09-29-2017, 06:55 PM
1977 29' Ambassador
Union
, Mississippi
1977 29 ft. Ambassador
What size AC unit did these come equipped with? Going to have to replace mine, it is the original that had cooling and heating capabilities and wondering what BTU rating to use. Any help appreciated.
10-21-2017, 04:08 PM
1977 29' Ambassador
Union
, Mississippi
Do not think anyone knows the answer to this ....sooooo will replace with 15K btu,
thanks for looking. Consider this thread closed.
10-22-2017, 06:40 AM
1977 31' Excella 500
West Sacramento
13,500 in my 31' but I would replace with 15,000
10-22-2017, 08:19 AM
1977 29' Ambassador
Union
, Mississippi
Thank you
11-10-2017, 07:19 AM
1977 29' Ambassador
Union
, Mississippi
Working on ac now.
Does it damage the roof to work from standing or sitting on it. Have a 1977 29' ambassador.
Will be working on ac unit and do not want to cause any leaks in roof. Going to troubleshoot AC problem and make sure it needs to be replaced.
11-10-2017, 07:09 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hi Katman104: I wanted the Ambassador, but ended up with a 75 Overlander. Oh well.
Yes, you can easily damage the roof by standing on it. It is just .032 thick aluminum sheeting.
That said, you know the shell is built like an old airplane fuselage. It has ribs about every two feet. You will see the vertical row of rivets that attaches the skins to the ribs. Once the skins are all riveted to the ribs and crossmembers, it really becomes quite strong.
I replaced the AC unit on my 86 Airstream. If I recall correctly I put an old piece of carpet down, then a couple of 2x6s along the ribs of the roof close to the AC. Then I put a piece of plywood over the 2x6s making kind of a bridge between ribs where I needed to put my weight. The awning seemed to hold the boards from sliding off. The AC is pretty heavy, about all I wanted to lift.
So be careful up on the roof or your body weight will dent it for sure. Note: The end caps of an Airstream are especially fragile. Never step on an end cap.
David
11-10-2017, 08:12 PM
1973 23' Safari
1970 27' Overlander
Boerne
Just be sure to stand over the ribs and you will be fine.
11-11-2017, 09:21 AM
1977 29' Ambassador
Union
, Mississippi
David
Thanks for the info much appreciated
11-11-2017, 09:22 AM
1977 29' Ambassador
Union
, Mississippi
Thanks for the information.
