Old 02-25-2015, 01:51 PM   #15
Sioux Falls , South Dakota
Thank you all!I just dont know enough and really appreciate all the help. I'll keep you updated as things progress.
Rocco1964 is offline   Reply With Quote
Old 02-26-2015, 12:17 PM   #16
Weimy's Avatar
1973 31' Sovereign
Ridgecrest , California
Same advice?
I am also looking at a sovereign, but a 73, rear bath and supposedly a "barn find", for $10,000. This trailer is a consignment at a dealership and they don't check anything and can't tell me anything about it.
Should I be taking the same advice that you have just given about the 80's trailer? Nothing works and most everything will probably have to be replaced?
Keeping that in mind when we negotiate a price, and when I start my project redo?
Thanks in advance,
Weimy is offline   Reply With Quote
Old 02-26-2015, 12:34 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Axles will need to be replaced, and chances are if no one will say that the water works that the fresh water pipes have frozen and broken, the water heater will be ruined also.
If the fridge has not run in years the refrigerant may have clumped.
I would say that the rest of the appliances will likely be ok.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 02-26-2015, 12:40 PM   #18
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Thanks in advance,
YEP, except it's 12 years OLDER than the 85. If the dealer hasn't looked it's probably because they don't want to know! Again get real fussy about looking for un-messed with. Nothing worse than buying a unit from someone who did hack job maintenance or renovations.
Always remember, this is NOT the only Airstream calling for your love or attention. If "outstanding" doesn't make the back of your throat start to tingle - take your time. I used to write resumes and advise people who were re-entering the workforce after years of raising children to go somewhere you'd never want to work like the local sewage plant or chicken dressing plant and interview. You can practice interviewing with NO stress or worry about missing out on your dream job.
You should probably try to find a real basket case "meth lab" or "it's been rotting in a field for six years but we finally got the possom's out" Airstream for your first look-see. NO temptation Airstream will make you know what a good one should be.
Old 02-26-2015, 02:07 PM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Ok a rear bedroom model is more valuable and sought after than a rear bathroom one.
I would check out as many of the services on the trailer that you can. The water, the a/c and heat, stove etc. Look over the body under and over for issues. Figure on tires needed, though the present ones might get you home albeit at a slow safe speed.
Wheel bearings may need grease.
Other thank that if it looks good and seems like it is as the owner described, and checks out fairly well make an offer. This could be a great trailer to own.
My present one is a 66 that sat in a field for 18 years, and was totally nasty inside. Even with all that and pretty cracked tires, it made it home... got cleaned and fixed up and has been a thoroughly enjoyable Airstream. I have not replaced the axles and won't for some time to come.
It pulls fine and I am not seeing any rivets popping out all over the place.
Don't be afraid of the negative remarks you may see here. I've been on this forum since day 1.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-26-2015, 06:03 PM   #20
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Need advice
I simply posted my experience.
I fixed the rear separation, I replaced the last four feet of frame and replaced the rotted plywood, put it together and made three 3,000 mile round trips before replacing the axles and the rear of the trailer sagged a fairly substantial amount. You could actually see that it was downhill going into the bathroom.
It wasn't a hard fix, (the rear did not come apart again, the frame just bent where the axles pass through the notch), but the fix would have been unnessasary had I changed the axles first thing.
Old 02-26-2015, 06:17 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1424999805.995903.jpg
It is pretty straight now, and raised 3" to boot....
Old 02-26-2015, 06:28 PM   #22
1971 31' Sovereign
Indian Wells , California
Weimy- I only paid $2500 for my original '71.
CraigCA is offline   Reply With Quote
Old 02-27-2015, 07:57 AM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Morgan- that trailer looks really fine. I still like the 31 footers, but my 26 is so light that it is a pleasure to tow. Can't beat the late 60's trailers.
AIR #005
retired!
Old 02-27-2015, 02:51 PM   #24
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea, with my changes mine weighs in at about 6,500 ready to camp.
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
Need advice Classic vs. Land Yacht fangthorpe Airstream Motorhome Forums 11 02-27-2003 10:46 AM
Brand new to this; need logistics advice 4521red Our Community 21 01-01-2003 09:07 AM
Need your advice-buying a vintage A/S randomnoise Our Community 7 11-08-2002 09:19 PM
