Old 04-27-2015, 10:32 AM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
State named Trailers?
I've noticed a couple of trailers with state names on both sides and rear of trailers. Does anyone know if this was a factory install? I sit some type of package? Both trailers are 77's. I have an Alaska and Wyoming trailer pictures.
desertair27 is offline   Reply With Quote
Old 04-27-2015, 10:39 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Never seen this before. I think I can safely that this was not a factory applied option.
MICHAEL
Old 04-27-2015, 11:40 AM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
It's weird because I've seen 2 different trailers with the same exact letters just different states.
Old 04-27-2015, 12:22 PM   #4
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I think folks use to do this to identify their WBCCI units. I've seen similar posts regarding an AS that had either Arkansas Razorback Unit or Arkansas on both sides.
Landrum is offline   Reply With Quote
Old 04-27-2015, 01:00 PM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Definitely a user installed option!
Bob Martel
WBCCI# 5766
Old 06-10-2015, 11:56 AM   #6
lonestardr's Avatar
1979 25' Tradewind
Kingwood , Texas
It was often put on the sides of trailers to represent their WBCCI unit or state. Used to see it more often in the 1980's than now
David
lonestardr is offline   Reply With Quote
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Airstreamer Matthew McConaughey named hottest bachelor. Sean Michael Airstream "In the News" 1 06-15-2007 08:43 PM
What is this material named? Sanders General Interior Topics 2 09-27-2004 03:51 PM
"Streetcar Named Desire" movie coach??? fangthorpe Airstream Motorhome Forums 1 05-13-2003 06:27 PM
