Old 09-11-2013, 04:56 PM   #1
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
'78 Ambassador Air Conditioner
I have just purchased a 78 Ambassador and was wondering about the air conditioner. It has an Armstrong unit and the fan runs fine but I can't hear the compressor kick in. Is this something that can be fixed or would I be better off to replace the unit?
denmcd is offline   Reply With Quote
Old 09-11-2013, 07:47 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It can be repaired. Most RV places only want to replace the unit.
It has been said that a functioning Armstrong will out perform the new units.
You may be able to locate an HVAC shop that would be willing to work on it.
My guess is. You will have to remove the unit from the coach.
Old 09-12-2013, 08:27 AM   #3
denmcd's Avatar
1978 28' Ambassador
Pella , Iowa
Thank You thats good to know. I have seen some on this forum complaining about new units not cooling properly.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
