Old 07-15-2019, 06:32 PM   #1
1974 27' Overlander
Seattle , Washington
Interim Refrigerator Replacement Recommendations Sought; Gas Shutoff Valve Location
Dear Airstreamers,
We have an original Dometic refrigerator in our 1974 "International" Overlander ( or is it an "Ambassador" ? ) that needs to be replaced. For now, we're looking for an interim replacement that can just be powered by an electric hookup to a service post, rather than a dual gas/electric unit. We'll likely be keeping the original unit nearby in the event a purist wants to try and fix it.
In the meantime, what are some recommendations for an interim replacement that will cost us notably less than the $1.9k cost of an upgraded Dometic ? The old frig is 56" H, x 24" W, by 21" D. It's a Model RM 77 running on 110 volts.
A related question is: where is the LPG gas shutoff for the old unit ? The shutoff valve locations are obvious for the trailer's oven, stove, wall heater and hot water heater, but this is not nearly so obvious for the frig, as accessed from the exterior service door. Don't want to blow anything (or anyone) up here!
Finally, any advice that might assist in the removal of the old unit is equally welcome, as this will be performed in a remote location.
Thanks in Advance to All.
jmellana is offline   Reply With Quote
Old 07-15-2019, 06:43 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Why not replace with a Furrion compressor fridge?
Interim Refrigerator Replacement Recommendations Sought; Gas Shutoff Valve Location jmellana 1974 - 1977 Overlander 0 07-14-2019 07:15 PM
Rear Rot, Interim Solution, Quick Tips Needed Thiss Repairing/Replacing Floor &/or Frame 9 08-23-2014 06:41 AM
1970 Caravanner remodel interim jenner 515 General Repair Forum 0 08-15-2013 05:51 PM
Exterior water shutoff valve Ag&Au Fresh Water Systems 14 08-18-2009 09:00 PM
leaky shutoff valve? JohnGalt48 LP Gas, Piping, Tanks & Regulators 0 07-13-2005 06:06 AM
