Old 11-21-2006, 04:26 AM   #379
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Don't forget that many newer Airstream's have the A/C and Microwave on the same circuit (and same circuit breaker) with a switch in-line to select either the microwave, or A/C. This keeps you from overloading the circuit at the campground, especially if the campground has only 20A service. Those of us that don't have a factory installed microwave have to do this the old fashioned way and remember to not turn both on at the same time. This switch definitely is not a requirement, but you do have the option of adding it during your rewiring efforts if you want to.
Joe
WBCCI/VAC #6768
66Overlander is online now   Reply With Quote
Old 11-21-2006, 06:47 AM   #380
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Andy ~
Although the factory used wire nuts and electrical tape, you shouldn't if it's done right unless it's in a junction box. Do you have your electrical panel picked out yet or are you planning on using the original to the trailer? If you need some assistance with setting this up in your trailer, give me a ring. We can set up a diagram that will be easy to follow.
Now, it goes without saying, if I help on this, you need to keep this trailer.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-21-2006, 11:48 AM   #381
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally Posted by ankornuta
I took Richard's (Azflycaster) advice and contacted Randy at www.bestconverter.com. He was EXTREMELY helpful. I basically know nothing about how to wire a trailer and he helped me out quite a bit.
It looks like I'm going to go with:
- WFCO 8900 series 55amp converter / charger with power distribution center. This will hold my AC breakers and DC Fuse panel. I believe I need one main 30 amp breaker and do I also need one 30 amp breaker for the Air Conditioner?
- WFCO 600 watt true sine inverter
- Class T fuse block
- Two Lifeline AGM GPL-4C 6 Volt, 220 Ampere Hour Deep Cycle batteries, wired to produce 12 volts. These weigh almost 70 pounds each, though... so I'm wondering if I'm going to need to reinforce the tongue of the trailer, and how to do that.
- TriMetric battery monitor
- Some type of mechanical Battery disconnect
Also... in my trailer, all of the 110V AC wiring today is just copper wire with insulation. However, I know that in construction, Romex is generally used. Is there a reason not to use Romex when replacing the 110V AC wiring in the trailer?
My 59 going to be close to what you have. It had one breaker for all the 110v. Course back then the big draw would be a Toaster not a Microwave. It wasn't even prewired for a A/C.
When I rewired mine I took ALL the outlets off the existing 110v circuit and only left the over head lighting on it. All the outlets were T in in the ceilings at the light fixtures so it was easy to just cut that leg out and I was able to use the cut off legs to pull new wires down to the outlets. I used 12 gage Romex.
"Overkill" is my middle name. When I rewired I made a dedicated line to the Reefer and a Dedicated line to where a A/C will eventually end up. A dedicated line to where the charger and D/C distribution will be under the front Gaucho. Then I ran a a Leg for outlets to each side of the coach. I ran it all 12 gage so that I could handle a Microwave either side as well a space heaters or any other high draw appliance.
The D/C I again ran a Dedicated to where the reefer will be as well as Forward lights, Rear lights, power for futureTV antenna and 12v plug, Heater blower, stereo, galley 12v receptacle. I also ran an 8gage spare from front where the distribution panel will be to to the rear under bed storage area for any future needs or to run a small inverter if I ever feel I want one.
Don't for get to take entertainment into consideration. I prewired for 4 speakers with the intent to mount a car stereo in the side of the wardrobe. That happens to be right next to where we will put a TV so it will be no big deal to get that the speaker wires if we get fancy with the TV. I also ran a Coax around to the storage compartment for when Cable TV is available at the campground.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 11-21-2006, 02:00 PM   #382
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
Originally Posted by flyfshr
Andy ~
FF
Well, I'm not going to make any promises about whether or not I'm keeping the trailer because one never knows what curveballs one may encounter in ones life... Now that I'm done waxing philosophical, it's looking like I'll be keeping the trailer
I'm going to be getting a WFCO 8900 series 55amp converter / charger with power distribution center. This will hold my AC breakers and DC Fuse panel. I don't know how many AC breakers it will hold though. Based on what I'm hearing (thanks to everyone for their great feedback!), I think I'll need the following for breakers for AC power:
1. 30 Amp main
2. 20 Amp for refrigerator
3. 20 Amp for A/C
4. 20 Amp for left trailer side
5. 20 Amp for right trailer side
6. Should I run the inverter on it's own breaker? Does that make any sense?
I'll be using 12 gauge Romex for all this wiring (good advice 59toaster!) I don't think I'll keep a microwave in the trailer... but just in case it'll be good to have the refrigerator and trailer sides on different breakers with a heavier wire. I plan to use grounded GFCI outlets for all of the 110V outlets. You never know what might get wet when camping...
For the 12 volt, I'll probably do something similar to what 59Toaster is talking about as well, and I did forget to take an entertainment system into consideration actually! I'll need to run wiring for the speakers, switches to turn zones on and off, etc. I'll also need coax for the antenna and possible campground cable.
Brad, chances are I'll be calling you tonight! I think I'm finally starting to wrap my brain around this wiring thing, but I know that means I know a lot less than I think I do
ankornuta is offline   Reply With Quote
Old 11-21-2006, 03:04 PM   #383
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Outside outlet
Andy,
Are you going to put an outlet outside. I find the one on our Safari very useful for the obligatory awning lights and a radio. It also works for the optional margarita blender when the weather is too nice to mix inside.
Bill
Just my personal opinion
Old 11-21-2006, 03:10 PM   #384
ankornuta's Avatar
Images: 22
Another question....
I definitely want get a lot of the wiring done this weekend (yay four day weekend!) but I still have a question I'm hoping some of you seasoned electrical veterans can help me out with...
My overhead lights have both 110v and 12v outlets. Can I just run 12v power to the 110v outlet and use 12v bulbs in them?
I'll post a picture of it later, but if I have to replace it, it's going to be tough. The part that the bulbs screw into is the same part that the lens attaches to.
Also... I need to find some 12 volt ballasts for the flourescent light fixtures in the trailer. My trailer has five flourescent light fixtures, all 110v currently. I really like the look of them.
Old 11-21-2006, 03:11 PM   #385
ankornuta's Avatar
Images: 22
Originally Posted by wkerfoot
Andy,
Bill
Ahhh yes... outside is the best place for margarita blending I actually have two outlets outside of my trailer; someone replaced the original single outlet with a double.
Old 11-22-2006, 03:16 PM   #386
ankornuta's Avatar
Images: 22
Wiring... I think I've got it
Okay, so I want to get everything wired this weekend, I've asked loads of questions... I think I've finally got it. I'm putting my notes here so I don't lose them
110 volt system:
- Main panel with one 30 amp breaker connecting to the incoming shore power on street side, in the bathroom cabinet. Power runs from here to...
- WFCO 8900 power center with converter and breaker panel located under the refrigerator. Breakers include:
- 20 amp for Air Conditioner
- 20 amp for Refrigerator
- 20 amp for trailer curb side, outside and ceiling lights
- 20 amp for trailer street side (incl kitchen)
- The only 110v lights will be the three original overhead lights which also have 12v outlets (two 110v outlets and one 12v outlet in each)
- All outlets are grounded GFCI outlets in plastic boxes
- All wiring is 3 wire 12 gauge Romex
- All splits/splices in plastic junction boxes
- Pure sine 600W inverter w/ class 110 amp class t fuse block located w/in 18" of battery
12 Volt
- 2 x 6 Volt, 220 amp hour batteries, providing 440 amp hours!
- Mechanical kill switch for batteries
- 12 position DC fuseblock in WFCO 8900 power center, powering:
- 5 flourescent lights (two fuses: one fuse for front and curb, one fuse for rear and street)
- 3 overhead lights (one fuse for all)
- 2 front sconce lights (one fuse)
- 2 rear sconce lights (one fuse)
- water pump (one fuse)
- fantastic fan in bedroom (one fuse)
- 2 outside lights, one at each door (one fuse for both)
- stereo, amplifier and speakers (one fuse)
- bathroom overhead light and under cabinet lights (one fuse)
- 12 volt (cig lighter) outlet in over-fridge electronics cabinet (one fuse)
- 14 gauge wire
Enterntainment and Internet
- Car stereo and amplifier running on 12 volt in the electronics compartment, above the refrigerator
- 2.4 GHz 15dBi omnidirectional roof-mount antenna mast for 802.11x receipt and broadcast, connecting to Airport base station which also feeds into Aux jack on stereo for wirelessly streaming music from any laptop w/ iTunes
- Input for coax by shore power, converts to HDMI and feeds to front living area and rear bedroom area, with additional inputs possible in electronics compartment above fridge (for laptop video, DVD player, etc)
- Original (old school) antenna, coax feed into electronics compartment above refrigerator, into output box.
- Wiring for 4 speakers in the living area, 2 speakers in the bedroom area, 2 jacks for speakers near the outside outlet, zone controller in the electronics compartment to turn off front, back or outside.
Old 11-22-2006, 04:06 PM   #387
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
crikeys man! i don't think my house has that many circuits! i need to get mine cracking once the interior skins are polished up.
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 11-22-2006, 06:52 PM   #388
till's Avatar
Lisle , Illinois
Images: 108
Wholy smokes!! That is one long list of curcuits.
I would recomend keeping it simple. I was going downthe same road when I had a reality check with the inside walls. I did not want to run that much wire through the walls. Just more to go wrong down the line. The coach has worked for 39+ years with three 110 and three 12 volt curcuits.
Just my two cents
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 11-22-2006, 06:59 PM   #389
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Andy,
I am not sure that you need a separate circuit for the refrigerator. Check the amp draw for yours. Is it a gas/electric absorption type or a household compressor driven. I don't think the absorption type draw as much as the compressor type. I have never had a problem with popping circuit breakers on the Safari and we only have three circuits with the microwave and refigerator on the same circuit.
Bill
Old 11-22-2006, 07:19 PM   #390
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Wires everywhere!
Wiring is just what I have been doing the last couple of days. Wires everywhere. But I have nothing close to what you are proposing
I wish I could think that far ahead.
Here is part of my wiring mess from today. You don't want to see the other ends of these wires!
-Tim
theVAP - Airstream Podcast
Old 11-22-2006, 07:24 PM   #391
ankornuta's Avatar
Images: 22
Andy,
Bill
You're probably right, but you never know what the future holds in store and since I basically have just an aluminum shell right now, it won't hurt to overdo it a little. The refrigerator that I'm looking at is a dometic, and I have somewhere in my notes that it will draw 14.1 amps.
Old 11-22-2006, 07:25 PM   #392
ankornuta's Avatar
Images: 22
Whoa... I can only imagine what the other end looks like. I've got ALL of the interior skins off right now, so it should be easier for me to do my wiring than what you're having to deal with right now.
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 4 10-26-2003 05:10 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 3 09-07-2002 07:27 PM
