Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1970 -1973 Ambassador
Old 08-06-2015, 02:24 PM   #1
1972 29' Ambassador
East Moriches , New York
Shower Faucet
So, While re-doing the systems in our 1972 Ambassador we have decided to replace all the copper with PEX. Now mind you the RV repair place is doing most if not all of this, As I am working and we want to get this done by someone with much more know how than myself.
I do like to help, facilitate parts, etc ... And I've done much of the cosmetic work. But mostly want to have the major things checked and done by a professional. We need a new water heater, gas valves, etc ...
Since there were many splits in the copper we needed to replace with PEX. So we also now need a new shower faucet. The old one appears to be a MOEN or very similar, SINGLE HANDLE with a mixer valve. The valve was supported mostly by the ridged copper pipes. And a new one could not be located in a timely fashion So I am opting for just getting a common one from Home Depot. (Photo Below). Since the panel on the side of the shower/Tub is now removed I made a Square out of plywood, 8"x8" and drilled holes out for the valve (See photos) and mounted it to the wood. then using SHARK BITE fitting will attach the PEX. this play wood can be glued or screwed to the back of the existing panel and thus give the needed support.
I think this will work and can be done with any similar valve. IF you cant get a original, at least you can get a mixer type and maintain the look and appearance of it.
I will get more photos when completed.
Name:	GLACIER BAY FAUCET.JPG
ID:	244743   Click image for larger version
72TINCAN is offline   Reply With Quote
Old 08-06-2015, 06:38 PM   #2
Mission , Texas
I recently ran PEX in our 75 Overlander rear bath, but no shark bites, all clamps. I used a Delta faucet in the shower and modified the face trim plate as necessary, no plywood; worked good.
nrgtrakr is offline   Reply With Quote
Old 08-07-2015, 05:32 AM   #3
1972 29' Ambassador
I was just reading some of the suggested links ... I bought a TUB,SHOWER valve and was going to put the plug on the bottom and use the shower out let ... but after reading those other post I will change the direction and put the plug on top and use the tub out let ... that way water will drain out when its off ... better for winter and long sitting periods ...
The valve I bough was also pretty heavy ... the panel did not give much support ...
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 08:54 PM
Shower faucet Philip Williams Sinks, Showers & Toilets 11 02-09-2007 06:55 PM
Shower faucet replacement racoco 1974 - 1979 Sovereign 6 10-30-2006 02:38 PM
Shower faucet repacement gergstuff All Argosy Trailers 4 08-02-2006 11:41 AM
Shower Faucet Howard Lefkowitz Mechanics Corner - Engines, Transmission & More... 2 08-30-2004 02:39 PM
