Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1970 -1973 Ambassador
Old 11-09-2010, 05:32 PM   #1
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Abby gets all the attention
Hello Y'all,
Here are some pics of the Airstream we are buying. The interior is all original in very good condition for being 38 years old. The exterior is mostly good except for a few skin problems and some heavy frame corrosion under the rear bath. The right front was damaged when a tree fell on it. The panel was replaced. Looks like a "Hack Job" to me. The right front window has water between the panes. I'm not sure how to repair this window. I'm sure someone will tell me to replace the axles!
ID:	114859   Click image for larger version
ID:	114861   Click image for larger version
ID:	114863   Click image for larger version
Lance M is offline   Reply With Quote
Old 11-09-2010, 06:47 PM   #2
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
Welcome to the forums, and enjoy your new-to-you trailer.
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Old 11-09-2010, 09:16 PM   #3
funkill's Avatar
Tucson , AZ
Images: 27
Originally Posted by pb379_2010 View Post
Hello Y'all,
You can count on it ... and then some.
I added some of those jelly-window sticker things above my window water line. Nice undersea theme goin' on. Make the most of it
Laura
funkill is offline   Reply With Quote
Old 12-09-2010, 03:56 AM   #4
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Back at home
Well we finally got Abby back home from the RV shop here in town. They just did an inspection for me to make sure I wasn't in danger of killing myself or someone else. Her are there findings;
Stove=checked OK
Oven=checked OK
Refrigerator=Checked OK on gas and electric (flint lighter rusted)
Water Heater=pilot will not light. (they recommended a new water heater for $800!)
Battery=will not hold a charge. Installed new Interstate deep cycle marine group-27
Wheels, tires, brakes and axles=checked. They installed new backing plates and magnets.
Plumbing=leak under street side twin bed-repaired
Total bill $717
When I got home I checked everything again and found;
water leak under the sink from fresh water tank vent tube line.
water leak from fresh water drain valve soldered joint at the rear of trailer.
Repairs-
I purchased a new pilot and thermocouple, gas control and burner from Crestview RV in San Antonio. I installed the new pilot and tc and got it to light. The burner lights when the valve is turned to "ON" burns for a minute or two, then I hear a click and the gas shuts off and flame goes out including the pilot. Any Ideas?
I spent the day cleaning. Lots of cleaning. Mud daubers and rodents can reek havoc on a trailer.
I've been using Krud Kutter to remove the sticky stuff from the interior walls. Seems to be working well. I think I need to increase the mix ratio to 2:1.
One more day of repairs and cleaning, and we're headed out for her maiden trip. I hope I can get it all done in time!
Lance
Old 12-09-2010, 05:47 AM   #5
x
XXXX , XXXX
Lance if you replaced both the thermocouple and the pilot. Make sure the pilot flame is bathing the thermocouple and check to amke sure your connection of the thermocouple to the gas valve is tight. If both are good then it sounds like the spring in the gas valve is weak and if you have already bought it, go ahead and install it.
wasagachris is offline   Reply With Quote
Old 12-09-2010, 07:22 AM   #6
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Lance, I had a similar problem with my water heater...Here is what I did:
Open the access door to the water heater
Remove the pilot and main burner assembly from the thermostat
Place a piece of cardboard from the edge of the water heater to over the outer lip so water can flow out of the compartment
Take 3 screws off the exhaust cover screen and remove the screen assembly
Try to remove as many nests and blockages with a shop vac from the exhaust side and the intake side of the burner area before running the water hose
Finally, start spraying water into the exhaust side of the water heater until it flows freely and clear out of the intake side
Re-install the pilot and burner assembly
Re-install the exhaust screen
all done...Mine worked...hope yours does too.
Tharon
mopariac is offline   Reply With Quote
Old 12-09-2010, 08:29 AM   #7
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Mopariac. I'll give it a shot!
Lance
Old 12-13-2010, 03:59 AM   #8
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Our maiden voyage was a success! It is amazing how wonderful an Airstream is from 1972! Everything is working, including the hot water heater! We came back yesterday afternoon from the Blanco Rally. We met some of the nicest people on this plant I believe. Can't wait for more great times in the future!
Lance
Old 12-20-2010, 12:57 PM   #9
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
The long process of repairing all the leaky spots is now under way. I started with the bathroom window. I'm updating to the newer D shaped weather stripping. It is evident that this trailer had/has leaks. The window and screen frames are all pitted from corrosion. Here are a few before and after pictures
ID:	117389   Click image for larger version
ID:	117391   Click image for larger version
ID:	117394   Click image for larger version
Lance
Old 12-20-2010, 01:30 PM   #10
dznf0g's Avatar
Oswego , Illinois
Hello Y'all,
Lance,
I really don't want you to be disappointed so......... don't forget to replace those axles, those aquarium windows are heavy and probably have caused the axle rubber to take a set!
Old 12-20-2010, 02:08 PM   #11
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
What are you doing with the frame corrosion?
Hello Y'all,
Just wondering if you have tackled the corrosion in your bottom picture.....pj
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 12-20-2010, 02:32 PM   #12
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I plan on tackling the rear end separation problem after the first of the year. I have a bunch of preparations to make before I tear into the bath. I will post my progress or lack thereof on this thread. until then, we're going camping!
Lance
Old 12-20-2010, 03:09 PM   #13
SteSpot's Avatar
Going Camping sounds good
That sounds like a great plan to me......let us know where you go....pj
Paula & Ed
Old 12-21-2010, 07:36 PM   #14
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Working on some window weather proofing
Well, there are a lot of windows in a 1972 Ambassador. Today i successfully removed all the old Vulchem and did a little polishing around the frame and re sealed with Sikkaflex 221 ONE window! It took about five hours. Here's what the old stuff looked like..Click image for larger version
ID:	117519Click image for larger version
And when I had it all cleaned ready to apply Sikkaflex...
ID:	117521Click image for larger version
ID:	117522Click image for larger version
I then taped it up so I didn't get it all over the place..
ID:	117526Click image for larger version
Her's what the final sealant looked like. If it leaks, uh...well I'll just have to live with it!
ID:	117528Click image for larger version
Lance
Old 12-21-2010, 08:00 PM   #15
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Polished some Aluminum with MET-ALL
Here's are some pics of the light cover that I polished this evening. Cast Aluminum is sometimes difficult to polish effectively. I used a 3M Roloc abrasive disk 120 grit to remove the surface corrosion then used 220, 400, 800 and 1000 wet/dry sand paper. I used a cotton polishing wheel with some MET-ALL aluminum polish I bought at Camper Clinic II. It took about 30 min. Click image for larger version
ID:	117535Click image for larger version
ID:	117536Click image for larger version
Lance
Old 12-21-2010, 08:09 PM   #16
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Amazing work.
Harker Heights isn't so far. If you'd like an extra set of hands working on that rear end in the Spring, I would be happy to help.
TX-16
Dave Park is offline   Reply With Quote
Old 12-21-2010, 08:17 PM   #17
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Dave, Thanks for the offer! I have been wondering how to approach you for some assistance. I guess you solved that for me. I plan on tearing into the rear immediately after we get back from our small West Texas trip. I looked behind the toilet this evening and noticed that there is no floor underneath the water heater! Ahh the things you don't "see" when you are a wannabe! I'd be honored to have you lend a hand! I'll send you a PM so we can link up.
Lance
Old 12-21-2010, 08:23 PM   #18
x
XXXX , XXXX
Lance that's nice and shiney. Are you going with a LED while you have it out. It's much easier to install with the cover off.
So your trailer is suffering from rear end seperation. When Dave comes to help have him bring a tube of seperation H. That will cure it.
Old 12-21-2010, 08:27 PM   #19
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Always got some "cracks" don't you, Chris! LOL
I was just thinking of the LED retrofit, but I'm kinda partial to the glow of incandescent bulbs. Still kicking it around...
Lance
Old 12-21-2010, 08:33 PM   #20
x
XXXX , XXXX
rear end cracks LMAO you'd think I was a plumber or something.
I just put my LED's in today and tested them tonight. WOW are they bright and use 1/10th the power. I tested them tonight after dark and the over the door light lit up thw shop well enough to read a book from 15 ft away and the scare light looked like a runway landing light.
1972 ambassador, 29', restoration, water, window, leaks
