Old 08-25-2011, 09:13 AM   #141
Tool Hoarder
West , California
@ Chuck Tops link is correct. In fact Top is the one I ripped it from. I know it is a bit of over kill, but at this point? Come on!! Hope this weekend to finish the install of the C channel and rear hold down plates. More pics to come.
@Top You are also correct. Thanks for the tip on the paint BTW. Boy those axles were a biaaaach to remove! Heres a bit of the carnage....
ID:	138648   Click image for larger version
marzboy is offline   Reply With Quote
Old 08-25-2011, 10:53 AM   #142
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
Two months for axles! Where did you get them?
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
Max Well is offline   Reply With Quote
Old 08-25-2011, 07:05 PM   #143
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ooh! I'm going to try to narrow the axle guessing game... the calipers look like single piston, so not Dexter....
I'm going to also guess that shipping was not from the west coast....
Do I win?
Great progress! Can't wait to see the frame standing up with the new axles and tires. Good looking rims too!
Marc
Old 08-26-2011, 08:53 AM   #144
Tool Hoarder
West , California
@ Max I knew the axles were going to be back ordered, but that much time was a bit much. No big deal because I have to finish the insulation and belly pan.
@ Marc You are correct sir! They are 3500# Axis axles w/ 12"disk brakes. Now before I get comments form the peanut gallery, I have read the threads regarding Axle size. I made my decision based on where I will be towing, mostly mountain and wet roads. All of you that have towed in those conditions know what pulling that much trailer on those kind of roads. A bit over kill maybe, peace of mind defiantly.
Old 08-26-2011, 10:08 AM   #145
1975 Argosy 26
1963 24' Tradewind
Nice going with the disc brakes! I know about wanting that backup... when I replace my Argosy axles, I will be going with disc.. after overheating my trailer and TV brakes (1 ton Dodge van) going down into Kelona BC, I didn't want to wash my pants again! (I think I almost puked after I got out of the van... 45 mph down the grade, pulsing the brakes, already in 2nd, and couldn't slow down for the SHARP 35 mph curve ahead... minimal brakes left. Didn't want to do THAT again!)
Which controller did you get? I can't wait to see the plumbing.. did you get a tubing bender and flare tool?
You know I'm jealous don't you! I want a welder.. some driveway space... new axles... sigh...
Marc
Old 08-26-2011, 10:48 AM   #146
Tool Hoarder
West , California
Marc
No doubt, scary ****! Thats the problem with magnets, heat makes them not so magnetic. With all that friction, well you can do the math. I have a Prodigy III Brake controller. I am going with the Titan brake actuator. I still have to figure out if I want to run the lines or pay someone.
I can wait to get her back together so I can have my driveway back!!
Old 09-05-2011, 12:04 AM   #147
Tool Hoarder
West , California
Got some work done on the belly pan today, hope to have it finished by Tuesday. I started a thread under the belly pan section.
Old 09-11-2011, 06:25 PM   #148
Tool Hoarder
West , California
Got 3/4 of the belly pan finished reinstalled the spare tire carrier and got one new axle in place today. Unfortunately I have to cut it short today because I have to attend an event
ID:	139955   Click image for larger version
Old 09-13-2011, 04:39 PM   #149
1968 26' Overlander
West Richland , Washington
Marzboy,
Been watching your build and its looking good. You'll be reinstalling walls & cabinets in no time. You mention you have re-installed your spare tire carrier. My trailer came without one but it's obvious it was intended to be mounted under the trailer, between the main frame rails at the very front of the trailer. I'm trying to find a picture of how its made and installed. If your trailer has a similar spare tire carrier installation, could you post a picture or two? thanks------
JIMandPJ is offline   Reply With Quote
Old 09-13-2011, 06:07 PM   #150
Originally Posted by JIMandPJ View Post
Marzboy,
Hope this helps you.
Old 09-13-2011, 10:21 PM   #151
Tool Hoarder
West , California
Marzboy,
The spare tire carrier Andy posted is the one that I got ( from Inland RV). Just reinstalled it yesterday after I got done with the front section of my belly pan.
ID:	140178   Click image for larger version
Old 09-13-2011, 10:49 PM   #152
Tool Hoarder
West , California
Got one axle up one more to go!! Not easy when you are workin alone....
ID:	140180   Click image for larger version
ID:	140182   Click image for larger version
Old 09-21-2011, 12:40 PM   #153
Tool Hoarder
West , California
And heres the other axle
ID:	140683   Click image for larger version
Old 09-21-2011, 04:20 PM   #154
1975 Argosy 26
1963 24' Tradewind
Nice! So drill four holes and you're good to go? How'd you mark the holes? What kind of bit did you use?
Bet you're arms are sore... Great work!
Marc
1965, 1965 sovereign, buck rivet, frame repair, olympic rivet, shell off
'63 Overlander Rehab.... tgregory13 1960 - 1964 Overlander 43 12-09-2010 09:40 AM
Need Rehab Buddy for Hubby/Anywhere in US! goobygirl General Repair Forum 6 09-17-2009 12:47 AM
Getting Assistance in Rehab? goobygirl General Interior Topics 9 09-15-2009 11:22 PM
First Use Rehab Merry Stahel General Interior Topics 16 11-18-2006 07:41 PM
6 metre interior rehab? Janet H All Argosy Trailers 2 09-24-2003 04:17 PM
