Old 12-28-2018, 10:44 AM   #1
2015 25' Flying Cloud
columbus , Georgia
Used or new
This will be our first AS. We are looking at 25ft FC and deciding between a 2015 and 2018. Are there any significant differences between these model years or anything I should inquire about more indepth? What about the dealer offered extended warranty?
Thank you
Shazam is offline   Reply With Quote
Old 12-28-2018, 11:24 AM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Shazam,
Hello from across the river!
As far as the difference between 2015 and 2018. The 25’ FC should be the same. Ducted Air for those units was new in 2015 if my memory serves me well. There was the addition of a interior color choice sometime in the last few years but no major changes.
PM me if you need any other help
Ronnie
Old 12-28-2018, 05:44 PM   #3
1986 31' Sovereign
Miami , Florida
The 2018 will have the balance of the factory warranty. The 2015, on the other hand, is out of warranty but should have had any serious gripes addressed by the previous owner(s).
I am skeptical of dealer warranties. How useful is it if you break something a thousand miles away from the dealer? What is excluded in the fine print? Is there a mandatory (expensive) annual dealer inspection required to keep it in force?
If the 2015 is in good shape, you will save a bundle as the first three years depreciation is the greatest, tapering off rapidly from there.
If you are handy,get the inspection checklist (or a volunteer inspector from the Forum) and leap in!
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 12-28-2018, 05:49 PM   #4
Overkill Pundit
GMFL's Avatar
Dadeville , Alabama
I will be happy to inspect it for you if it’s in my area.
Old 12-28-2018, 05:58 PM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Note that the first year of the air ducts (2015), many folks experienced them falling out due to a faulty design issue of oversized holes or poor clip design. Airstream really never addressed the issue to everyone's satisfaction.
Old 12-28-2018, 05:59 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Definately go for the 2015.....save thousands, negligible future problems; hopefully a scuff or two just to give it some patina and save you the angst of your first scuff.
Even if you spend money to redo the bedding to a better quality mattress, you're still thousands ahead.
May come with WD hitch and all the accessories that will cost you thousand beyond the 2018 buying price.
Cheers
Sidekick Tony
PS Don't bother with extended warranty....save your money and enjoy fixing it properly yourself, the first time.
Old 12-28-2018, 06:37 PM   #7
2019 30' International
Pennsylvania , Pennsylvania
The 2018 may have the upgraded converter and a couple solar panels on top. The upgraded converter is nice, but you could upgrade the 2015 your self, many have done so.
The 2015 will be needing tires in a year or so. Check the tires on the units.
I'd probably opt for the 2015 if the price difference is great enough.
majorairhead is offline   Reply With Quote
Old 12-28-2018, 06:42 PM   #8
2016 25' Flying Cloud
Holly Springs , Mississippi
I vote for the 2015. The current owner can sell for close to what they paid for it, and still be $20-30,000 below current prices. A win-win for everybody.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-28-2018, 09:57 PM   #9
columbus , Georgia
Thanks all for the useful info. I've learned a bunch lurking on the forum.
GMFL- Lake Martin is beautiful- PM sent.
Old 12-28-2018, 10:44 PM   #10
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
New vs used? It depends. If you are DIY capable, get the used coach. If you are a take it to the dealer person, then look at the new ones. They have a longer warranty now.
What I would say is - look at the 27s. Less tongue weight and more interior. Folks think 25 is the one and lots of them get sold. It is a nice mid sized coach. But if you are a twoftitis type person, just consider the 27 now. You will be happier in the end. If you are not a bigger is better RVer, look at the 23s. They are a lot of coach, easy to tow and a great value for two folks. The CB model is even offered in a bunk version for small families. Note - the 23s did not get ducted air until later production. That can hold the 2015 and older to a lower price if your budget is tight.
Do your research now, before you sign. There is a lot of information to consider and that adventure is basically free.
Good luck in your search. Pat
PKI is online now   Reply With Quote
Old 12-29-2018, 09:29 AM   #11
2017 23' International
hendersonville , North Carolina
Ducted air registers
They now drill a small hole at the end of the slot for the air adjustment and then insert back into ceiling hole. Then a small hole is drilled into skin at 4 different intervals while rotating outer duct. 4 rivets or small screws installed and no more falling vents. The technician at JC did this to my 2017 23D when in for minor warranty work. works perfect.
uraljohn is offline   Reply With Quote
Old 12-29-2018, 09:43 AM   #12
2015 to 2018 differences
The cushions in the 2018 received a major upgrade to a much firmer foam, Big difference. Also the window curtains are blackout. No seeing through them at night with lights on inside. The 2015 may have the dreaded Goodyear Marathon tires. The 2018 will have the Goodyear Endurance E rated tires. Way better and so far no bad reputation for failure. 2015 may still have the standard wheel bearings and not the Never Lube. Not sure on that one. When we purchased our 2017 23D we bought new because the used ones were maybe 5k less and for 2017 several important upgrades were made to the 23D's. We thought the factory warranty and upgrades were worth the difference. Personal choice. Either way, enjoy your new or pre-owned Airstream and welcome to the group.
Old 01-19-2019, 09:10 PM   #13
columbus , Georgia
New owner
All-
We took delivery today of our 2015 25FC. I appreciate for all the guidance and will continue to learn from this forum.
Old 01-19-2019, 11:46 PM   #14
Mollysdad's Avatar
I've had three fall out. I look at them, guess how and why they're in there, give them a firm push to lock the plastic teeth, and move on.
The ducted air is such an improvement, it's worth dealing with finding an occasional vent on the floor or bed.
Nice Used Airstream 30' Bunks Safari TravelTrailer RV SNice Used Airstream 30' Bunks eBay Watch Airstreams on eBay 0 02-17-2011 07:00 PM
NO RESERVE Used Nice AIRSTREAM TravelTrailer 25 RV Repo SNO RESERVE Used Nice AIRSTRE eBay Watch Airstreams on eBay 0 02-03-2011 11:50 PM
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 09-11-2009 08:40 AM
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 08-19-2009 11:50 AM
