Old 08-15-2015, 10:28 AM   #29
mandolindave's Avatar
Just saw your " looking for a tow vehicle " video
Don't wanna insult your intelligence, cause it appears that you know your stuff.
BUT….I would advise against the extended van….just a little bit.
The further back to rear axle is, the better for towing.
mandolindave is offline   Reply With Quote
Old 08-15-2015, 11:02 AM   #30
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
From our experience with a 2013 25FB International Serenity, get in one on a dealer lot and pretend to make the cross frame bed. My feet did not fit beside the bed frame and the front wall. Lie down on that same bed close to the front wall and sit up ....watch your head. The person in the front sleeping position has to crab walk out of the bed in the middle of the night to use the head.
While touring the various models, also sit on the toilet and see if your knees fit with the door closed. Our 23D came with the toilet installed perpendicular to the wall, not at the angle shown in the literature. The door could not be closed when perched. We are correcting the toilet installation angle.
Sit in the dinettes and look at the television. Is that position comfortable or is your head turned 90 degrees to see the screen?
The literature tongue weights are very understated. Our literature tongue weight on the 25FB was 833 pounds. After installing the Hensley hitch head and along with the dealer installed street and rear awnings and a 155v watt solar panel (not enough capacity by the way) the scale reported our tongue weight as 1,150, pounds. This number increased to 1,175 pounds when we loaded the trailer for camping.
Many potential tow vehicles may not have a stout enough factory hitch to handle that much weight.
We all get to visit truck stops and use their CAT scales to get the real numbers on both the trailer axles and tow vehicle axles. Many folks are surprised to find their tow vehicle does not have the capacity numbers they thought it had.
Whenever taking a demo tow vehicle ride, cross the local scales and see the axle weights and vehicle total weight and compare those the numbers on the driver's door jam weight stickers. Note that the actual weight will probably not be identical even for the same model on a different lot due to differences in the factory installed accessories.
Good luck in your research and welcome to the forum.
Old 08-16-2015, 04:18 PM   #31
explorer
2010 30' Flying Cloud
On the Road Full Time , Utah
Thanks so much for all the great info everyone.
We ended up picking up a 7.3L E350 EB from Denver yesterday. We're putting together a highlight video of the rig. Here's a pic in the mean-time:
We'll be selling the roof rack and modifying the suspension a bit, it's got a little bump-steer at high speeds, so we'll have to sort that out. I realize an EB won't be as ideal for towing, but it'll be nice to have the extra room inside.
explore more is offline   Reply With Quote
Old 08-16-2015, 05:40 PM   #32
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question ....... "modifying the suspension a bit"
'Ya think?
A bit.....
Maybe just a bit more than a bit.
Old 08-16-2015, 07:27 PM   #33
explorer
Yeah, it's HUGE. A little too huge.
Old 08-16-2015, 07:57 PM   #34
2015 30' FB FC Bunk
Ayer , Massachusetts
If I had that van I would love to have that rack. I had one similar built for my Excursion. I put Thule bars and six bikes up there, with the whole front of the rack full of other stuff.
Ted S. is offline   Reply With Quote
Old 08-19-2015, 11:53 AM   #35
explorer
Old 08-19-2015, 12:29 PM   #36
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Bummer about the AC.
Are you going to be able to lower it or is due to the 4x4 conversion?
How did it drive going 70mph and around corners. No tracking issues? Those tires loud?
Kelvin
Old 08-23-2015, 12:25 AM   #37
explorer
A/C just needed a charge. $180 later and it blows ice cold (though it takes a few minutes to cool the entire van).
The tires are all terrains, so they're not very loud. We took it up to 80 mph (the speed limit in northern utah) and it did great. Around corners it wanders a bit, so I slow down, but now I'm getting used to driving it.
I'll probably be swapping the suspension with a more updated leaf spring design (shackles in back). Unfortunately, with a solid axle up front, you need at least a 4-6" lift to clear the front crossmember.
The good news is that these vans actually drive better than stock once they're lifted properly.
Old 09-01-2015, 03:36 PM   #38
2016 27' Flying Cloud
North augusta , South Carolina
I stumbled on your trailer buying videos a few weeks ago and it was scary how much you sounded like my husband with respect to trailer quality. We have made the leap and will be proud owners of a new 27fb flying cloud in a few weeks. Can't wait to hear what you guys end up with.
Medjrd is offline   Reply With Quote
Old 09-01-2015, 10:35 PM   #39
explorer
Awesome. We're super jealous. If we could have any trailer in the world, it'd be a 27' Flying Cloud. Enjoy it!
Old 11-09-2015, 03:44 PM   #40
explorer
We saw our first Avion this past weekend, and it made up our mind: that will most likely be our next trailer. We're officially looking for an '86-'89 Avion in the 25-30' range. A 28A or 30 R would be ideal. We'll keep a close eye on the classifieds, but if anyone could pass some leads our way, it'd be greatly appreciated.
Old 11-09-2015, 05:46 PM   #41
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
You will not regret your decision. I'd be more than happy to keep my eyes open for an Avion. How far would you be willing to travel to look at one?
If you haven't already, I like to use SearchTempest: Search all of Craigslist nationwide & more to browse the Avion ads, usually nationwide.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 11-09-2015, 05:53 PM   #42
PaulnGina's Avatar
Good Ol' , USA
For some reason I had not kept up with this thread until tonight.
What an AWESOME van!!! We are kindred spirits!! You are gonna LOVE that PowerStroke! Then to hear you are now looking for an Avion! Awesome X 2!!!
Congratulations!
1987 Avion 34W
Explore USA Denton, Texas Bluto Off Topic Forum 10 09-28-2012 08:47 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Explore USA RV in Fort Worth TX Sister General Repair Forum 12 10-26-2011 11:03 AM
Just beginning to explore AS smbrewster54 Member Introductions 1 10-01-2010 01:32 PM
ATV's are they a viable way to explore trails? LI Pets Off Topic Forum 5 09-25-2006 11:13 PM
