Old 06-01-2010, 08:26 PM   #1
2010 27' FB International
Miami , Florida
Top 5 issues at delivery
I will be taking delivery of a new International 27FB next week. This is my first Airstream/RV and naturally, I am a bit nervous to perform the "walk through" with the dealer.
Recent purchasers of Airstreams, could you let me know what were your top 5 issues/defects you discovered.
Cheers
gamana is offline   Reply With Quote
Old 06-01-2010, 08:33 PM   #2
Ottawa , ON
If you don't hear "leaks" in that list, I will be really surprised...
ďCourage is being scared to death, but saddling up anyway.Ē
Old 06-01-2010, 09:00 PM   #3
Indian Harbor Beach , Florida
LEAKS!!!! We have a new Int. 27 FB and all, yes all, of our outside compartments seals were improperly installed and we had a flood (not a leak, a flood). Our dealer fixed them asap, then had window and vent leaks. But all was taken care of and now we are travelling all over.
Highly recommend video taping the walk thru....we have watched our tape many times to answer many questions! Also, make sure the awning works properly. let them show you how to operate it, then do it yourself with no help from dealer. Also, get on top and look at seals!! We have had problems with the new 3m seals for the vents, check those carefully. Also, the microwave will not pop popcorn!! I went straight to the manufacturer on this one, and they said nope, will not pop popcorn...
Again, videotape, videotape, videotape! We have reviewed it sooo many times. And read the owners manuals before you go anywhere...we had alarms going off one night and went scrambling for the books at 3am! We can laugh at it now....
Enjoy your adventure, we love our International named "Belle".
See you on the road....
kidsgone is offline   Reply With Quote
Old 06-01-2010, 09:37 PM   #4
2005 22' Safari
Gresham , Oregon
A microwave that won't pop popcorn, really?? What does it do then?
sempi2 is offline   Reply With Quote
Old 06-01-2010, 09:47 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
How sad is that! Never heard of such a thing. Even our little cheap microwave that we take with us sometimes will pop popcorn!
TB & Greg and Abbey Schnauzer
#3954
Old 06-01-2010, 09:58 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Well, sample size of one, here's what I found, not in the walk through but on the first couple of trips:
1) Loose trim on kitchen cupboard
2) Rear A/C temperature sensor not connected
3) Half of oven burner won't light from pilot, has to be lit by hand
4) Stovetop washer/grommets defective, won't hold up the weight of a pan
5) Locks required graphite lubrication to allow keys to work smoothly
6) Sensor for sewage tank shows empty all the time (sensor problems are, apparently, common)
7) Missing screw in one of the panels in the bathroom
8) Bad ballast in one of the fluorescent lights
9) Freshwater system leaks back into the tank, probably leaky valve in the pump
10) Defective latch on one of the cabinets
11) Coat closet door mounted too high, hits A/C ductwork
12) Loose socket in triarm light over dinette. Bulb won't stay seated
13) Several loose counter items, faucet, soap dispensers
14) Holes in A/C filters because someone put a screw in the wrong place
15) Excessive noise from rear A/C
I didn't take the walkthrough seriously because I figured I was going to have to bring the rig back to the dealer in the first couple of months anyway and it wasn't worth it to me to rake them over the coals on delivery day. Ymmv.
As for the microwave, I thought they were just for melting chocolate and butter.
Old 06-01-2010, 09:59 PM   #7
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Upon walk through, you may find things like uneven trim and other cosmetic issues or awning adjustment that they will take care of before you leave the dealership. Take your time, enjoy and spend a night or two nearby and return for any issues that are found later. There is much too much to inspect at once. The waranty is well stood by and you will be served well by a good dealer or the factory. Troubles with battery recharging, shower leaks, doors and alignment may be the worst you encounter. Sometimes the window locks need adjustment. Open and close the fantastic vents. They often stick and need either trimming or 303 to condition the weather stripping and open more easily. Inspect the outside around the spotlight and tail lights and door handle and battery compartments for corrosion. They can replace or fix the clear coat. You will have to open all the windows and burn off the new manufacturing oils etc., with the oven and heater. Congratulations. We want pictures!!
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 06-02-2010, 09:09 AM   #8
2010 27' FB Classic
N/A , Texas
At the delivery time: Received new light fixture as one reading light was defective.
I had a good service person do the walk thru with us and it went smoothly. Apparently he had some training from Airstream. He answered all my questions during the walk thru. After I came home I had some time to read the manual and handouts from the various manufactures and I had a few more questions. He answered them over the phone.
Airstream also accepts emails to the service dept and will answer any additional questions on line if you want to go that route.
It was a good experience for me!
I bought one off the lot the first time and had many issues with broken things that were just flatly abused from people going thru the trailer at the dealership.
Old 06-02-2010, 09:27 AM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Even more important, what kind (brand and model) of microwave is this? Help warn others.
End of my hijacking.
Since I bought both mine very well used, my list hardly applies.
Enjoy your new International, gamana!
Vaughan
Old 06-02-2010, 09:33 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Probably the #1 issue has been leaks from the shower door area. My 2001 Safari and 2004 Classic both suffered from this malady. It seems to be something that may take multiple visits to finally control. It has something to do with the door framing that seems to be prone to improper sealing during installation.
My only other issue is the failure of a check valve in the fresh water pump requiring it's replacement. I have replaced the sensor control panel due to a burnt out LED.
My local dealer has hookup spots at the dealership and encourages owners to spend the first night there. This way it gives you time to go through the walk through and the next day, get any issues taken care of prior to you driving off.
My advice to watch carefully the awning set up and storage procedure. Also, if you are new to trailering, pay special attention to the hitching procedure.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-02-2010, 05:09 PM   #11
Miami , Florida
Thank you all for your inputs. It seems like the most important issue I need to look for is leakage which is not so easy to determine within a couple of hours on the parking lot of a dealer.
Has anyone ever asked a dealer permission to water the roof of an AS with a hose pipe for 15-30 mins???
Old 06-02-2010, 05:58 PM   #12
Gamana, We did ask our dealer for a water check after the leaks were fixed and they complied....no problem.
As for the make of our microwave...Tappan. We took it to a Tappan dealer and they said that our model would not pop even a small bag of popcorn....we thought it was defective that's why we took it to them. They wouldn't do anything...we need to replace it soon....I need my popcorn!
Old 06-02-2010, 07:02 PM   #13
Miami , Florida
Kidsgone, thanks for the info on the water check.
Since it is my own post I can probably hijack it for a couple posts .
Why do you need a microwave to make pop corn??? I have always used a pot with a lid!
Old 06-02-2010, 07:27 PM   #14
Birmingham , Michigan
I took delivery of a new 27FB International last month. Still have not "tripped" in it yet. I did drive it home...3 hour drive in a pouring rain. Didn't find any leaks. I washed it down pretty good the next day from the top down and didn't discover any leaks whatsoever. Not sure about the shower yet.
My dealer, Woodland RV in Grand Rapids, Michigan, did a fantastic job of prepping our unit. Had a very thorough walk-thru. I really think they did a lot of adjustments prior to our picking up the unit that was ordered. They had the unit for about 3 weeks before I picked it up. No problems yet...but...we have not yet tripped in her.
I'll be keeping my fingers crossed.
Enjoy your AS. They are great.
Aquabud is offline   Reply With Quote
delivery inspection
delivery tomorrow!!! cricktoline Member Introductions 8 05-29-2009 05:21 AM
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
Used Trailer Delivery? Booner Member Introductions 4 10-21-2007 03:52 PM
Anybody need delivery Melody Ranch Off Topic Forum 1 08-06-2007 07:14 PM
Delayed Delivery campadk Buyer Guidelines 11 10-19-2006 03:51 PM
