Old 03-22-2015, 07:18 PM   #1
1961 24' Tradewind
Broomfield , Colorado
1961 24' Tradewind floor
I recently acquired a 1961 24' trade wind. I am gutting it.
The subfloor is in rough shape in spots. I have the following questions (I am new so be gentle if these are dumb questions)
- From what I can tell, the subfloor is bolted into the frame from top to bottom, and the shell sits on the floor, bolted down to it from underneath. Is this true?
- In order to replace the subfloor completely, I would need to lift the shell?
- If I were to lift the shell, I would have to remove the inside panels to unbolt the shell from the floor?
- The trailer has aluminum under skin, which I'm hoping has protected the frame but at the same time is destroyed in some spots. The under skin appears to be riveted to the sides at the base. In order to get to the bolts holding the subfloor down, I think I have to remove the underskin. When this happens, I'll get a good look at the frame.
- If I were to go through the brain damage of lifting the shell and removing the subfloor, would I be an idiot not to completely restore/repair the frame?
rohayre is offline   Reply With Quote
Old 03-22-2015, 07:50 PM   #2
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
You can replace the floor parts at a time without lifting the shell. The inside walls need to come out no matter. There are many threads doing it either way. Good luck and post pictures of your progress.
FC7039 is offline   Reply With Quote
Old 03-22-2015, 08:29 PM   #3
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Here is a link to a very detailed, very good shell off restoration of a '63 Overlander.
http://www.airforums.com/forums/f109...ome-71609.html
Good luck!
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-23-2015, 08:29 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
This is correct!
People replace their floors without lifting the shell, but in my opinion, that is probably the more difficult way to do it. Lifting the shell seems like a huge and dramatic way to go, but people do it all the time!
Correct!
Yes, this is known as the "belly pan," and yes, you need to remove it, and you will see that it doesn't really protect the frame.
Again, lifting the shell is not such a big deal, and yes, if you are lifting the shell, you should repair any part of the frame that is rusting away, scrape the old rust and paint off of it, paint it with POR-15, etc.
Good luck!
1961 Bambi :: 1961 novus1 Airstream Registry Discussions 0 05-22-2012 06:53 PM
1961 BAMBI :: 1961 Airstream BAMBI SILVERSAILOR Airstream Registry Discussions 0 08-19-2011 08:31 AM
1961 Tradewind Tad Pole 1959-69 Tradewind 5 09-18-2008 09:56 PM
Region 9 Auctioning 1961 TradeWind Pahaska WBCCI Forum 7 10-31-2005 11:22 AM
