Old 05-20-2006, 09:14 PM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Question Rear-end Sag, Educate me please!
I seem not to be very good at finding useful information on a particular subject, using the "search" function on this site....is it just me...or is it the system? I always get a return of hundreds of threads that take many hours to read and provide very little useful information! Oh well.
I am looking at a 79 Excella 500 as a purchase candidate. I was talking to the owner on the phone and I ask if it had any "rear-end sag". He said he didn't know, but then he vaguely described some loose screws in the rear, above the bumper, that needed some repair. So, my questions are, (1)What is "rear-end sag". (2)How do you spot it? (3)And, how do you fix it?
Thank for the help. Bill
lebolewis is offline   Reply With Quote
Old 05-20-2006, 09:30 PM   #2
1. It is a separation of the frame from behind the back axle on a tandem axle Airstream. It sort of looks like the frame is starting to "dangle".
2. Oh, you will know it. My Dad's '73 31-footer had it. The back of the trailer will develop a gap between the bumper storage compartment and the super-structure of the trailer itself. It will also start to "pull" in the belly pan below.
3. The only way I have ever seen it fixed is when my brother-in-law had it repaired at Airstream in Jackson Center. It was not cheap either. They also only warranty the repair for a short amount of time. He had it repaired about 6 years ago and it was starting again last year. He took it back down there and they fixed it again. I am not sure how much it cost but it is a deal-breaker when the price of a trailer seems high.
Anon is offline   Reply With Quote
Old 05-20-2006, 09:44 PM   #3
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Thanks Lou, .....Another question for you or somebody....since all Airstreams do not have this problem, why only some?.....what are the forces at work that cause the "sag"? Why would the trailer frame drop down below the trailer body? Did I understand that part correctly? Bill
Old 05-20-2006, 10:47 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Bill,
if you have a strong constitution and aren't easily frightened, then all is explained in this thread.
Sort of.
Now, keep in mind that you are talking about a '79 and that sort of is out of the range, but it still can happen. Here' how you spot it: Put your foot on the rear bumper. Look very closely where the shell meets the bumper. Push down with your foot. If the bumper moves apart from the shell then you have rear end separation. Which is not the end of the world. I know. There are several fixes: Cut elephant ears, ear shape patched from your exterior skin where the shell can be reattached to the frame and then the holes are patched over with more aluminum. Not pretty looking. Or they can remove all of your bathroom, remove the lower wall, tear our the rear floor, replace with new floor, reattach the shel and put everything back.
Your description of what this guy says does not in any way indicate that this coach has that problem. Vague loose screws just sounds weird since an AS has very few if any exterior screws, unless they hold on the license plate or tail lights.
Hope this helps, and good luck!
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 05-21-2006, 09:09 AM   #5
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Originally Posted by AYRSTRM2
Bill,
Sort of.
Thanks Ayrstrm2, I read the WHOLE thing!! I feel like I am now an expert on the subject!!!.....well, not exactly. But, I now know what to look for! And....I know it can cost up to $3000.00 to get a fix at an AS repair shop....and maybe a loooong tow to get you to a good shop that knows how to do the job right. There seems to be lots of opinion and confusion remaining as to EXACTLY what causes it. My guess is that it is a combination of factors, all of them are mentioned in the thread. That's very valuable info when you are looking at used AS's. In spite of some "testy" comments by a few folks, this Forum continues to be a very valuable asset to AS owners. Bill
Old 05-21-2006, 10:07 AM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Fast easy way to check is to stand on rear bumper and watch seam beneath belly band as you bounce up and down gently. Check both sides.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 05-21-2006, 10:17 AM   #7
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Bill, It happens mostly on longer trailers with rear baths, trailers 25' and 26' and below or long trailers with center baths don't usually have this problem. The cause is usually because of the weight of the water in the holding tanks. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-21-2006, 11:35 AM   #8
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Bill,
The foregoing is a common misconception, or at least a point of common disagreement. I'm not sure who is right and who is wrong. Andy of Inland RV reports that frame separation is caused less by the weight of water in the holding takes and more by lack of proper wheel balancing. I suspect that it's probably a combination of factors.
My Airstream inspections have found a 25', 27' (rear bath), and 31' (center bath) with frame separation. Yet, I have found 30 year old 31' rear bath Sovereigns without it. So, my take is this. Since there is disagreement about the cause, just assume that all old Airstreams regardless of lenght or floor plan may have it; and make it a part of your inspection checklist.
By the way frame separation and tail droop are two different maladies, but that's another thread.
Ken L
1966 Tradewind 24
Old 05-21-2006, 12:09 PM   #9
1969 31' Sovereign
Elizabeth , Colorado
Before you tackle this problem ask yourself this question?
Am I doing a 5, 10 or 40 year fix on this problem? The price goes up with length of time? I fixed the tail sag on my 69 31' Sovereign this way after getting some advice from a professional restorer. The problem was: the rear bunper was sagging below the aluminum frame far enough so thet I could see all of the 3/4 inch plywood in the gap.
Solution: jack up the rear bumper with stands to the poiint that you are almost lifting the tires off the ground. (pur stabilizers at front corners of frame) I left it on these stands over the winter to get the rear bumper as high as I could, Got back almost 1/2". Then using 2" aluminum angle I rivited it to the aluminum frame and the bumper. The 2" alumionum L allowed me to place the upper rivets high enough to catch the U-channel of the frame, but i had to cut off some of the lower part of the L to make it fit on the bumper.( make some cuts in bottom of L to allow it to bend around side curve.) Using oversize rivets it worked out very well. No problems since I fixed it last year. Dont forget to use spray foam or a lot of caulk before you rivet it in place.
stagecoachbill
WBCCI #5345
62 Globe Trotter 19'
69 Sovereign 31'
04 E-350 Van 6.0 diesel
stagecoachbill is offline   Reply With Quote
Old 05-21-2006, 01:26 PM   #10
Rear end separation.
Rear end separation, can be caused by excessive weight at the bumper, and/or by lack of proper running gear balance, or some of both.
The longer the trailer, the more likely it could happen. But any length Airstream trailer, can have the separation, even a 17 footer.
When Airstream swithched the rear floor channel to a new design, the problem did not stop, but did tremendously reduce. That floor channel slipped over the edge of the plywood instead of just sittling on top of it.
There are temporary fixes, and there are permanent fixes.
The following is the correct permanent fix.
1. Remove the raer rub rail molding. Remove the two rear quarter panels. Cut them at the lower belt line molding.
2. Fold the rear plate upwards from the bottom.
3. You will typically find that the floor channel is in pieces.
4. Reweld the floor channel.
5. Replace any plywood thats necessary.
6. Remove the two rear banana wraps.
7. Weld a small 2 x 2 x 1/4 inch steel plate, "outward" of the frame, so that the banana wrap will hide it when reinstalled.
8. Replace the rear steel plate hold down if necessary.
9. Jack up the rear of the frame to place it back into it's original position.
10. Refasten or add additional 3/16 pop rivets to hold the "inside" quarter panels.
11. Fabricate at least 4 steel plates that will fit inside the floor channel.
12. Place one plate over the frame and the other over the added piece of angle that you welded outside of the frame.
13. Reinstall the floor channel.
14. Use 1/4 or 3/8 inch "plated" bolts with "large" flat washers, and lockwashers, every 3 to 4 inches as well as at least two bolts through each metal plate.
15. Replace the insulation if necessary.
16. Add a splicer plate to the inside part of the quarter panel that you "dad not" remove.
17. Reinstall the quarter panels, using 3/16 rivets at the belt line and at the floor line. Make sure you injected Vulkem sealer before you start to rivet.
18. Install olympic rivets to finish the job.
19. Reinstall the rub rail molding.
20. Clean up any excess vulkem.
21. Remove the jacks.
22. Go in the house and get a beer. Go back out to the trailer, and observe the beautiful job you did. After all, we know your Grandmother was supervising, so the job had to be far better than the original construction.
Those owners or or owners that allowed a dealer to short change the repair by using the "elephant ear" method, will pay dearly for it, in time.
Unless a person tows the trailer many miles over railroad tracks, you will "never" have the problem again.
However, adding weight to the back of the trailer, is always a no no.
Towing without proper running gear balance is a no no, as well, but not nearly as bad, unless you use square tires.
Keep in mind, anything can be destroyed, if we shake it enough, or subject it to enough vibration.
Those that are old enough, I am sure remember the cause of the Lockeed Electra wings falling off.
I forgot who wrote, "Why is it we can find enough time to do a job over again, because we didn't take enough time to do it correctly, the first time".
Or, when it fails again, sell it on e-bay.
Old 05-21-2006, 02:10 PM   #11
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Wow! No wonder it costs $1500-$3000
Wow! Thanks, Andy.
This is not a simple problem to fix. This looks well beyond anything that I would ever attempt to tackle. I will do my very best to avoid buying a used AS that has any symptions of "REAR-END SEPARATION". And......if I muck it up, and it develops the problem, I will then seek out a competent repair shop to fix it.
Armed with all this good info, I will be out there, stalking them thar used Airstreams..... and the FIRST thing I will check for is, "guess what"?!! Bill
Old 05-21-2006, 02:14 PM   #12
Wow! Thanks, Andy.
Bill.
The second thing that you "MUST" look at is the axles.
Are they OK?
Are they correct for the trailer?
Are they someones "home brew"?
Old 05-21-2006, 02:22 PM   #13
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Bill.
Are they OK?
OK, makes sense. So, help me out here. Can I stand 5 feet away, or closer, looking at the wheel-wells and the wheels, and tell if the axles are good? If not, how do I make a good (simple) decision about them? Bill
Old 05-22-2006, 09:15 AM   #14
Bill.
Stand 15 to 20 feet away and stoop down so that your eyes are even with the wheel well.
You should be able to see some of the tire, "above" the top of the wheel, perhaps as much as 1 to 3 inches, depending on the model.
You can also read an article about the Duro-torque axle and how to check it by going to our web site, inlandrv.com Click on articles, click on the Dura-torque axle article.
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Winter in an Airstream ????? Boris Carlove Our Community 9 08-04-2002 07:58 AM
Trailer weights davidz71 Our Community 6 05-28-2002 10:55 AM
