Old 02-09-2014, 07:43 PM   #1
1977 29' Ambassador
St. Albert , Alberta
New to us '77 Ambassador
Hello All! Yesterday my wife and I purchased a '77 29' Ambassador! Interior is excellent right down to the original curtains. The trailer sat stored indoors for over two decades. The gentleman we purchased it from is the 3rd owner. He had the trailer sitting on an asphalt pad for 2 years in between camping trips. The only updates he has done was he removed the original carpets to install a floating floor, new tires and updated the brake wiring. As far as work needed, the hot water heater has to be replaced and there is a small leak under the sink that i am going to repair by removing the old copper and update with flex hose. Also a window screen needs to be replaced and it is missing one hub cap. As we always wanted an older Airstream, i'd say we hit a good one. We are pretty excited and can't wait to hit the road. Also our trailer is fitted with a centre bathroom, which i think is great, as i was told to watch out for rear baths and the inevitable tail sag. Any tips, hints and advice are welcome and needed please.
Cheers,
Vance MacLean
vanceandjodi is offline   Reply With Quote
Old 02-21-2015, 12:05 PM   #2
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
It sounds like you found a great vintage AS. We bought a 1976 29' rear bath in 2007. I had no idea what we had gotten into but eventually found that it was in good condition. We stripped the remaining clear coat, did some basic restoration/upgrades, polished the exterior, added awnings (transplanted from of a 1991) and have been traveling with it full time.
Sorry to say but any of the vintage models have the potential to develop rear separation. It is not an impossible fix but it does take some work to repair. If you have not done so by now you will need to replace the axles and shock absorbers. I would recommend that you use axles that have a 4000# capacity (each). (No one in the 1970s could have imagined how much stuff we would carry around with us in this day.) If your floor and outriggers are intact, you should be good to go.
Installing PEX will take some planning and a few days of work but is well worth the effort. The electrical system will not handle the demands of todays travelers. You can take out the old breakers, put in slims and run two new 110/20amp lines using metal flex conduit.
If you plan on using the trailer for more than a few weeks you might consider replacing the water pump and converter. They are behind the cook stove/oven. The fact that we have only one battery limits us as to how long we can go between charges but replacing all of the incandescent lights with LEDs will allow you to stay unplugged for a week or more.
Let us know what work and upgrades you have put into your AS.
Eagle & Bear is offline   Reply With Quote
Old 02-21-2015, 11:26 PM   #3
1977 29' Ambassador
Hey,
So far we have installed a new floor, new fridge, new furnace, new hot water tank, re upholstered the couches and had some custom curtains made. All our work was done by Blue Moon Caravans in Missoula Montana. As well, we had it checked out top to bottom and no issues were found. We also had some plumbing and electrical upgrades done. The trailer was stored indoors for over two decades and was in excellent condition when we purchased. Our trailer is middle bath, so no issues with rear sag thus far. Knock on wood, she's a beauty!!!
Old 02-21-2015, 11:32 PM   #4
1977 29' Ambassador
Here she is
Old 02-21-2015, 11:39 PM   #5
1977 29' Ambassador
Try this
Old 02-22-2015, 12:33 AM   #6
2007 22' International CCD
Very impressive. Looks nice!
KE4GNK/AE
Ambassador Kinton :: 1965 Airstream Ambassador International sckinton Airstream Registry Discussions 0 08-17-2013 02:17 PM
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 01:01 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 11:07 PM
New member - new 1968 Ambassador jnjmiller 1966 - 1969 Ambassador 7 01-30-2007 07:54 AM
New Custom Tank for 1962 Ambassador Lookinghard Waste Systems, Tanks & Totes 6 09-28-2005 06:35 PM
