Old 07-20-2019, 03:04 AM   #41
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
If the 2 units in question were the same capacity and physical size, their efficiency (BTU delivered per KW consumed) would be the same.
If one system had a physically larger evaporator or condenser coil but the same BTU capacity, that unit would be more efficient because that unit would have more surface area to reject the heat and thus deliver more BTU per KW consumed.
A ducted a/c system would take longer get a space to temperature over a non ducted system if the ducted systems supply and return outlets total free area was less than the non ducted system (assuming they were both the same capacity). Were all the a/c outlets opened 100%?
If that is the case, it would make the non ducted system SEEM more efficient because the trailer cooled off faster.
The benefits of a system that takes longer to cool off a space are this....
1. The longer a system runs between cycles means that more moisture is removed from the space. The drier the space, the better the comfort.
2. The fewer times a system cycles (turns on and off) to maintain a set point in an hour means less wear and tear on the internal components of the a/c which should increase its life.
twbucksr is offline   Reply With Quote
Old 08-31-2019, 04:24 PM   #42
2018 22' Sport
San Antonio , Texas
Just picked up my 2020 Flying Cloud with 50 amp and two acs. Will be spending September in South Texas heat. Should be interesting test!
CinTerLine is offline   Reply With Quote
College aged... looking at maybe getting trailer.... Advise please saturninin Vintage Kin 17 10-24-2012 08:11 AM
Long Tour and we NEED internet please advise zenarmy Computers, Internet & Satellite 74 12-30-2011 11:23 PM
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Looking for Advise on Possible Purchase gerry303ca 1974 - 1977 Overlander 6 08-21-2009 06:03 PM
Need some quick advise on a Chevy PU! Please rlambs Tow Vehicles 20 10-16-2004 11:05 AM
