Old 10-30-2014, 09:18 PM   #1
1984 34' International
Harrisonville , Pennsylvania
Thinking of buying. Any advice?
I am thinking of buying a 1984 34 foot international. It has not been used in about 6 yrs. Buying from an elderly widow so no history. Looks to be in good working order but in need of cleaning. I am a mechanic so repairs are no problem. I have never owned an airstream or even been in one before.
Any advice?
Things to beware of?
How much is it worth?
racer57 is offline   Reply With Quote
Old 10-30-2014, 09:37 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
PM sent
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-30-2014, 09:47 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am saying you will have some floor rot in the back and under the front windows.
Chances are high that the freshwater plumbing and hot water heater have frozen and broken.
Pipes are easy to replace with Pex, depending on the extent of floor rot fixing it can be easy, and it can be difficult if a person elects to do a shell off to fix.
IMO the only major problem that a capable DIY guy wont want to deal with is if the frame is rusted out.
The frame unfortunately is hard to inspect without dropping the belly pan, not really practical on a pre purchase inspection. You can maybe gat an idea by checking in the frame visible inside the stair recess.
Old 10-30-2014, 09:52 PM   #4
Thanks, I think pipes are fine. Couple did a lot of camping before he died. Found a jug of antifreeze in trailer. Any idea what it is worth?
Old 10-30-2014, 09:57 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
offhand, wild guess..$8-15k.. condition is key.. might be more if realllllly good.
if bad, under$8k..pics and inspection...
Channing
WBCCI# 30676
Old 10-31-2014, 10:51 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Jug of antifreeze? about $4...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-31-2014, 10:57 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Funny guy!
Bob Martel
WBCCI# 5766
Old 10-31-2014, 11:28 AM   #8
Any advice?
Keep in mind, that torsion axles must be used some what frequently, if not, the rubber rods go bad. Rubber must be exercised, or else.
Most likely, the axles in that trailer, will need replacing, because of non use.
Also, when in use, torsion axles rubber rods, only last about 25 years.
Old 10-31-2014, 11:31 AM   #9
1994 34' Excella
Warren , Manitoba
Probably going to need new axles, tires, and shocks. Plan on $5000 for that. If original A/C you will probably have to replace. Same with fridge and possibly H/W heater. I bought a 1994 34' in the spring for a good price, and have put over $7000 in it, including new axles, tires, and shocks. Before you buy it, try and have someone that knows Airstreams look at it. Good luck!!
CBWELL is offline   Reply With Quote
Old 10-31-2014, 01:28 PM   #10
1987 25' Sovereign
Oregon , Ohio
On the portal page, the right side about 2/3 down you will find Airstream inspectors. You may find someone near you that will look at the trailer with you.
msmcv51 is offline   Reply With Quote
Old 10-31-2014, 01:48 PM   #11
m.hony's Avatar
2013 30' Classic
Advice?
Go ahead and by that beautiful, long trailer and enjoy it...
I tried to buy a 34 footer before I bought my 30. We just couldn't get together on price.
It was a 1988 not in the best condition and he wanted $18,000. He would go down to $15,000 and I thought that was still too much for that particular trailer with an odor and a broken window.
TAC #MS-10
Airforums #70955
Old 10-31-2014, 01:57 PM   #12
millertimeUS's Avatar
1976 25' Tradewind
Some real good advice here
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 10-31-2014, 02:05 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A good budget number is $10k without regard to labor cost
Throw in a Pro Pride hitch as well
FWIW I expect to have $30k past purchase in mine at some point. Best not to cheap out on any aspect (curtains as example) as what one might get away with in a house is just wrong in a fine TT. After all it still has another thirty years or more to go. Plan that way.
Good luck
Old 10-31-2014, 05:25 PM   #14
From what u guys are saying it sounds like the 2k asking price is pretty good. Only reason I question price is online price guide that says 3500. Are they worth way more?
Thinking about buying a Generator. Anyone have any suggestions? Blockstream Generators & Solar Power 16 07-19-2012 06:33 PM
Thinking of buying an older Airstream Old Cracker Member Introductions 7 11-20-2006 10:25 PM
Thinking of buying a 75 Argosy 24' Motorhome hamilton1965 Trailer Values 8 03-28-2006 03:57 PM
I am thinking of buying: is it worth it? JeffTerry 1981 - 1983 Excella 12 02-19-2006 11:10 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
