Old 07-15-2010, 11:09 AM   #29
Dillon , South Carolina
I am in the process of buying a 1972 Ambassador. The PO tells me that the electric brakes are not working. How do I correct this problem? Also what should I be looking for to determine if the axles need to be replaced?
All suggestions are welcome.
Rodney
urb2165 is offline   Reply With Quote
Old 07-15-2010, 11:19 AM   #30
Rodney
Rodney.
Reading the "Dura-torque axle" article in the Airstream Central part of this Forums, will tell you how to check the axles out yourself.
Old 07-15-2010, 11:25 AM   #31
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Rodney
The brake issue could be something as simple as bad wiring (short or open). Inspect the wiring to see if it looks good. If all appears good, then take a voltmeter to your brake lines when you have the brakes applied. That should tell you a lot right there. If you have good voltage then your brake might be siezed.
As for bad axles, generally you can determine a bad axle on a '72 if the top of the wheel well covers a portion of the wheels/rims. Post a picture of your Ambassador and we can help you out.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
1972, 1972 ambassador, insulation, rebuild, rear bathroom
1972 Ambassador Furnace tdveal General Repair Forum 2 03-29-2008 03:59 PM
New Members and Owners - 1972 Ambassador tdveal Member Introductions 10 02-28-2008 07:23 PM
My boy Kai turns three today! (Picture Heavy) cameront120 The Pet Forum 9 06-07-2007 09:20 PM
Cabinets 1972 Ambassador 31 ft Alex Cabinets, Counter Tops & Furnishings 2 11-29-2003 11:58 PM
