Old 06-24-2010, 03:43 AM   #1
1973 29' Ambassador
Anchorage , Alaska
Quick redo - 1973 Ambassador!?!?
I am currently working on my 1973 29 foot ambassador. I have pulled everything out of it and going to put it back together to live on some property. It will probably only see the road being transported from one property to the next.
ID:	105507   Click image for larger version
akmntman is offline   Reply With Quote
Old 06-24-2010, 07:02 AM   #2
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
Welcome to the forums. There is alot of information here regarding redoing the inside of AS.
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 06-24-2010, 07:05 AM   #3
Ottawa , ON
Welcome to airforums.com!
Recommend you keep everything you took out, since even if you don't use it in your trailer again, others may value something you have.
Even more likely, you yourself may need the old parts to serve as a template for new ones you make.
Old 06-25-2010, 03:30 AM   #4
1973 29' Ambassador
Anchorage , Alaska
I have everything piled up around the outside, I really wish the floor was in better shape for a template. I just fitted the ends this evening will seal every edge I can this week and put the rest of the floor in next week.
Old 09-18-2010, 01:32 AM   #5
1973 29' Ambassador
Anchorage , Alaska
Its been awhile since I have posted, but I have been working on the Airstream alot, to much, my OCD is going crazy, and finally I have started to put it together. welded frame, patched skin, new wood floor and currently insulating and washing an putting up walls.
ID:	110993   Click image for larger version
ID:	110995   Click image for larger version
1973 ambassador
