Old 04-12-2012, 10:35 AM   #1
Aptos , California
rear bath question - '70s and '80s
Do all rear bath models have problems with the frame or is it just the excella? Also is the excella or the sovereign the top of the line?
I have just started to consider going with a rear bath floor plan with the twin beds for my family. I would install bunks above the twins and use the pullout in front for wife and me. (4 kids) It seems like it would be a good functional layout for us. Any thoughts on what years to avoid and what problem areas to look for would be helpful. I have figured out from reading the forum that there is some problem with thermopane windows, but I don't know which years had them.
I also read about a frame strengthening kit, but I haven't figured out what it is or looks like to see if it has already been done. I am envisioning some kind of welded on steel that makes the frame rails deeper, in which case I could make it myself in my shop. Does it only reinforce under the bath area or is it the whole length of the trailer?
Thanks in advance,
Dave
farmerdave is offline   Reply With Quote
Old 04-12-2012, 10:57 AM   #2
Thanks in advance,
Dave
The frame beef-up kit, does absolutely NOTHING for the rear end separation.
The separation, is caused by 2 reasons.
1. The shell to frame hold down at the rear, was marginal.
2. Lack of proper running gear balance.
The fix is not difficult, but does take a few hours.
Also, adding to the frame at the rear, will make the separation even worse, in time.
The strength is in the shell, NOT the frame.
Old 04-12-2012, 12:04 PM   #3
Aptos , California
That is not at all what I thought it was for. Where does the separation happen? I thought it meant that the frame was dropping out from under the shell (separating). What problem does the frame beef up kit address then? Does anyone have pictures of the two different problems and their solutions?
Old 04-12-2012, 12:28 PM   #4
The separation happens when the frame at the rear, drops from the shell.
The frame beef up kit is wlded in place at the axles. It "supposedly" beefs up the frame !!!
Why needed?? No one knows.
The frame when made sometimes had the axle mounting plates improperly welded, by not using enough welding to hold the plate to the frame. That plate could buckle.
To avoid that issue, you can check to make sure the axle mounting plate is welded with minimum gaps between the welds, at the bottom of the frame.
If there are excessive gaps, simply fill in those gaps with welds.
Then, there is no need for the frame beef-up kit.
Again, the frame beef up kit has nothing to do with rear end separation.
There have been many posts about the rear end separation previously within this Forums.
Old 04-12-2012, 01:04 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Rear end separation happens when the shell is no longer connected to the frame at the back end of the trailer. The construction in the early 70's (not sure how long this lasted) is: the plywood sits on top of the frame. Then, at the rear, there's a plate that is angled and it goes underneath the c-channel and extends up inside the outer skin about 3 or 4 inches. The plywood is bolted to the frame. The c-channel and this plate are screwed and bolted to the plywood. Then the skin is riveted to the c-channel and the plate. The problem comes in when the plywood rots away due to water damage, or other physical damage causes it to break. Since the shell has no direct attachment to the frame other than the plywood, the frame and shell can become separated fairly easily. The fix that was applied to our 72 was to weld a steel u-channel between the main frame members directly underneath the plywood and c-channel. Then extra bolts are extended through the c-channel and plate, through the plywood and this u-channel, providing a much more solid connection between the shell and frame. Worked fairly well on our trailer, until the plywood rotted out. But even then, the bolts through the u-channel limited the movement between the shell and frame. The problem tends to be worse on the longer trailers. If you put a foot on the bumper and you can push the bumper down without moving the shell, there is rear end separation.
The frame reinforcing plates bolt (or weld) onto the frame directly over the axles. They are intended to solve a frame sag problem as I understand it. The way to know if your frame has sagged it to use a string line (a chalk line works) inside the trailer. If you do not have rear end separation, then when you run the string line front to back the entire length of the trailer supported on say a 3/4" board at each end and pull the line taut, if the line does not touch the floor in the area over the axles, then you do not need the reinforcing kit. You can also check with a level on the floor. If you level the front of the trailer, and then move the level behind the axle, if the level shows the floor is sloping down to the rear, and you do not have rear end separation, then you have frame sag. The frame would then need to be straightened and the reinforcing plates bolted on. At least, that's how Andy explained it to me a couple of years ago.
We had rear end separation, but not frame sag in our 72 Sovereign (31 ft). One problem with read end separation is that it can cause you to think you also have frame sag (like we thought). But, once we solved the rear end separation issue, we found out we did not have frame sag at all.
Hope this helps.
Chris
Old 04-12-2012, 01:08 PM   #6
Minno's Avatar
1972 31' Sovereign
Forgot about checking the welds. But, it was 3 years ago when Andy went over it with me...
Old 04-12-2012, 01:40 PM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Bent frame with or without frame separation
From my knowledge from my 77 31 footer: You can have at least two problems with the frame and separation. The most common is frame bending between or just after the rear wheels. This can most easily seen by looking from back to front down the wheel mounting plate. It should be straight. If it has a warp in it, the frame is bent and will need to be straighten before you do anything else. You could also use the string or level method mentioned above. After you get the frame back to being straight, then you should add the frame strengthening plates made by Airstream.
If there was a bend the frame, separation from the body is more likely to occur. Check for frame separation by jumping on the back bumper. If it is loose you need to fix it. The easiest way is the use the elephant ears fix that Airstream recommended. If you have the interior walls out anyway, you can bolt directly or use the u-bolts. You will also have to fix any rotten plywood for any of these fixes to work.
If there is a bulge when looking down the side of the trailer, you could have a bent frame and/or the outriggers are rotted out or bent. If the interior walls are pushing holes into the ceiling, you definitely have the outriggers collapsing. You need to drop the banana skins and weld in new outriggers.
Old 04-12-2012, 10:36 PM   #8
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The Excella was the top of the line up until the early 80's when the Limited was introduced.
4RXLA is offline   Reply With Quote
Old 04-15-2012, 12:11 AM   #9
Aptos , California
Thanks for the responses.
So when did Airstream figure out that there was a problem and fix it? 80's 90's never?
Dave
Old 04-15-2012, 05:55 AM   #10
casa3805's Avatar
Corpus Christi , Texas
Images: 41
84 Sovereign
Dave
Ours is an 84 Dave (twins in the middle and rear bath) and we have had no problems at all. I do keep reading about the separation and I am very wary, but I think something happened in the early to mid 80's that changed it all. I am sure a history buff can chime in about different ownerships for Airstream and changed designs..
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 04-16-2012, 02:43 AM   #11
1977 31' Sovereign
1989 34' Excella
The Fix for weak frame
I think 1984 was the year Airstream decided enough was enough and went to the 5 inch deep frame to solve the weak frame situation that lead to all the bent 4 inch frames. The problem of frame separation, due to poor connection between the frame and the body of the trailer in the rear was solved by increasing the quality and quantity of the fasteners. There still was the problem of leaks in the rear seal system which lead to plywood (or OSB) floor rot. This causes poor connection between the body and the frame also as the floor is sandwiched between them.
There is no such thing as a indestructible trailer. I have seen units as late as the 2000's that have had frames destroyed and rotten floors. Several recent International Presidents, who put on lots of rough miles, have had to have their units repaired with the elephant ears fix to reattach the frame to the body.
Old 04-16-2012, 07:02 AM   #12
Central , Mississippi
A quick point - I had a '77 that had 5" frame rails so not ALL of the 70/80's were "frame issues"...
IMHO, the reason tail droop is so noticable in that era is two fold. Most units were rear bath which included a bunch of floor penetrations AND all of the leaky stuff was right at the back. This cause a better than even chance of the floor getting soaked and failing.
My '77 had been well cared for and had NO signs of floor rot in the back, thus no tail separation.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-16-2012, 07:12 AM   #13
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
My 77 31' Sovereign has a 5" frame as well. Oddly enough, the bulk of the "rear end" problems stem from water pouring in through the rear tail light assemblies. I would never have known this if I didn't remove the rear interior wall panels and stand inside during a torrential rain. This caused the bulk of the damage to the rear cross member and C channel. The back bumper compartment certainly contributed.
So, if you have water seeping in and can't figure out where it is coming from, check your tail lights!
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 04-16-2012, 03:59 PM   #14
Minno's Avatar
1972 31' Sovereign
Our '72 31' Sovereign also has a 5" frame.
