04-07-2020, 11:35 AM
#81
1972 29' Ambassador
saint louis
, Missouri
finally got all the windows cleaned polished and put back together. it was a lot of work but got them all in
04-07-2020, 06:51 PM
#82
1968 24' Tradewind
1968 26' Overlander
Detroit
, Michigan
Nice! That’s a lot of effort! Keep up the good work.
04-08-2020, 10:44 AM
#83
CC
1972 27' Overlander
Heinsburg
, AB
Just found your thread. Your project is really coming along. The original interior of the ambassador is so similar to my '72 overlander. You are completing what I am going to start this year, nice to have your experience to refer to. Thanks for the great pictures
CC
04-15-2020, 01:09 PM
#84
1972 29' Ambassador
saint louis
, Missouri
using rivnuts and ss bolts to attach awning hardware. looks better than the large rivets and lags that were on it previously
04-20-2020, 08:09 AM
#85
1972 29' Ambassador
saint louis
, Missouri
got more awning hardware attached. also got the hinges on all the compartment doors. just a few more exterior items and I am ready to put the floor in. sorry for the photo orientation
04-20-2020, 07:45 PM
#86
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I put hinges on my cargo doors too. I didn't like the "J" hook Airstream used. The "J" hook is okay for the windows, but they have operators to help hold them in position. The cargo doors would just fall off if you opened them too far.
Very nice awning reinforcements. That art work takes more tooling than a pair of tin snips.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
04-21-2020, 01:25 PM
#87
1972 29' Ambassador
saint louis
, Missouri
found the hinge idea on the forum. makes a lot of sense. keeps door off ground and from possibly being left behind.
the patches at the awning supports cover the 2 sets of holes that were there. one was obviously from earlier damage the other one I think was misdrilled at installation. both clean and not blown out like the other.
04-22-2020, 03:22 AM
#88
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
I like your patches a lot. I am removing an old CD/short wave antenna and will be needing one. Maybe I missed it in a previous post, but what tools did you use to create them? I agree with David, seems like more than tin snips. Also are they the same thickness as the skin or thicker? Thanks - Mark
04-22-2020, 02:05 PM
#89
1972 29' Ambassador
saint louis
, Missouri
its the same as the exterior aluminum. I use snips to cut it as close as possible. on curves and spots I cant get to with snips I will use a Dremel with a cut off wheel. then I just use files.
04-22-2020, 07:53 PM
#90
1986 34' Limited
1975 27' Overlander
Conifer
Heck, I figured you had a CNC laser in your garage.
It takes a real craftsman to make artwork like that out of aluminum.
I made a patch for the front of my Overlander to cover the former hole for the crazy two plug umbilical cord Airstream was using in the mid seventies. I made one of those fancy state patches so folks might see where our home state was. It was a real challenge to make.
I live in square Colorado.
David
04-27-2020, 11:54 AM
#91
1972 29' Ambassador
saint louis
, Missouri
tail lights are in. couple items left and I can start putting the floor in.
04-28-2020, 12:27 PM
#92
1972 29' Ambassador
saint louis
, Missouri
fresh water tank fill
04-29-2020, 07:53 AM
#93
1972 31' Sovereign
Lexington
Wow, you've got some nice bling on your trailer! I like it!
Kay
06-25-2020, 09:52 AM
#94
1972 29' Ambassador
saint louis
, Missouri
got the front and rear subfloor in. using a 7 ply plywood that I am putting 4 coats of a marine grade spar varnish.
06-25-2020, 10:01 AM
#95
1973 31' Sovereign
Mantua
, Ohio
Very cool!
Just happened to find your thread. Your '72 looks great! I really like the details you put in for the awning supports and fill location! I've got about 20 patches on our '73 and it makes me want to do something similar. Your floors are looking GREAT! I see that you hinged your exterior doors. I did the same thing on ours and I really like the decision. Cheers, and keep up the good work!
06-26-2020, 06:57 PM
#96
1986 34' Limited
1975 27' Overlander
Conifer
Well, the new floor is going in. Looks like you want it to last longer than the old one did. Of course, the main thing is guarding against rainwater leaks, always a problem with Airstreams.
David
08-24-2020, 12:00 PM
#97
1972 29' Ambassador
saint louis
, Missouri
got the floor replaced and the shell bolted down. shell on floor replacement wasn't really that difficult. there is plenty of flex in the shell to allow me to slid the flooring in place.
08-24-2020, 01:50 PM
#98
1966 22' Safari
Fredericksburg
Looks like a nice clean slate. More fun to come. Great job and good luck going forward.
08-24-2020, 07:09 PM
#99
1986 34' Limited
1975 27' Overlander
Conifer
Wow, you have completed one of the harder jobs in Airstream renovations. Can you give a bit more detail on how you did it. Was the floor material in smaller pieces going east/west, say 48 by 62? Did you use wedges or something to lift the c channel and body up enough to slide in the flooring. Doesn't your trailer have "F" channels along the straight sides that the flooring fits into? Mine does.
I need to learn to do this as I don't have a good way to lift the body off the frame and subfloor.
David
08-25-2020, 07:57 AM
#100
1972 31' Sovereign
Lexington
We did shell on, and it worked well for us. If we were to do another complete reno, we would try to do shell off. It would make working on the frame much easier, and we could have put a least part of the belly pan on without being on our backs under the trailer.
We had to sand the edges of the floor along the shell to enable them to fit into the frame. Chris also made a specialized come-along to pull the edges of the shell in properly before we bolted it down.
Kay
