Old 04-16-2013, 07:39 PM   #1
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
'74 Ambassador Needs Water Pump
We finally decided to tackle the white tank repair and plumbing before our first trip this spring.
After running some new plumbing, both copper and automotive-style rubber tubing, we discovered that our water pump, which is original part number 36800, was leaking due to a very large crack that ran through the entire base.
I plan to order a ShurFlo 8125 pump from Out-of-Doors Mart tomorrow. Any thoughts on this or recommendations?
After discovering I have no talent for sweating copper pipe, we hired a legitimate (and quite reasonable) plumber to come and do the work. He seems to quickly figure things out, where I would struggle forever and a day and make costly mistakes.
However, before I have him come out for another session in a couple days I would like to know if the ShurFlo is the right / best choice.
The only other challenge I have is that the small in-line water pump filter assembly with mesh screen had a cracked top, which is made of clear plastic. Does anyone know if this original part is still available from Airstream, or if there is a replacement that makes sense?
Thanks!
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Erik Olson is offline   Reply With Quote
Old 04-16-2013, 07:45 PM   #2
1974 Argosy 20
Kooskia , Idaho
The Sur Flo is a very good pump and was a good choice. The filter/strainer you need can be purchased at any decent RV parts store. They are common. Just ask for a water pump strainer. Brand is not important.
Old 04-16-2013, 07:51 PM   #3
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Thanks! Do you suppose there is a complete replacement for the pump filter assembly? Our clear dome (the part held in place with the top screw) is cracked top to bottom.
Erik Olson
Old 04-16-2013, 08:09 PM   #4
Thanks!
Attachment 183539
Your original water pump is far superior to a Shurflo.
All you need to do, is rebuild it.
Parts are available.
So, it lasted almost 40 years. WOW
Old 04-16-2013, 10:37 PM   #5
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
I had no idea! The Airstream service manual refers to the [cracked] base as part 5625 "Base" on larger model 36800. Are these items available a la carte?
What other parts would be typically ready for a refresh? Assuming items like Dampeners, Diaphragm, Belt (all found in Service Kit 30122)?
Thanks!
Erik Olson
Old 04-17-2013, 11:14 AM   #6
Thanks!
Attachment 183555
Unfortunately, the base is not available.
The only way it could crack,is if it froze with water in it.
Old 04-17-2013, 08:26 PM   #7
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
The PO told me they could not resolve the leaks that came when running the white tank system.
Perhaps it had cracked during one of our rarer and rarer NC cold snaps.
A Revolution 4008 is being installed tomorrow along with a fresh ShurFlo pump filter at the pump head. $100 well spent if I get some leak-free years of boondock water from these retrofits and upgrades.
Erik Olson
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Interstate Water Pump VAinterstate Fresh Water Systems 5 06-15-2011 08:12 AM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 01:15 PM
