07-05-2011, 01:46 PM
1978 31' Sovereign
Oakley
1/2" Subfloor? And Elevator bolts.
I've finally got both front and rear floor sections out of the 76 Argosy. I measured the plywood and it specs at 1/2"?!! What the heck? I thought is was supposed to be 5/8"...also...I can't seem to find the elevator bolts locally. I can find flat headed elevator bolts, but they all have the square shank under the head instead of just a smooth shaft. Where can I get the correct ones? Even the nutshop online shows an elevator bolt with the square shank like a carriage bolt. Please help.
07-05-2011, 01:53 PM
1959 17' Pacer
Long Beach
So I'm guessing the ones you saw online were these elevator bolts at VTS?
If so, you could probably just drill a slightly larger hole near the top, or a countersinking bit, etc.
It looks like there is still plenty of surface area on the bolt head to grab plywood, even if you drill out a hole for the square shank, which would only be slightly larger than the hole for the threaded portion.
07-05-2011, 02:11 PM
1978 31' Sovereign
Oakley
Yes, similar style. The ones I'm replacing though are the ones that attach the front and rear c channel thru the channel then the plywood. I don't really want to elongate the holes in the c channel.
07-05-2011, 02:39 PM
1973 Argosy 26
1966 30' Sovereign
Southern
, Wisconsin
"Jenny" (our '73 Argosy26) has 5/8" subfloor...I used carriage bolts in some places...
All that is gold does not always glitter...those who wander not always are lost....
07-05-2011, 03:03 PM
1978 31' Sovereign
Oakley
These are the one's I'm lookin for. "Jenny's" floor is more of what I expected with 5/8". I don't get why they would have used 1/2".? Since it's on the ends, can I upscale to 5/8" without causing too much stress to the shell (the cap)? Mine is a 76 26 footer.
07-05-2011, 03:21 PM
1973 Argosy 26
1966 30' Sovereign
Southern
, Wisconsin
Check your C-channel dimensions to see if 5/8" will work. I was confused until I actually pulled the bad sub-floor up and found that the center (more solid places)were actually 5/8" I would reposition those slightly to center in the channel, thus allowing you to use whatever fasteners you'd like...seal the old hole with urethane....
07-05-2011, 03:26 PM
1978 31' Sovereign
Oakley
These are the ends...where the channel sits atop the plywood.
I'm only replacing the ends, the center sections are A-O.K.! Thank the Lord!!!!
07-05-2011, 05:04 PM
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
check if you got a fastenal place in you area.
Home | Fastenal
they have the elevator bolts as well.
07-05-2011, 05:51 PM
1978 31' Sovereign
Oakley
Home | Fastenal
Thanks! Didn't even know there was one here. Hahaha lived here for 25 years too. Yikes! They better start advertising.
07-22-2018, 02:25 AM
jcarp sculptor
1966 22' Safari
portland
, Oregon
Jcarp 1966 safari my c Chanel has 1.5 inch by 3 inch by 1/4 inch rectangular bars as washers under heads of elevator bolts to spread stress. These accommodate the square head space.
