Old 01-05-2011, 05:34 PM   #1
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Morrilton , Arkansas
Images: 55
Photos of running gear condition
These are photos of a 1992 Excella 29 ft we just bought. Does this rust/corrosion, etc. appear to be normal or should we be worried about it. We are told the A/S is in towing condition. The tires appear to be 3 to 5 years old, any worries there? A/S has sat for at least 6 months on dealer lot and who knows how long before that. Rubber bushing at ends of shocks are cracked from age. Is there anything of major concern shown in pictures? If so, please advise us.
Inside is very nice, no problems there. Dealer fixed some plumbing problems and cleaned it somewhat. Checked electric items and all seem to work ok.
ID:	118812   Click image for larger version
ID:	118814   Click image for larger version
ID:	118816   Click image for larger version
Carol
2004 Dodge Ram 2500 Cummins HD
1987 Excella 32'
"Besides, I'm a gypsy at heart
and I like to travel around."
Reba McEntire
LawChick is offline   Reply With Quote
Old 01-05-2011, 05:41 PM   #2
1972 21' Globetrotter
nc , North Carolina
looks normal to me
rock60 is offline   Reply With Quote
Old 01-05-2011, 05:50 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Looks fine for towing to me. I can't tell from the photos what shape the axles are as far as still providing suspension. Even if they are shot it is still OK to tow it (maybe not great for all the way across the country, but locally is OK).
There is an article somewhere here as well as on the Inland RV site which will help you to evaluate them.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-05-2011, 05:54 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Looks like it spent some time near the coast...
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 01-05-2011, 06:01 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Replace shocks if rubber grommets are cracked is a common rule of thumb... I would also take a careful look at the brake wiring, make sure the wire is in good condition, rust and rubber do not mix well together... I would replace the tires!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 01-05-2011, 06:01 PM   #6
_
the surface rust in the pix is typical,
i don't think any predictions about WHERE the stream has lived are possible...
based on those few views.
Originally Posted by LawChick View Post
...The tires appear to be 3 to 5 years old, any worries there?
the tire DATE OF MANUFACTURE is stamped on the sidewall (inner or outer)
should be a 4 digit code for week/year IF they were manufactured after 1999.
so there is no reason to guess at age, find the date stamp.
5 years is getting CLOSE (like now) to replacement time regardless of tread depth.
3 years means another 2-3 years of life IF the thread depth is good
and there are NO side wall issues from inactivity.
the guys at the former AoA are good folks and won't intentionally grift ya,
but it's a nearly 20 year old stream, so much of it's history could be a mystery...
if the systems all check out and you've PAID for it...
go play and break some stuff...
congrats on the stream.
cheers
2air'
Old 01-05-2011, 06:46 PM   #7
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Images: 55
Thank you
One tire says 2506 for the date, which seems to be the oldest, we plan to haul it home and have them checked by a local tire dealer we trust. Most of your replies are pretty much what we thought and were told, just needed a little more reassurance. However, we do plan to drag it all over the country and expect to have to throw some more money at it in the process. This is our first TT and fell in love with this A/S when we first saw it. We couldn't buy it right then and there, but said if it was still available after 1/1/11 we would take that as a sign to buy it. Guess what !!!!!!!!!
Thanks for the replies. Now we look forward to naming her and starting our adventures on the road.
Carol
1987 Excella 32'
Reba McEntire
Old 01-05-2011, 07:07 PM   #8
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Looks like you got the "sign" and now are afflicted with the disease - sorry, there's no cure except more aluminum.
If you're gonna' tow with those tires, do make sure that they appear sound, check pressures carefully, and take your time (go slow) 'cause that's getting as old as you want to tow with for any distance. One other suggestion: before you head out homeward bound, either check yourself, or get some dealer comfort regarding the wheel bearings and test the brakes. If the bearings are gone or dying or need repacking, you can have a really bad day, and it's not apparent what is their condition without some inspection. Likewise the brakes. They're on the trailer for a good reason, and if they're not working properly, lots of bad things can happen.
Good luck and congratulations!
AirsDream is offline   Reply With Quote
Old 01-06-2011, 06:30 AM   #9
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Since this is your first TT, I will just mention that you need a brake controller on your Ram to operate the trailer brakes. I only mention it because when we got our Airstream it was our first trailer as well, and I had mistakenly thought that if the truck had a "tow package" all the necessary stuff was all ready on the truck.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 01-06-2011, 08:54 AM   #10
It appears in the right hand middle photo that the torsion arm of the axle may be going uphill as it goes rearward.
If that's the case, then that indicates the rubber rods in the axle have expired.
It's easy to check the axles out. Go to the article section of this Forums, and read the "Dura torque axle article".
Also, I would suggest that you drop the underbelly and thoroughly check out the chassis. From the visible rust, I would guess that the trailer was parked for a long time near salt water. That unfortunately, has a huge negative effect on the steel chassis integrity.
Old 01-06-2011, 10:48 AM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I totally agree with what Andy says.
I would tow directly to the first good tire shop and replace the tires right at the get-go. They need replacing, why take a chance of having trouble on your way home.
The axles and shocks look questionable as well. Not a huge expense, but can be a huge improvement.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 01-06-2011, 11:16 PM   #12
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Images: 55
We do have a brake controller on our Ram. We're going to replace the tires immediately. If we can get it to Dallas (we think nearest dealer now) we will get the shocks and maybe the axles done if that's needed. From what Andy said, probably is. We asked to have the wheel bearings repacked back when we first tried to buy it last October. The mechanic there now said he thinks they were inspected if not repacked. Going to have it done again since there seems to be some question whether it was done? Any way to find out for sure without going in?
One of our biggest problems is that there is no dealer nearby. AofA has stopped working on them now. But, I guess we'll just have to try to drag her somewhere near a dealer. It's about to get too cold here anyway, so we need to go south if we can get her well enough to go.
Thanks again for your input.
Carol
1987 Excella 32'
Reba McEntire
Old 01-07-2011, 07:17 AM   #13
Dwight's Avatar
1999 34' Excella
Joshua , Texas
What dealer in Dallas are you referring to?
Old 01-08-2011, 02:11 AM   #14
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Images: 55
Dallas Dealer?
Not sure. Haven't researched any of them yet, but I think there are a couple of AS dealers in the Dallas area. Are you familiar with them?
Carol
1987 Excella 32'
Reba McEntire
'73 Door Handle went to crap funkill Doors & Locks 46 06-04-2018 06:58 AM
The old girl needs new shoes.... Trex 1970 - 1973 Sovereign 1160 03-04-2017 10:39 AM
The long road ahead..... prob All Argosy Trailers 10 11-26-2011 07:32 AM
New Owner sgray Member Introductions 9 01-02-2011 08:16 AM
