Old 06-15-2004, 02:51 PM   #1
Talking 1 more question on floor replacement?
I have some holes in back of trailer in floor. If I take off the trim strip aluminum and then unscrew osb can I get it out and slide in a sheet of plywood? It looks like 3/4" thick, is that right for a '85 Sovereign? Why was AS using osb anyway?
jperryfly is offline   Reply With Quote
Old 06-15-2004, 04:04 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Do a search for "clamshell repair" - I think that describes what you are referring to.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-15-2004, 09:59 PM   #3
Joe Z's Avatar
jperryfly - Check out this thread:
http://www.airforums.com/forum...ad.php?t=11903
I have an '87 Sovereign with a similar problem. If your floor is the same as mine it is 5/8 OSB with the edges that go under the aluminum "U" channel in the front and back of the trailer routered down about an 1/8". After two dealers botched the repair job I decided to do it myself. Joe
Joe Z is offline   Reply With Quote
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
