Old 07-18-2008, 09:23 AM   #1
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Ambassador Awesomeness - 1972 Redux (picture heavy)
One fine day in June 2007, I bought my lovely Airstream with the idea I'd have it rebuilt and then take a shot at fulltiming. Naturally, it needs A LOT of work, and I have a lot to learn (that's why I'm here, after all!). But finally, progress...
As found:
Work with my contractor started in February 2008. The frame was immaculate in the front & middle, & all kinds of scary in the back (see below).
That was cleaned, repaired & coated. A lot of little things were fixed to get it registered proper. Have new plywood flooring down.
She is a rear bath model, and I think I'm the only one on the planet who WANTS a rear bath. I love the idea of a tub and for me it's worth the space it takes up. However, the 40-some inch stock tub is practically useless.
My new tub/shower is here, but not installed yet. I went with a fiberglass 54" mobile home unit from American Standard which is far more usable, and will be using some badarse antique brass shower fixtures from the 1890s I got on eBay - the big raindrop showerhead among other things. The one pipe has a small hole, and good lord is it hard to find brazers! But I found someone to tackle that. The rest of the fixtures are presently in the shop getting polished.
I also got some fun towel racks & TP roll holder which are off being brass plated to match. I figure I might as well go all the way!
Which means, I also got little brass claw feet to attach to my bathtub, just for kicks:
Today begins reinsulation behind the back endcap. I'm trying the 2 layers of bubble foil method, but that's for another post.
BrockLives is offline   Reply With Quote
Old 07-18-2008, 09:30 AM   #2
cameront120's Avatar
1972 25' Tradewind
So you're going for a 'Victorian Twinkie' design motif?
North Vancouver, BC
Old 07-18-2008, 09:36 AM   #3
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Thumbs up Nice thread, very cool fixtures Brock!
Can't wait to see more pix!! Good luck with the project!
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 07-18-2008, 09:43 AM   #4
BrockLives's Avatar
1972 29' Ambassador
I am, Cameron! Though it's probably going to be a bit on the anachronistic side as I do love gadgets..
Old 07-18-2008, 10:26 AM   #5
1972 25' Tradewind
Can't wait to see the world's first Gothic Airstream!
North Vancouver, BC
Old 07-18-2008, 10:33 AM   #6
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Victorian Twinky! I'm still laughing.
LJH is offline   Reply With Quote
Old 07-18-2008, 10:35 AM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Same here. Can't wait to see how this one turns out!
www.nesa.org
Air No. 6427
Old 07-18-2008, 11:31 AM   #8
Before you toput your budget, you should check out your axles.
Since it appears that your trailer is at least partially gutted, and looking at the axle position in your photo, replacements are in order.
1974 and older axles, all will fail, in time due to the wrong composition of the rubber rods.
Old 07-18-2008, 12:14 PM   #9
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Arrow ponder this but don't fret
Brock not to rain on anyone's parade, but...
More Tub = More Water = More Weight
add additional weight of new tub and brass fixtures ,add your weight, add weight of bar of soap and rubber duck.
Divide by no grey water tank.
Equals lots of fullness in Black Water tank.
Not sure if draining tub into a near full tank would push effluent back up into toilet or not. Someone here prob can answer.
Be careful, Block Well, Empty Often
and never, never bathe with a friend, not even in Virginia at least in that rear bath Airstream.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 07-18-2008, 12:23 PM   #10
1972 25' Tradewind
Does the grey water go into the black tank? I was under the impression that it didn't. If I block the grey water drain, grey water backs up into my shower pan. I connect my grey water to sewer and let it drain.
North Vancouver, BC
Old 07-18-2008, 01:26 PM   #11
1972 29' Ambassador
Harrah , Oklahoma
You are correct.
Grey water and black water are usually separate tanks. There are however some modern manufacturers that 'economize' and have a single tank for both. The 72 ambassador has blackwater tank only, greywater drains straight out w/ no tank.
The problem is, what happens with one of those single combo tank setups get full and back up?
That's right, poopie in your sink, or at your feet when showering. Not very sanitary.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 07-18-2008, 03:02 PM   #12
1975 31' Sovereign
Houston , Texas
Arrow
Originally Posted by airbassador View Post
You are correct.
See I told Brock not to fret.. Actually I thought the tub went into the black water in pre 1974 Airstreams with rear baths. I thought just the galley drained outside direct. I stand corrected.
I too would love to replace the useless tub with not a bigger tub but a tighter shower-only stall to give me a little more storage area in my 75 rear-bath.
Actually a decent shower curtain idea and a better shower head design will make the minature tub work fine as a shower pan. And the tub occasionally serves other purpose to either wash such as kids & pets or large items, or to store things but I'd prob have to call 911 to get out of it if I ever sat down there.
____ d'drummer ____
Old 07-18-2008, 08:29 PM   #13
1972 25' Tradewind
This is why I like the rear wet bath in my '72 Tradewind. I can stand full height and have lots of room to shower. All 6'-3" and 240 pounds of me! Cleaning it is pretty easy too. I'm really liking living in this trailer.
North Vancouver, BC
Old 07-23-2008, 08:32 AM   #14
BrockLives's Avatar
1972 29' Ambassador
Andy, when is the easiest/best time during construction to replace the axles?
I put in a grey tank & new black tank (28 gal each) w/ box as that was ridiculously rotted out.. but yeah, the original grey water was set to drain out a pipe in the back Another thing is, the original tub had no insulation under it whatsoever - changing that.
Never?
Can't we make an exception..?
1972, 1972 ambassador, insulation, rebuild, rear bathroom
1972 Ambassador Furnace tdveal General Repair Forum 2 03-29-2008 03:59 PM
New Members and Owners - 1972 Ambassador tdveal Member Introductions 10 02-28-2008 07:23 PM
My boy Kai turns three today! (Picture Heavy) cameront120 The Pet Forum 9 06-07-2007 09:20 PM
Cabinets 1972 Ambassador 31 ft Alex Cabinets, Counter Tops & Furnishings 2 11-29-2003 11:58 PM
