Old 09-14-2013, 08:53 PM   #1
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
Remove stains on awning
I have stains on the underside of my awning caused by leaves. Is it possible to get these stains out?
denmcd is offline   Reply With Quote
Old 09-14-2013, 09:17 PM   #2
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Wow, never seen anything like that. Did you try a small area with 25% bleach to 75 water? Barkeepers helper is a good cleaner and removes stains, but mainly for use on solid objects. I don't think it would harm the cloth awning however, again, try a small spot.
Howard L. is offline   Reply With Quote
Old 09-14-2013, 09:37 PM   #3
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
When I bought the AS a month ago it had been sitting under an oak tree and leaves had built up and caused the stain each rotation of the awning. I am a bit concerned in using bleach on this awning because of its age. I did try a stain remover windex based and it did help but didn't remove it.
Old 09-14-2013, 09:45 PM   #4
Howard L.'s Avatar
San Antonio , Texas
Yes, understand the bleach on older canvas. Greased Lightning ,at home depot and elsewhere, is one hell of a cleaner, removes grease off carpet, etc. basically just one very powerful cleaning liquid. It's not going to hurt the old canvas so you could try., may just have to live with some stain until you re-canvas. Good luck
Old 09-14-2013, 09:54 PM   #5
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
I'll try that. Thanks!
Old 09-15-2013, 03:22 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hmmm - wouldn't leaf stains look more random? With that uniform pattern in the picture, it looks more likely to me that your roller might be rusting.
Old 09-15-2013, 06:54 AM   #7
Hoonanea's Avatar
2012 23' International
Riverview , Florida
One tip I got several years ago when I owned a Prowler travel trailer was to get the awning soaked with water before putting the cleaning solution on. Then, with it soaked with water and cleaning solution, roll the awning back up to let it soak for a little while longer. This presumably lets the solution settle in the same areas where the staining is occurring. It wasn't a perfect solution but I do think it helped remove more of the staining. And it involved less scrubbing.
Ho'onanea -- to pass the time with peace, ease, and pleasure.
Hoonanea is offline   Reply With Quote
Old 09-15-2013, 07:17 AM   #8
Lily&Me's Avatar
Normal , Illinois
OxyClean with a dab of Dawn in hot water works well for us.
Scrub it in with a soft brush and let it sit. Scrub again and rinse thoroughly.
I would follow with diluted bleach water.
If that doesn't work, and it is still visually disturbing , you might want to replace just the fabric.
Maggie
Old 09-15-2013, 08:53 AM   #9
1985 31' Limited
Nellysford , Virginia
Cleaning awning
The Zip Dee website has a video on cleaning awnings, but the important part is their recommended cleaning solution: 1/2 cup bleach, 1 cup liquid soap (Dawn, etc) Water. Apply to both sides of awning. Someone above recommended rolling the awning up with the cleaning solution on the awning. I do that to let it soak in; leave rolled up for a few minutes, put awning down and thoroughly flush both sides of the awning. Worked well for me on a 30 year old awning on my Avion.
RTurnConn is offline   Reply With Quote
Old 09-15-2013, 09:56 AM   #10
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
I don't think you can't mix dawn and bleach together..
Could they be suggesting something instead of dawn?
I don't know.. just want to put this info out.
Jane
Janie Q is offline   Reply With Quote
Old 09-15-2013, 08:39 PM   #11
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
Leaves
The AS set for twenty years with the awning up. The leaves piled up on top where the awning meets the roof and rain and dampness caused the stains. When I rolled out the awning the stains had soaked through the layers of the awning.
Old 09-15-2013, 08:41 PM   #12
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
Thank you all for your help!
Old 09-15-2013, 08:55 PM   #13
W , New England
Ahhhhh! Got it! That makes sense.
I wonder if the leaf stain is a protein. A million years ago when I was a dry cleaner, we used ammonia to get out protein stains (e.g., blood). Probably wouldn't hurt to try all these recommendations on small test sites and see which works best. Good luck!
Old 09-16-2013, 06:20 AM   #14
Lily&Me's Avatar
Normal , Illinois
Jane
Honey, you can mix Dawn and bleach together. Trust me.
We do it all the time. Dawn is just dish detergent, nothing corrosive or that causes fumes.
Maggie
