Old 08-15-2014, 04:30 PM   #15
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I can't comment personally from experience with Airstream restoration - I opted to buy a used but fairly new one.
But I do have some experience in restoring old Brit sports cars. In that field the wisdom seems to be that unless you want to do it for the experience, you are better off financially using one someone else has restored - always provided of course that they have done a decent job!
I didn't heed that info and restored several old sports cars only to have them be worth abut half what I invested! It was fun, I learned a lit and developed some new skills and had the satisfaction of doing it, but I wouldn't do another!
I suspect restoring old Airstreams might be in the same category.
So I think it depends what you want out of it - if you intend keeping it a long time, it still could be the way for you to go. You would have the satisfaction of knowing you did it yourself and could work to the levee of quality that you are satisfied with.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-16-2014, 11:21 AM   #16
Canton , Michigan
If you are going to see the '69 Ambassador in Winnetka that is on airstreamclassifieds.com as well as ebay (for a long time, BTW), a couple of observations:
No where in his long description are crucial mechanicals: axles, fridge, ac, furnace, listed as "replaced" or "newer."
More importantly, there is not a single syllable about any work on the subfloor or frame. If I recall correctly (please correct me if I'm wrong on this 'Streamers), a design change beginning in this model year made floor rot and frame issues very common--almost universal in our midwest climate. Plus, the seller has added a lot of weight in the remodel and without reinforcing the frame that makes me very uneasy.
HawkinGal is offline   Reply With Quote
Old 08-16-2014, 12:07 PM   #17
Canton , Michigan
Then there's the two huge dents...
Old 08-16-2014, 03:56 PM   #18
aquinob's Avatar
Portsmouth , Virginia
If you look at the one pic of the streetside, you will also see some rust staining on the frame just forward of the bumper and it looks like there is a bit of a gap between the sheet metal and top of the frame that might indicate some rear end separation.
Other things to note are no awnings, the top of the wheels is about even with the side of the aluminum which most likely points to old axles.
Fridge and stove are newer, looks like lots of newer woodwork. Not sure if I would want to fill up that tub with what it would do to the frame.
It shows well enough in the pictures, but if nothing has been done either structurally with the frame or the axles are original, then I think it is overpriced. (especially with two huge dents).
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 08-18-2014, 08:40 AM   #19
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
A couple of thoughts...
"Is it worth it?" - Yes, for many it is a labor of love! As others have mentioned, if it is a labor of love for you and you don't plan on "making money on it" when it's time to sell, it can be worth it.
"Major renovation while living in it" - this is tough. It really depends on how major of a renovation you are undertaking and your tolerance for living in a construction zone and "without" while working on it. (Sounds like you may have a high tolerance for these based on your comments about living in a tent, etc.) Start with the best trailer you can find - and avoid the full-monty style restorations.
"Winter living during the renovation...in Illinois" - This one is to me could be a deal-breaker. Winter conditions in a tent - without options? Is this really do-able? Maybe being an outdoorsman from working on road crews & in construction makes for a hearty lifestyle, but that seems a bit much. During a major renovation an Airstream is not much more than a hard-sided tent....at at times, it's even less. Again, this will depend on the starting condition of the trailer and to what level it needs to be disassembled.
"Full-Time Living in an Airstream...in Illinois" - Even in a new Airstream this is going to be a challenge through the winter months. Airstreams are really intended as three-season trailers. In addition to reading through the "full-monty restoration threads" I would also suggest you hit a few of the "winter-living threads". Issues that will need to be dealt with are insulation, humidity and water/tanks freezing up. One of my "favorites" is this oldie but goodie Winter Living by Rubyslipper Airstreams are not insulated like a house and most have exposed water lines that will freeze.
"Place to park near Chicago" - If you are considering a pre-1974 trailer, you will need full sewer hookups as they didn't have any grey water tanks and dealing with a blue-boy on a full-time basis will get real old, real quick.
All that being said, it is do-able, BUT...it won't be with challenges. If you have a back-up plan for getting through the restoration and severe winter conditions, you will end up with an Airstream to live &/or travel in and hopefully to be proud of when you are done. Good luck!
Shari
Old 08-18-2014, 11:56 PM   #20
Portland , Oregon
We wanted an Airstream then got sticker shock for gutted roaches. So we ended up with a Streamline. Similar, but cheaper since they are less popular.
But if you're a contractor you can easily live in one while fixing it. As long as the floor is solid and you don't have to rip it out, the rest can be fixed in stages.
I taught myself how to use PEX and did the plumbing in a weekend.
A new furnace took me a week (a few hours a day, working full time, etc).
I'm into ours well under $10k, and could probably get what we have into it if we had to sell. But then it was in great shape when we bought it. 2 owner, stored in a barn, all electrics and plumbing still worked.
Ian Lomax
1966 Streamline Countess 26'
JeweloJalopy is offline   Reply With Quote
Old 08-19-2014, 06:56 AM   #21
1981 31' Excella II
New Market , Alabama
I probably have more in my trailer than it is worth but I know what I fixed will stay fixed and I know the trailer inside and out and can fix most things on the fly if I have to. I have spares for all the stuff I fixed. Even a new trailer is going to take maintenance.
Perry
Old 08-19-2014, 07:19 AM   #22
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Our first Airstream was a very used 1977. We were able to use it after a few minor fixes. We worked on it and enjoyed it at the same time. We did not full time, though.
We then purchased a more gently used Airstream that had some options we wanted.
Our current AS we bought new. Knowing what we know now, we might have opted to keep the old one and do a total renovation. At the time we didn't have the time or money to do that.
There are plenty of ways to do it and you will find one that works for you.
Welcome to the forums.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-19-2014, 08:10 AM   #23
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
a voice of dissension:
"Is buying vintage and fixing it up worth it?"
If you have to ask if it's "worth it" then maybe it's not.
For us, there was no question if it was "worth it."
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 08-19-2014, 09:05 AM   #24
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Everything Shari says is right on. My biggest thought about any aging steel in Illinois is it's rust rotted. For a place to park there is a fair RV park in Marengo with a few full hookup sites available. It's mostly a park model park.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg TDI
Santana tandem bike
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 08-20-2014, 01:31 PM   #25
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
1969 Ambas Is it worth it?
I have a 1969 Ambassador mid twins. If you look at my threads you can get a good feel for what may need to be done. Feel free to IM me if you want to chat, I'll give you my phone number.
Some things to look out for, and noted above. Rear end floor and frame rot. The back seal between the bumper trunk and body leak, letting water seep into the floor. I had to replace the about three feet of the main rails back, and out riggers, and 4 feet of floor. Also the front Frame from the front door forward. The big question for any of these is what kind of shape is the frame in. The inside will look great, but if the floor and frame is rusted out it will be a bunch of work.
To check for rear frame separation/ Rot, put you foot on the rear bumper and push down. Is there is any movement between the body and bumper then there is problems. They should be bolted together tight and move as one.
Now with that said, if you are living in a camp group with bath house I would not worry about it too much. Just make sure they are ok with you working on it in their camp ground. It can get messy.
Looking back, the most import thing to look for is a clean shell. As few dents as possible.
Silverflames is offline   Reply With Quote
Old 08-20-2014, 01:39 PM   #26
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
I also want to point out that vintage trailers are becoming all the rage, and the value of a finished trailer will be much higher than it was just ten years ago.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 08-20-2014, 01:52 PM   #27
1967 24' Tradewind
Images: 38
And while it's been ten years since we bought it and we're just now getting ready to finally get our act together and put the shell back on (life got in the way) I can tell you from experience that you'll meet cool people and have SO MUCH fun. We went on a trip to Disneyland, and one forums member came to pick my family and me up from the airport and drive us shopping and to our hotel and hadn't met us in person ONCE. I've been to many Airstream rallies, the Vintage Restoration event, and just had so much fun in general. We have not been able to travel in our Airstream once yet. It's like having a low-paying job that's fun. The benefits aren't necessarily visible. Look how many friends you've already made!
From my experience the members are very supportive here to those who don't know what on earth they're doing.
I don't know how long you are willing to wait, but attending this would be perfect for you. www.vintagetraileracademy.com. the 2014 one is over but there will probably be another one 2015. We went, and got lots of great information and you will get a first-hand look at what it takes to fix one up.
~ Hurley
ingrid
Old 08-20-2014, 02:40 PM   #28
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We had our AS appraised this spring: she appraised for $16,000 more than we had spent. And, we're not even done yet. Is it worth it? Financially, if you do it right, YES. We have done full monty, and don't count our labor as part of the cost.
Kay
Worth fixing up or not?? HELP! rjmiester Trailer Values 38 11-12-2009 05:18 PM
Ebay AS. Worth fixing? You decide! Streamer1 2005 Safari 23 11-21-2007 07:46 PM
Worth fixing, or parts only? You decide! Streamer1 Ribs, Skins & Rivets 10 01-10-2007 10:07 PM
Worth fixing or not. chapparel Dollars & Cents 8 11-02-2006 10:31 AM
Bathroom water damage? Worth fixing? Curtis-79MH 1966-68 Caravel 3 09-12-2006 11:55 AM
