Old 12-22-2010, 09:01 PM   #29
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Here is the skin under the porch light. Kind of corroded. It took a little bit of cleaning and sanding but in the end it turned out OK.
ID:	117604   Click image for larger version
Lance
Top is offline   Reply With Quote
Old 12-23-2010, 07:50 AM   #30
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Lance, if you are not keeping the ceiling lights in your trailer, you can take one of the four lights and recycle it to your porch light. I did that to my Argosy 20 and it worked great. If you need pictures let me know and I'll send some. keep up the good work.
Are you going to Canyon of Eagles rally in the spring?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 12-23-2010, 08:09 AM   #31
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Bruce,
Thanks for the idea. I'll just borrow one for now. Yes we are planning on the Canyon of the Eagles rally. I hope to be done fixing the rear end separation by then. All I need is some "Separation H" as WasagaChris pointed out...lol
Lance
Old 12-23-2010, 09:35 AM   #32
soldiermedic's Avatar
Florissant , USA
Just found this thread....good work top!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 12-23-2010, 02:15 PM   #33
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thumbs up Thank You Doc
Thanks!
Lance
Old 12-26-2010, 09:07 PM   #34
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Finished the porch light even though I had to do it twice
I got this cheapo single 1156 replacement socket at Advance Auto. I tried to pry the spring clip out to have something to attach to the inner bracket. It kept on snapping, so I heated it up and then bent the tang straight. I got it all attached and installed. I then sealed up the newly polished dome with Sikaflex 221 gray and got it all looking so pretty. I then went to the battery compartment and connected the battery. What do you know, the light was on with the switch off! What I found out is that this little original socket is ground isolated and switched through the ground circuit! So I took it all apart and used electrical tape to insulate the connection between the socket and the mounting bracket. I then cleaned up the newly applied Sikaflex 221 and reinstalled it.
ID:	118000Click image for larger version
ID:	118001Click image for larger version
ID:	118002Click image for larger version
ID:	118003Click image for larger version
ID:	118004Click image for larger version
Looks much better and works great. I guess I should have known that it was a switched ground because of the two wires coming out of the trailer. Oh well, live and learn.
Lance
Old 12-27-2010, 04:46 AM   #35
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
Now I know what I'm missing under my light cover. If it's not in the trailers bag of bits and parts, I think I can make somethinhg that will work. MPJ
moparjohn is offline   Reply With Quote
Old 12-27-2010, 09:39 AM   #36
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Looks good, Lance.
BTW, don't waste your money buying the "official" Airstream lens for that door light. I think the parts dealers want $16 for it and it's nothing more than cheap plastic. You can make your own lens for pennies. You can use either a one gallon milk container or clear plastic packaging. The hardest part is creating a template to make your home made lens so that it fits but that didn't take too long.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 12-27-2010, 10:05 AM   #37
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Mike. Good idea. I do have the frosty white lens. It has a crack, but you wouldn't notice.
Lance
Old 12-27-2010, 06:09 PM   #38
Florissant , USA
As we have all said before, many may not notice it...it's what you will know is not right, and can you live with it.
I think from what I know about Lance...he will be just fine with it
Old 01-02-2011, 10:01 PM   #39
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Last trip for the year
Well, we took Abby for the last trip of the year. Here are some pics...
ID:	118634   Click image for larger version
ID:	118636   Click image for larger version
Lance
Old 01-02-2011, 10:25 PM   #40
Florissant , USA
I'm sure she does...just look at the bling coming from that porch light cover!!!!!!!!!!!!
Old 01-03-2011, 07:33 AM   #41
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
She's so beautiful and sparkly!
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 01-03-2011, 06:47 PM   #42
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Funny...Bling Bling was the not so affectionate nickname we had for a Command Sergeant Major in Germany. He drove an Expedition with chrome rims and had two gold front teeth! Please Steve, Bling is not a word I use lightly!
Thanks Lisa
Lance
1972 ambassador, 29', restoration, water, window, leaks
