trying to finish and get out of here with the trailer before the weather window closes in New Mexico for the year. Happy Trails! Rolland 5953 (By the way, if you can't figure out what a wire was used for: Aluminum wiring with a black wire, white wire and ground in a white covering is 110V AC. Aluminum Wiring in a white covering with only a black wire and a white wire is 12v DC. Wiring with a black covering is thermostat wiring. Learned this the hard way, someone cut all the wires off before I bought the trailer!)
08-28-2014, 01:54 PM
#552
Tool Hoarder
West
Rolland I am using 14 awg duplex for all the 12v. Do you have any pictures?
08-28-2014, 03:53 PM
#553
1967 30' Sovereign
Chiefland
Will take a couple now-#12 wire will work fine, but use a lot heavier for the mains and from the battery- remember, the lower the voltage and higher the draw, the heavier wire you need. I put everything 12v in the compartment behind the rear wheel on the road side, also put a led switched light in there so could see what I'm doing. Front view is buss bars and charger-Rear is solar regulator and connections. I put the battery in a later model salvaged battery box mounted forward as the photo shows, bringing the weight further forward. Used a aluminum rear bumper and made both tanks from aluminum to reduce the rear bath weight too.
08-28-2014, 04:11 PM
#554
1967 30' Sovereign
Chiefland
TV antenna-Winegard, amplified-made a curved mount for it-I Love aluminum! working feverishly on the inside now. The antenna tucks down out of the way nicely-made a new wall to the left of the door and hung the little flat screen on it-A/C is where the oven used to be, vents out the refrigerator vent and another vent through the floor in front of the wheel-Jury is not in on that one yet. Convection oven on counter behind TV, Nancy doesn't like microwaves. 2 burner gas countertop next to sink.
08-28-2014, 04:18 PM
#555
1967 30' Sovereign
Chiefland
Should have said the 14 will work for most, but use heavier for any heavy or constant draw
08-28-2014, 04:22 PM
#556
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Rolland,
Nice work you have going on there. I encourage you to start your own thread on the '67 Sovereign forum.
Lance
08-28-2014, 05:23 PM
#557
1967 30' Sovereign
Chiefland
I have one, but send most stuff as answers to other threads questions-have about 100 photos of the process, maybe should put on my thread. I find the I-pad much easier to use to post and attach.
08-29-2014, 09:54 AM
#558
Tool Hoarder
West
Rolland
Thank you so much!! I am using 12/2 romex for the 110v 8/2 for the main and 6 awg for the batteries as well as the pre wire for future solar. I think most people are a bit shy about sharing their re wiring pics so I appreciate it.
08-29-2014, 04:43 PM
#559
1967 30' Sovereign
Chiefland
You are quite welcome-you could use 12/2 for the 12v too-I Don't mind sharing, I too look at and read everything I can, there is not a lot out there on these older rigs. Just have to get this one on the road before I am to old to get on the road!
