Old 08-17-2019, 08:40 PM   #29
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Quick question, anyone know what these brackets were used for?
There are four of them. I am thinking they were for privacy curtains. It's the only thing that comes to mind. Click image for larger version
Swrider is offline   Reply With Quote
Old 08-18-2019, 03:20 AM   #30
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Those brackets are part of bunk bed hardware.
Too bad the rest isn’t there. Don’t ditch those someone will want them.
Ian
Iansk is offline   Reply With Quote
Old 08-18-2019, 03:20 AM   #31
Iansk's Avatar
1977 31' Sovereign
Ian
Old 08-19-2019, 09:10 AM   #32
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Ian
Actually I probably do have them somewhere, I had a couple of things that look like stretchers, they were probably for the bunk beds.
Old 08-19-2019, 09:16 AM   #33
Iansk's Avatar
1977 31' Sovereign
Aside from the frames, there should also be what look like towel hooks that the frame would sit on and either aircraft cable or grip chain that hooks into the above apparatus.
Ian
Old 08-19-2019, 11:59 PM   #34
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Ian
I'll see what i find and take some pictures of it.
Not much progress the last couple of days. It's still pretty hot outside, which means inside the trailer is stupid hot. But some progress none the less. So far the floor seems to show signs of water staining, but still looks solid, no noticeable rot, and not bouncy/squishy. Will keep fingers crossed.
Also, you will see in one of the pics, the exterior compartment door is partly covered by the interiod skin. Thats just weird. Oh well.
I think that going forward i will use this post for the main restoration progress and comments and general questions, but i will also go to thw more specific forums for other questions, as in, how to test a refrigerator, or how to wire a fan. That kind of thing.
Is there a way to link posts asked elsewhere to this post???
I'm hoping that tomorrowni get to start in on the bathroom!
Anywho, to the pictures...
ID:	349966Click image for larger version
ID:	349967Click image for larger version
Old 08-20-2019, 09:56 PM   #35
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Another, well, something else was done. I was doi g pretty good tearing into the bathrm until it was time to take the tub off and realized that i somehow have to disconnect it from the drain. Stumped.
Only way i see it coming off is to open the outside compartment door, reach in and unscrew it...
I'll have to check the manual and see what it says, but for now, its too dark and im too tired.
But on a good note, so far i haven't found any floor rot. Even looking down the back of the trailer i can see nothing. So keeping.my fingwrs crossed.
ID:	350064Click image for larger version
ID:	350065Click image for larger version
Old 08-21-2019, 07:34 AM   #36
Iansk's Avatar
1977 31' Sovereign
I think if you post everything here on this thread as a general repair/restoration thread that would be the best way to keep track of everything.
Your tubs drain should unscrew from the top, you may need to make some sort of spanner to unseat it. It’s probably pretty stuck on there from years of being stuck on there.
That’s great you’re finding so little floor damage, kind of amazing actually.
That interior partial skin cover is indeed strange. I wonder if your trailer was made right before a holiday and the workers had other things on their minds...
Ian
Old 08-22-2019, 05:49 PM   #37
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Hey Iansk, it probably was made during the holidays
So progress was maxe yet again, the bathrm is gutted and i managed to save all the pladtic pieces incase we decide to use them again. The toilet came out after i fugured out those two bolts that hold it in place. The flange, on the other hand, is a different story. Seems like it screws into the tank, which sucks because i haven't been able to budget it.
Anyone out there have any thoughts???
Well as far as gutting it goes, i think i am at the stoping point. After removing everything i have i don't see any floor rot. Stepping everywhere seems solid and i don't see any seperation of frame anywhere. I will leave pics below so that someone with more experience can comment, but i think moving forward, i am at the stage where i start cleaning everything out, painting and verifying what works and what should be updated.
Anyone.have any thoughts on where i should proceed from here???
ID:	350192Click image for larger version
ID:	350194Click image for larger version
ID:	350195Click image for larger version
ID:	350196Click image for larger version
Old 08-22-2019, 06:29 PM   #38
Iansk's Avatar
1977 31' Sovereign
Make another spanner for your toilet flange, some 1/4-20 bolts should work through a 1x2. It’s how I got mine off.
Is everything labeled? Even if you don’t plan on reinstalling you should label and store for future reference.
Even though you say there is no rot, there are some suspect areas in the pics. Take an awl or an ice pick (who has an ice pick anymore?) and probe those areas that look funky and anywhere around the perimeter. If indeed you have no rot, proceed to double checking and sealing any and all exterior penetrations to keep things like they are.
Go buy a sh!t ton of cleaning supplies and go to town on the interior skins and floor.
Then go get a bunch of high quality paint supplies and start prepping.
Don’t jump the gun on actual paint, prep takes a lot longer than painting and it’s better to have the paint freshly shook when actually dipping a brush.
What do you want to do next? This is your lounge area right?
Ian
Old 08-23-2019, 11:24 AM   #39
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
So the plan is, after talking it over with the wife:
- start cleaning/prepping for paint
- Remove all light fixtures and upgrade to led's
- Jump on roof and start sealing all vents
- Replace roof vents with working units
- Figure out why the AC is not working
- Seal up the Ambassafor to keep water out
I could go on and on, but that list will probably keep me busy for the next month!
A quick pic of the roof. Not too bad, but needs tlc.
On a related note. Anyone know where i can get a new shroud for my AC?Click image for larger version
ID:	350257Click image for larger version
ID:	350258Click image for larger version
Old 08-23-2019, 12:11 PM   #40
Iansk's Avatar
1977 31' Sovereign
Is that an old Armstrong unit?
If it is, my buddy and I just removed one off of his '78 Avion. It works and the shroud is in good shape.
The Armstrong units are known to be pretty bulletproof. The capacitor is the first thing I'd check after ensuring you are getting power up there.
Ian
Old 08-23-2019, 09:53 PM   #41
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Inland sells a replacement Armstrong shroud for—hold on to your wallet—$500.
https://inlandrv.com/product/part-69812/
TheGreatleys is offline   Reply With Quote
Old 08-24-2019, 11:59 PM   #42
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
For a fracking shroud!!!
Thats bananas!
I think that it is an old armstrong unit. Only thing i know for sure is that the PO started it up and it blew air, it just wans't cold.
Wow! What did I get myself into? Meeker Member Introductions 25 01-23-2010 10:07 AM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Did You Persuade your Mate into an Airstream? Communicator Member Introductions 34 08-16-2007 10:49 AM
How did you get into camping? yukionna Our Community 51 07-23-2007 12:54 PM
