Old 09-27-2010, 01:53 PM   #1
Airstray's Avatar
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton , Washington
Images: 13
Angry '03 Frame Cracks
My '03 22ft. International CCD has 2 small horizonal cracks where the outriggers attach to the main frame on each side of the step. It appears that a very heavy person has jumped up and down on the step. The main frame dosen't appear bent. Anyone have this problem or possible cause? I've owned a 66 Overlander and a 77 Excell 500. I'm really disappointed in the quality of the newer AS's Help!!!!! Airstray
Airstray is offline   Reply With Quote
Old 09-27-2010, 02:11 PM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Can you post a large, clear photo of these cracks?
TX-16
Dave Park is offline   Reply With Quote
Old 09-27-2010, 02:33 PM   #3
_
Originally Posted by Airstray View Post
Anyone have this problem or possible cause?...
hi stray...
the double deuce models from ~02-07 are WELL known for frame issues...
many threads here on this model including gory details and heroic repairs.
http://www.airforums.com/forums/f36/...-it-33396.html
http://www.airforums.com/forums/f36/...ure-48105.html
http://www.airforums.com/forums/f36/...oor-64802.html
http://www.airforums.com/forums/f212...ccd-44473.html
http://www.airforums.com/forums/f349...rse-39275.html
http://www.airforums.com/forums/f353...tml#post771272
many INTERrelated issues but at the root is a TOO wimpy frame, osb, no belly pan and sealant integrity.
cheers
2air'
Old 10-03-2010, 09:55 PM   #4
Airstray's Avatar
1966 26' Overlander
Images: 13
Has anyone considered forcing sizable box tubing between the frames forward of the FW tank to bring the frame back to original position and weld it on all possible points? A hydraulic "Proto Power" will spread the frames but the street side frame should be well stabilized. The reason I suggest this stems from Forum reports, "the AS frame fix doesn't solve the problem". Boxing the frame may also help. I've contacted AS and await an answer. Any thoughts?
Old 10-13-2010, 08:07 PM   #5
Maineyak
frechettec's Avatar
2007 27' Safari FB SE
Kennebunkport , Maine
CCD 22 with sagging rear curbside outriggers
Our 2002 is "listing" on the curb side. I ordered and received but have not installed two new Dexter axles--thinking that was the problem. After running the trailer on ramps--I detected cracked welds on the outriggers and they are sagging about 2 inches.
How in the world can I lift the shell back into a level positions and beef-up the outriggers?
Please, anyone, help me.
Carl
P.S. I explained the listing (not knowing about the cracked welds at the time) to the AS factory repair mechanic when we visited the factory in Jackson Center, OH, and the only recommedaion/diagnosis he had was to check the air pressure to ensure both sides were equal.
frechettec is offline   Reply With Quote
Old 10-14-2010, 09:34 AM   #6
Airstray's Avatar
1966 26' Overlander
Images: 13
Carl, Send the axles back. The AS factory is blowing smoke. As everyone with our frame problem knows, the frame is weak. My '03 22ft. CCD has crack welds, vertical cracks in the frame and buckled frames which have dropped the rearend. I am presently in contact with AS factory, which has sent frame stiffeners, 8 outrigger stiffeners and agreeed to pay for 4 hours labor. I know this will not solve the problem but I'm going along with it to see what happens. Send me a private and I will tell you who to contact. Airstray
Cracks in hitch! 2Tex4Fun Hitches, Couplers & Balls 8 11-05-2009 09:24 PM
Cracks in endcaps...and more a-wanabbee General Interior Topics 1 08-14-2007 03:25 AM
A-frame cracks Inland RV Center, In Repairing/Replacing Floor &/or Frame 7 08-11-2005 09:28 PM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 12:42 PM
Tire Cracks Action Tires 3 06-14-2004 01:09 PM
