Old 04-30-2012, 09:01 PM   #1
tarheelbornbred
tarheel1972's Avatar
1972 29' Ambassador
Wilmington , North Carolina
Send a message via AIM to tarheel1972
Leaking Water Heater 1972 Ambassador
I bought my '72 Ambassador in August of 2010 and have lived in it 14 months, "work timing" since then. I just started another stint that will last until November.
Well the old girl, almost all original, is starting to show here age.
I have a leak in the back, that I suspect is the water heater. Hopefully it is just a toilet connection. I plan to shut off the (replaced when I bought) toilet this weekend and see if the leak persists while I'm gone. There's carpet throughout, and moisture is seeping up from between the toilet and the hatch that holds the water heater.
None-the-less, I'm into replacing floor back there that is getting soft.
Can someone tell me about replacing the water heater?
Thanks.
John
tarheel1972 is offline   Reply With Quote
Old 04-30-2012, 09:08 PM   #2
Thanks.
John
Easy job, if you stay with the same brand and the 10 gallon size.
Old 04-30-2012, 09:20 PM   #3
1974 Argosy 20
Kooskia , Idaho
Water heater replacement is not too difficult in general. You first have to disconnect the hot and cold water lines, and that assumes you can get to the back side of the heater (from the inside of the coach). If everything is original, you will be dealing with copper lines and flare connections most likely. Then from the outside you remove the propane line, another flare connection. The water heater you will get is the same unit in size and everything else other than the propane connection which will be in a different location. You will need to decide if you wish to use the new location and re route and replace the original propane line, or if you want to try to drill a hole in the new unit, where the old one came in. You will also have to decide if you wish to remain with a pilot light type, or switch to a new electronic ignition type (I vote for electronic ignition).
Then you will unscrew all the screws from the outside flange, and inserting a putty knife cut the original sealing material all around. That will be your hardest job, and it is helpful if someone is inside pushing the heater out, while you cut the sealant free.
Then it is a matter of just putting the new one in place with new sealant tape and screws, hooking up the propane line (see above) and the water lines from inside. If you go with electronic ignition, you will have some wiring to do from the heater to the switch, and you will need a source of 12 volt power for the supply.
Lining up the pipes inside can be a challenge. You might want to change the hookup to something easier, such as PEX if you run into problems.
Old 05-02-2016, 04:07 PM   #4
tdveal's Avatar
1972 29' Ambassador
Sherwood , Oregon
Water Heater Replacement
Thanks for this post. It was just what I needed.
tdveal is offline   Reply With Quote
Old 03-27-2018, 04:16 PM   #5
1972 29' Ambassador
AUSTIN , Texas
Appreciate the level of detail here!
Krisaloha is offline   Reply With Quote
1972 ambassador
