Old 09-30-2010, 03:57 PM   #1
1965 28' Ambassador
Malta , New York
What's the difference between Excella and ExcellaII
Can anyone explain the difference to me between Exclla and ExcellaII. thanks.
Airstreamdmb is offline   Reply With Quote
Old 09-30-2010, 04:06 PM   #2
JimGolden's Avatar
1987 34' Limited
Primarily the years... Excella came out in the early '70s. I believe Excella II came out in the early '80s. Both were the higher trim levels.
take care,
- Jim
JimGolden is offline   Reply With Quote
Old 09-30-2010, 05:34 PM   #3
1965 28' Ambassador
Malta , New York
I really like this layout. would like the newest year I can tow with my current vehicle a 2007 Toyota Tacoma with max GVWR 6500 lbs. I can't readily find the weights of the 1980's models
Old 09-30-2010, 06:02 PM   #4
lucca53
lucca53's Avatar
1973 31' Excella 500
napa , California
Well welcome I have a 1973 excella 500 also have a 2007 tacoma factory weight on the airstream is 6400 dry.I have made it much lighter in the remodel something you should think about.The tacoma is just not up to the task of pulling a 31 footer for to long,I will be getting a full size truck to do a better job.I love the excella which where top of the line for the years put out.
lucca53 is offline   Reply With Quote
Old 09-30-2010, 06:18 PM   #5
heslinhotel's Avatar
1989 29' Excella
Youngsville , North Carolina
Just purchased a 1989 29' Excella. Weighed it dry as soon as I arrived home. 6250 lbs at local certified scales. There was about 1/2 full propane tanks but no water or waste in either gray or black tanks. This unit also had 2 solar panels installed (75watt). This is weight BEFORE my wife started to "stock" it with kitchen and bedding. Lord only knows what it will top out on weight after stocking. I will weigh again after loading, but anticipate minimum of 500#. Plan on additonal weight with your personal items.
heslinhotel is offline   Reply With Quote
Old 09-30-2010, 07:33 PM   #6
Thunder Bay , Ontario
airstream wieght
I think I read here that the average family puts in 2000 lbs in there trailer, I would think that includes water but who pulls a trailer with a full water tank, maybe 10 gallons but not 50
Don
doneuald is offline   Reply With Quote
Old 09-30-2010, 08:18 PM   #7
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Excella was the top of the line untill the Limited series was introduced in 82.
Excella II was produced in the 80-81 model years.
This model was not top of the line, it was between the International and Excella-Limited series.
These two years had a high end model called the Excella-Limited
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Any difference ? Robbie R. Generators & Solar Power 4 09-14-2009 05:42 AM
What's the difference? Hoosierdaddy General Repair Forum 9 10-28-2008 05:56 AM
Difference between Sovereign and Excella Aluminumb 1986 Sovereign 0 10-11-2007 09:12 PM
OEM Stabilizer Jacks for an 81 ExcellaII walter846 Member Introductions 4 11-12-2006 07:39 PM
Excella or Excello, what's the difference? ~flutterbee~ Off Topic Forum 4 09-04-2006 03:12 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
