Old 07-23-2006, 09:50 AM   #267
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
Floor
In the 118 degree heat with 30% humidity yesterday I started bolting my floor down in preparation for moving the shell to the new house. I got the first few pieces bolted in place, starting at the front. It's not too hard; I just drilled all the holes with a 5/16" forstner bit first, going down just enough to recess the carriage bolt head. Then I drilled through the rest of the way with a 1/4" drill bit and put the 1/4" x 1" carriage bolt through. Lock washer and nut on the bottom and it's done.
If it wasn't so ridiculously hot here it would be a pretty easy process. Yesterday my drill actually kept overheating in this weather and I kept having to take breaks to let it cool down. I can't pick up my ratchet with bare hands because it gets too hot. Even the bolts get too hot to touch comfortably. This morning I started at 6am and it was already over 90 degrees and then the drill died. So I'm done for the day.
I think the last piece of plywood floor for my trailer is too long. It almost reaches the bumper, short by only about 1". I'm not going to bolt that piece in place until I have the frame under the body again. That way, I can lower the body down and see how much length I need to trim there.
Next weekend I'll be at our cabin in the mountains enjoying the cool weather and then I'll finish up the floor and set the body on it the following weekend so I can take it to the new house. I'm trying to decide how I can secure the body so that it's safe for the 12 mile drive to the new place. The last thing I want is for that body to fall off in the middle of an intersection. That would certainly be a sight....
ankornuta is offline   Reply With Quote
Old 08-06-2006, 12:34 PM   #268
ankornuta's Avatar
Images: 22
More Progress
I continued to secure the floor today. I'm just about done, except for the last piece which I'm not going to bolt down until I do a test fit. I've decided that I'm going to use the old belly pan and just cut it off right where it disappears from view. Then I can finish up the insulation, plumbing, wiring, etc underneath and cover the bottom with new aluminum.
I also put the wheels and tires back on today and discovered something that made me very happy; per my calculations once I had the gray and black tanks installed with their supporting structures and the floor back on, the trailer should balance perfectly when unloaded (before the propane, batteries and fresh tank are installed up front). And it does! It's really cool. I can put the hitch stand up in the front and move the trailer side to side and front and back with very little effort... it just sort of teeters up and down ever so slightly.
Next up... test fitting the body.
Old 08-06-2006, 01:10 PM   #269
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I'm glad that the weather has given you a break to work on this project. When you get it all back together are you going to have a few hundred pounds of tounge weight? The reason I ask is that a light hitch will cause sway problems when you tow. BTW, I thought you were going to move....
Richard
Old 08-06-2006, 05:46 PM   #270
ankornuta's Avatar
Images: 22
No kidding... the weather's actually been pretty decent the past few days. It's nice to get outside and do stuff.
When it's all put back together, the tongue should be just a bit heavier (but not too heavy) so long as all of my planning works out the same in real life as it is on paper. So far so good...
The move is "officially" at the end of September. I'll probably move the trailer before then if progress permits, but at the very least it gives me a deadline. It seems like I work more quickly when I have a deadline like that.
Old 08-07-2006, 09:31 AM   #271
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
dead lines
I know what you mean about dead lines. When I was working on my trailer it was rally dates that I used to create dead lines. The input from the members of the rallies and the dead line was a great help. Especially on those jobs that seemed to take for ever. Cool work. Hope to see your results at a rally some day in the near future.
Don
NorCal Bambi is offline   Reply With Quote
Old 08-09-2006, 10:14 AM   #272
ankornuta's Avatar
Images: 22
Don
I hope that I can get my heap to a rally some day soon! Initially I thought I would be done with this thing very quickly. And I guess that if this was my full time job I could get it done very quickly, working eight or ten hours a day every day. But... it's a labor of love and I think part of me wants to drag it out because I really do love working on it. That's where the deadline comes in handy for getting stuff done!
Old 08-09-2006, 10:24 AM   #273
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
It will get done - if its like me it will seem endless at times, especially if you want to go camping - there were many times if someone came along with 1 dollar I would have said take it!
I think my 58 was in similar condition to yours - its taken me about 2.5yrs - can't do much in winter here - guess you can't do much in summer there - so probably about evens out. Not to mention I had a new house built and moved during that time - actually I guess your there too!
Regards
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 08-14-2006, 02:15 PM   #274
ankornuta's Avatar
Images: 22
Cutting Aluminum
I need to cut my belly pan so that it wraps over the U-channel and down under the frame just out of sight. I'll close it in with new aluminum on the under side later on when i finish the wiring and plumbing and all that down there.
Anyhow, I have a lot of belly pan that I need to cut; what's the best way to do it other than an air-nibbler thing; They don't have to be clean cuts. I just don't have an air compressor and need to do this quickly.
Any advice? Hacksaw?
Old 08-14-2006, 02:33 PM   #275
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I just picked up one of these shears recently. I used it to cut away the belly pan. Seemed to work pretty well for that.
http://www.harborfreight.com/cpi/cta...emnumber=92115
It does say 360 degree swivel head. I have not figured out what that does though.
-Tim
theVAP - Airstream Podcast
Old 08-14-2006, 03:23 PM   #276
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Ankornuta ~
I have an electric nibbler similar to the one shown above that you may borrow. Shoots through sheet aluminum just like butta' Let me know.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-14-2006, 04:56 PM   #277
ankornuta's Avatar
Images: 22
Originally Posted by flyfshr
Ankornuta ~
FF
Tim, thanks for the picture.
Brad, thanks for the offer! If they don't have them in stock at Harbor Frieght, I might just take you up on that this weekend.
I didn't realize that they made electric versions of these tools.
Old 08-14-2006, 06:52 PM   #278
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Ank, I thought I'd put a plug in for the Harbor Freight sheet metal shears. I have the exact tool that Tim is talking about. I did have to order it online as the HF store here didn't have em. It didn't take very long at all to get here.
One of the best tools I have bought for doing metal work. I used these shears to cut my entire new bellypan out of .040 Aluminum plus all the other odds and ends that I need a nice clean, straight edge for.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 08-15-2006, 10:37 AM   #279
ankornuta's Avatar
Images: 22
Alright, that does it. I've ordered it from Harbor Freight!
Old 08-18-2006, 06:39 PM   #280
ankornuta's Avatar
Images: 22
Test Fitting
This weekend I'm going to get the frame back under the body for a test fitting. I haven't attached the U-channel to the floor yet because I want to be sure that everything's lined up just right. This means that I'll have to roll the frame under the body, lower the body, test fit, attach the channel, and then raise the body back up to put the belly pan perimeter in place. I'm not looking forward to lowering, raising and lowering the body again. However, if all goes well this should enable me to start buttoning it back up by next weekend.
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 4 10-26-2003 05:10 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 3 09-07-2002 07:27 PM
