Greetings Peg!
Originally Posted by Peg
Thanks Shari.
that gave me the dry weight. the gvwr should be on the camper right? Problem is the camper is 130 miles from my house. Ohio title does not state the weight for some reason.
The GVWR can be a bit difficult to find for some of the Vintage coaches -- my '64 Overlander International didn't have a placquard on the coach, nor did the owners' manual list the information. When I contacted Airstream, (this was in 1995) they weren't able to give me the GVWR. I ended up estimating the GVWR by adding 1,600 pounds to the empty weight when registering the vehicle.
I suspect that by the time your coach was produced that the information was probably required to be posted on a placquard attached to the coach, and may very well have been found in the owners' manual as well (I know that by '78 the information was posted on a placquard on the front of my Minuet and was also contained in the owners' manual). If someone with a similar coach doesn't answer your question by Monday morning, you may want to contact Airstream Technical Support for a dfinitive answer. You can find the contact information for Airstream Technical Support at:
http://www.airstream.com/company/contact.html
Good luck with your coach!
Kevin
