Old 02-24-2009, 11:56 PM   #43
imeynstein's Avatar
Texarkana , Arkansas
BIGED52---Well, you know how it goes--no one wants to help with the 'blood sweat and tears' , but they are ALWAYS WILLING TO REAP THE BENEFITS!!! I keep reminding my husband and family that IF I am l lucky enough to possess these skills in which to 'get 'er done', that he needs to just 'lay off' or pitch in--either one to help!!
imeynstein
imeynstein is offline   Reply With Quote
Old 02-25-2009, 12:13 AM   #44
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
We are all pulling for you and are ready to look at any and all pictures you want to share. I bet before long he will be out there helping you make it a real memory maker for your travels and campouts. Wishing you the best of luck with your Reno... Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-11-2009, 01:49 PM   #45
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
Smiling Trailer
Over the last few weekends I have been removing and adding outriggers. As you looked down the trailer from the inside, the trailer was actually frowning.
With the edge of the floor lifted slightly I welded good outriggers with a slight up angle next to each of the existing outriggers. Then I raised the existing outrigger up to the new elevation and welded it to the new one. If the rusted outrigger was say at the wheel-well then I replaced it completely or added a piece of angel to the bottom for strength and cover rust holes. I have made my way around the trailer replacing or added to all that needed help except for the two at the steps. I hopefully will have material coming tomorrow to reinforce some of the rusted frame channel. This weekend will be spent replacing the outriggers at the steps and hopefully welding in the C-channel reinforcement.
I have notice an issue with raising the angle of the outriggers, there is oil-canning happening on the back sides just in front of the end cap. I am hopeful this will go away when I install the new flooring. Worst case Iíll shim under the floor in the back to push the end cap up to relieve the bulge in the skin.
I will try and post some pictures of the newly added outriggers.
Inside demo and investigations have uncovered that mice have been in the walls!! So plans have changed, I will be taking down the interior skins, cleaning, and replacing insulation. The idea for the moment is to remove one side make repairs and reinstall skins before removal of the other side.
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 06-11-2009, 06:35 PM   #46
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I've got to visit INSIDEOUT and pick up a tool. When I do, I'll stop by, maybe take some photos!
Keep on truckin'
Zep
Old 06-12-2009, 07:21 AM   #47
bedfords's Avatar
1975 29' Ambassador
Zep, your welcome any time. You wouldn't have a sand blaster by chance? I am starting the prep work for spraying on POR-15. The dirt and rust are bad in some hard to reach areas. Hope I'm around when you stop in, it has been a while sense we talked. Have a great weekend.
Old 06-12-2009, 08:43 AM   #48
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have a sandblaster but you will have to wait a week as I,m in B.C.
Old 06-22-2009, 03:10 PM   #49
bedfords's Avatar
1975 29' Ambassador
Sandblaster
Father's Day was good the kids got me a sandblaster and a spray gun all for the frame prep and painting.
Sunday was spent removing the steel piece down low in the back that attach's to the exterior skin and wall channel right at the floor. My fix is to replace with a similar length of Aluminum angle 4"x4". I will cut the bad exterior skin off and replacing. Attached pic shows damage of skin and edge of the floor before the floor and steel was removed.
The last cross member of the frame was totally gone so I welded in a 2"x2" angle across the top and another on the bottom of the C channel. I then added angle in the vertical, evenly space between the new upper and lower angles. Second pic shows floor removed and missing cross member.
I will try and take some pics of the progress tonight.
ID:	82746   Click image for larger version
Old 06-22-2009, 04:43 PM   #50
Aerowood's Avatar
Arvada , Colorado
That looks so familiar. I would recommend that you change out that entire rear skin. it would be less work then a skin splice. You get the Aluminum and I'll cut and bend for you. I replaced that with .050
Old 06-23-2009, 07:41 AM   #51
bedfords's Avatar
1975 29' Ambassador
Pics of Progress
Had a chance to snap some pics last night. I'll start with outriggers adds and replacement. Some I salvaged from another trailer (the black ones). Some are new fab'd for me by a true craftsman. And finally I used angle on a few of the solid ones that had rust only on the bottoms.
ID:	82790   Click image for larger version
Old 06-23-2009, 07:50 AM   #52
bedfords's Avatar
1975 29' Ambassador
The back
And now a couple of pics of rebuilding the back end. Notice corrosion of the base c-channel and the new AL angle. See added outrigger at back.
ID:	82794   Click image for larger version
Old 07-30-2009, 07:55 AM   #53
bedfords's Avatar
1975 29' Ambassador
Much work little progress
The month of July has seen me spend many hours on my back grinding and cutting the frame. Every time I look it, the frame, over I see another area that needs to be replace. I have replaced the outriggers at the steps and installed new elevator bolts in floor frame assembly. Monday night I cut off the side "S" shaped rails that hold the water tank up. There is lots of rust between the S and the C-channel. Not sure what the final repair approach will be. Last Tuesday night being fresh out of cutoff wheels for the grinder I spend an hour drilling old rivets out of the frame. Next on the list, if I can get the frame repaired, is sand blast the bad spots, paint with POR-15, insulate and install pan. Then it is inside for replacement of all wall insulation.
Old 07-30-2009, 09:53 AM   #54
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Gawrsh that nice rounded river pebble looks comfy and cool!
A couple of things -
POR-15 likes some rust to bite into.. I used a dilute oven/grill cleaner to get the caustic action going to make it rust and help strip a majority of oil off it but I also let it sit out and weather for a few weeks. Sand-blasting removes too much good metal in my opinion, BE SPARING where you use it - the POR stand for paint over rust, just remove the flakes and scaling that are or about to become loose. If you havent used POR-15 before you are in for a treat
The best way I found to remove the factory asphalt based frame paint remaining everywhere not rusted away was using a 3-inch wire wheel on a compressed air die grinder, beware thrown wires; I wore one for 4-5 days under my skin from lying on one wrongly, taped a magnet over it to get it out. The abrasive biscuits work also but are much slower and load up fast. Did I say beware loose wires? I made up rare-earth magnet broom and religously swept the area everytime I crawled out from under trailer after getting pierced.
The asphalt based paint traces remaining will not solvent wipe away easily - for the important parts (axle plates, F/R exposed frame) I used aerosol carb cleaner but the brown-black paint kept oozing out of the pores of the metal. I ended up over coating some smears, etc and it did just fine.
The ladder frame interior cross member spaces forward of the axle were pristine on my '73 so I used Rustoleum flat-black aerosol there.
I used thinned POR-15 using their solvent (<5%) everywhere else for 2 coats minimum, more coats (4, 5, etc.) where I saw it needed it as I went along. Using a 2" wide brush the extra solvent made it go on easier, cut through any films left after above procedures, and sure stretched the coverage plus helped paint fill the million dimples and pits of serious rust without just forming a bubble that would later pop and leave bare metal.
Getting the second coat on while the first still has some 'grab' to it when you slide a fingertip across it is important, I worked well after midnight using a fluorescent drop light as the only light source and got a paint job 1000% better than I expected. After 2+ years there are only 3 or 4 places where one rust pit did not get filled and has a 1mm rust spot showing.
The first coat fumes are not bad - its when it is firing up to set AND you have to do the second/third coats that it can cause the next day hangover when you've breathed it for 3 or four hours. Stay upwind as much as possible or use a cartridge style respirator.
Well - sorry for the lecture, time to get back to work here... Good luck with the next steps!!
Old 07-30-2009, 10:08 AM   #55
bedfords's Avatar
1975 29' Ambassador
Wabbiteer -Thanks for the advice. I am facing an overwhelming task of getting the frame paint ready. 29' is a lot of surfaces. Did you spray or brush the POR-15? The rocks are too bad. I get a back message for hours and hours and hours and
Old 07-30-2009, 12:34 PM   #56
1975 31' Sovereign
1977 23' Safari
You can brush it. It has great self-leveling qualities.
One of these days I will get up to see you--you'd think Denver was the back side of the moon, or something.
Zep
1975 ambassador
Dove season starts Thursday.. THEPILL On The Road... 15 09-03-2011 05:36 PM
Need help with Armstrong TR 21-12 problems please Top Furnaces, Heaters, Fireplaces & Air Conditioning 51 08-15-2011 10:20 AM
Jim starts the ball rolling JIMandPJ Repairing/Replacing Floor &/or Frame 16 06-21-2011 11:41 PM
Axle Fitting in Reno (NV)??? Yomster Axles 7 03-29-2011 03:03 PM
