Old 11-17-2008, 12:00 PM   #15
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
More pics
I can hardly live with myself - throwing all these little guys out and it is so close to the holidays. But before you pass judgment I have been warning them all summer. Blame it on the economy.
ID:	71455   Click image for larger version
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 11-17-2008, 12:21 PM   #16
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Sir, you have my deepest sympathy; I too suffered as my AS also displayed dung-dunes in the duct work and vermindiums everywhere... I found the greatest hidden space to radiate odor is the freshwater tank basement; I hope you drop that ASAP and paint and seal the underside of flooring, spars and tank bay floor plywood areas... Beyond that, painting the undersides of galley shelves and countertop will inhibit more smells as will washing both sides of liners with the cleansers of you choice... Good luck to you.
Old 12-10-2008, 09:02 PM   #17
bedfords's Avatar
1975 29' Ambassador
Thumbs up No more rats nest!!!
I finished dropping the pan and cleaning out the under cavity this weekend. The plan now is to have a friend come over with a smaller welder and material. It looks like all of the outriggers will need to be replace and some of the main rail. Then its time for Por-15 install new floor section in back and start putting things back together. If it where only that easy. Winter has set in 14" last week see pic. with another 11" this Monday. No complaints here the weekends have been nice enough to crawl under the trailer. Life is good.
Old 12-10-2008, 09:40 PM   #18
bedfords's Avatar
1975 29' Ambassador
Decorating the Tree with AS
A custom made AS ornament my honey had made for me.
Old 12-11-2008, 06:34 AM   #19
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I,m going to try getting some more metal work done this weekend too, hope the weather holds.
Old 12-11-2008, 11:59 AM   #20
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Hey Bedford, Not so much snow this side of the mountains, but I'm about to start ripping my rear end out too. At the end of the month.. Keep us posted.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-17-2009, 05:09 PM   #21
bedfords's Avatar
1975 29' Ambassador
Colarado Weather is GREAT!
OK so it has been a while but things are moving along around here. I borrowed a pressure washer to clean the underside. I had so much fun I washed the inside as well. The smell is a little better. I am still fearing the interior walls will need to come down and replace insulation. But for now I am focused on frame repair. Most all of the outriggers are rusted on the bottom which leads to a problem of what is supporting the walls and roof? Not much. The floor is frowning. I put a 4' level across the floor to see how bad a drop it is. There is 1/2" to 3/4" drop from the center to the exterior wall. So what to do? I happen to have 9 outriggers laying around that will be welded in. I am also thinking of using angle iron welding to the top flange of the existing outriggers, then drop down at an angle and attach to the frame? Oh and before adding any new support I will level the frame and then lift and support the edges. I might go as far as lifting the edges more than level and then weld in new riggers and angle. Any words of wisdom? So tomorrows plan is to get everything level and prep-ed for welding.
Old 01-17-2009, 05:26 PM   #22
bedfords's Avatar
1975 29' Ambassador
Items For Sale
I am needing a little help with posting some items on the Air Classifieds.
I have some things that I have been holding onto just incase. I am seeing a large putchase of two axils in the near future and thought maybe I could help some of you and get a little help in return. I have the following items from a 1972 Overlander that I am planning on posting on the classifieds but have no idea what a reasonalbe price would be. So here you go.
I have pictures of everything. Keep in mind this stuff is all used.
Black Water Tank 20 gal
Fresh Water Tank45 gal
Battery Storage complete w/Frame
Kitchen Sink
complete sky light
Front Single Pane Window43x24
Small low window w/molding21X10
Large Low window w/molding33x10
Compartment Door w/Frame20X14.5
Door Eye Brow
Back flat window w/screen frame43x24
Side curved window w/screen frame30.5x22.53
Screen Frames30.5x22.5c
omplete back bath
Frig Vent cover
Frig Vent Frame
Back Lights w/interior covers
Range Vent Cover
Door Light cover
Back interior Cap
Front Interior Cap
Rear Exterior Panelsx5
Front Exterior Panelsx4
Back storage cover
Interior cover plates
Front reading lights
Wide exterior molding
ID:	74152   Click image for larger version
Old 01-17-2009, 05:39 PM   #23
bedfords's Avatar
1975 29' Ambassador
few more pics
I am not looking to get rich just help pay for some repairs.
Name:	storage door sm.JPG
ID:	74154   Click image for larger version
Name:	v door sm.JPG
ID:	74156   Click image for larger version
Name:	over head lgt sm.JPG
Old 02-11-2009, 10:18 PM   #24
bedfords's Avatar
1975 29' Ambassador
Question on outriggers?
I am not moving forward as fast as I would like. But that is OK I am not in a big rush. I didn't get any feed back on my approach to the bow on the edges of the trailer. Has anyone had to beef up the outriggers or will the replacements everything level?
Old 02-11-2009, 10:45 PM   #25
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You can buy outriggers from Out of Doors Mart for about $15 each. I've got a box of them out at the Safari, and for the life of me I can't remember if the outer end of then has the curve. I think they do. But I won't be back at the Safari for a week.
Zep
Old 02-11-2009, 10:47 PM   #26
imeynstein's Avatar
Texarkana , Arkansas
Hey!! I am interested in the following:--freshwater and blackwater tank--freshwater pump if you have them...please let me know!!!
imeynstein
imeynstein is offline   Reply With Quote
Old 02-11-2009, 10:51 PM   #27
imeynstein's Avatar
YIKES!!! The frame is SCARY as I may have to replace mine during my renovation process...Please post photos and 'how to's' as I will need step by step instructions!! My husband will NOT be helping me as he made it CLEAR that my AS is MY project, so keep any photos and instructions available!!! THANKS!!!
imeynstein
Old 02-12-2009, 06:28 AM   #28
bedfords's Avatar
1975 29' Ambassador
Black and Drinking Water Tanks
Hey!! I am interested in the following:--freshwater and black water tank--freshwater pump if you have them...please let me know!!!
imeynstein
The first thing to make sure is will the tanks work for you. I am not sure personally but someone out there will know. I can tell you that the water tanks on my 72 and 75 are the same. The black water tanks are not. The tank in questions comes out of a rear bath configuration. Let me know if they will work. If so I am heading to Oklahoma mid April I would be able to get them at least that far. I don't have a water pump. They aren't all that pricey. I would suggest going new.
1975 ambassador
Dove season starts Thursday.. THEPILL On The Road... 15 09-03-2011 05:36 PM
Need help with Armstrong TR 21-12 problems please Top Furnaces, Heaters, Fireplaces & Air Conditioning 51 08-15-2011 10:20 AM
Jim starts the ball rolling JIMandPJ Repairing/Replacing Floor &/or Frame 16 06-21-2011 11:41 PM
Axle Fitting in Reno (NV)??? Yomster Axles 7 03-29-2011 03:03 PM
